SYNTH ANATOMY uses affiliation & partner programs (big red buttons) to finance a part of the activity. If you use these, you support the website. Thanks! Nektar Impact GX Mini is a new portable USB-MIDI keyboard with 25 velocity-sensitive mini-keys and tons of DAW controls for on the go. Small USB-MIDI keyboards come in handy. You can put it in your backpack and take it with you anywhere. They make mobile music-composing possible. And there are a lot of small, affordable keyboards on the market. But a company doesn¡¯t believe that yet. Nektar has today launched the Impact GX Mini, a new portable USB-MIDI keyboard for little money. Nektar Impact GX Mini Nektar Impact GX Mini The new Impact GX Mini features a newly developed velocity-sensitive keybed with 25 mini-keys including three velocity curves. There is no aftertouch support. Nektar does without classic pitch and mod wheels and uses instead a joystick for modulation control. It outputs pitch bend (left/right), modulation (up/down), and other real-time MIDI messages. I put the reward on USB-MIDI because the keyboard has no classic MIDI jacks. It only transmits the MIDI data over USB via a micro USB cable. It¡¯s a shame that a keyboard of 2021 does not have a USB-C, which is much more solid and future-proof. Also with the focus on the connections of modern PCs, Macs, and iPads with USB-Cs where you need an adapter again. Nektar Impact GX Mini Part 2 A highlight of the keyboard is a large number of DAW controls. Eight dedicated buttons put essential DAW functions right at your fingertips. Give your mouse a break and control transport, track navigation, and other features with Nektar DAW Integration for the most popular DAWs. The buttons are also MIDI assignable for use with any software that¡¯s not supported. Further, it offers Nektar¡¯s unique Part 2 feature that adds momentary transpose, MIDI note layering, and more. Nektar says: While playing, simply press one of the dedicated ¡°Part 2¡± buttons and momentarily shift the octave up or down, transpose, layer another octave on top ¨C or switch to another MIDI channel altogether. The instant you let go of the buttons, Impact GX Mini reverts back to its original settings. What¡¯s more, any note that was played prior to pressing ¡°Part 2¡± will keep playing at the original settings ¨C so you could play and hold some really low bass notes, while playing a solo over the top. A great performance feature! On top, Nektar ships its controller with a license of Bitwig 8-track, a stripped-down version of Bitwig Studio with the option to upgrade for a better price. At first glance a nice, affordable MIDI keyboard for on the go. Lots of control and smart functions. Only the micro USB connection gives me a stomach ache Nektar Impact GX Mini will be available in mid-August for 69,99 |
