T.Rex vBeats Drum Machine Plugin by Max Project
2021-8-13 06:25| ·¢²¼Õß: 6975510| ²é¿´: 904| ÆÀÂÛ: 0
ÕªÒª: T.Rex vBeats is the new virtual instrument from Max Project.It consists of 10 analog drum sounds captured with the highest quality.8 classic rhythms called InstntBeats that allow you to quickly genera ...
8 classic rhythms called InstntBeats that allow you to quickly generate ideas or use them as accompaniment with some other instrument.
Main features:
10 Analog Drum Sounds.
8 Classics Rhythms (InstntBeats).
Master volume control.
Integrated algorithmic reverb.
Vintage-Modern looking GUI.
Low CPU usage.
System Requirements:
Windows (Vista, 7, 8.1 and 10) or Mac OS X.
VST3 compatible DAW hosting software in Windows.
Audio Units & VST for Mac OS X.
Products similar to T.Rex vBeats...
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
