PiKTrix ROMpler Plugin by Midi Mobiles
2021-8-11 08:40| ·¢²¼Õß: albedo| ²é¿´: 1296| ÆÀÂÛ: 0
ÕªÒª: PiKTrix is a 'Sample Instrument Collector Tool' but not only.It's a DIY Rompler Project developed specialy for the KVR DC 2021 and and includes a soundware...PiKTrix_Ony is a simple player (only one i ...
PiKTrix_Ony is a simple player (only one instrument) of ~patch.pkt files.
The .pkt files are just the listing of a .wav files repertory. You can sort the .wav files by notes with Instrument_Creator.bat (from the PiKtrix interface) or just play an existing .pkt file. You don't need to compil an only .wav file with all the .wav files. Just the ~patch.pkt file in the .wav directory.
PiKTrix_Qi-Rack is another way to experiment some sound design with 4 layering of instruments connected to 4 arp modules and a global master (Flanger/Phaser/Delay/Reverb) and also an EQ (HP/LP Bass/Med/Treble) by layer...
As a modular, you can connect cables from 5 oscillators (4 mod wheel and OSC Speed in the FiltoDrag module) to 3 inputs (arp for modulate the speed, flanger & phaser effect too).
It is possible also to transpose in real time in one layer or All layer in the same time (in MIDI notes).
You can directly experiment the PiKTrix sensation just after the installation of 2 'essentials' soundbanks by flipping through the patches or choosing in menu bank / Program the instrument you want to play.
If you are new user of PiKTrix, first download PiKTrix 'Sample Instruments Collector Tool'.rar (478,7 Mo).
or download the Update PiKTriX v.1.1.rar (33 Mo) *** New Sounds & Fix some Bugs ***.
You can also if you want download PiKTrix Soundbank [Deluxe Version] (1,41 Go) (2,33 Go when unzip) but it's not very necessary to increase the audio quality for test the PiKTrix project...
Some fixes were made to fill in the finishes :
(version 0.2)
correct the bugs listed:
Momentary reset on patch menu.
Fix Bloc Note on 64-bits versions.
Fix Velocity 'On' (All versions).
Less springs off in FiltoDrag with 'No Filter OSC'. More flexible game play interface.
More MIDI Learn for External Controls.
And maybe other minors bugs...
New Sounds ... (Omnichord) in "KVR DC2021 Updates" bank...
(version 0.3):
OSC Link button under panic button (you can already access to OSC Setting by right click on mod wheel).
No 'OSC Send' in OSC Setting menu in the Ony versions (useless).
No reset on 'No filter OSC' in FilterDrag module when you click to 'Envelope'.
'Master' Button (useless before the 0.3 update) is now a bypass FX (original sound without Mod wheel FX, FiltoDrag & EQ process).
(version 0.4):
Some change in the name of VST3 versions.
Improvement with patch initialisation (mascot On/off at every patch change for Ony version).
More patch memory on 'Master (byp) ' option in Ony versions.
Improvement with Mod Wheel in all versions (Possibility to make some Ring modulator FX with the Mod Wheel with high values) and better Increasement level with 'White Noise' & 'Pink Noise' waveform in Osc seting).
(Ony version 0.41):
MIDI in is blocked at each program change for 2 seconds.
Fix keyboard that generated an unwanted note during patch initialization.
(version 0.5) ::
It seems that a image was still not present in the 'Ony' versions (Chi-Rack__porta_click.png).
Fix the Disk menu on '3.Create Instruments (Load .wav repertory)' in 64-bits versions (it was just a bad link. Note that it's the only option that is implementated in this menu for the time being...).
Fix GUI activation bug of 'FilterDrag' modes when you click to 'Speed OSC' (temporarily in 'off' position).
On PiKTrix Qi-Rack, When 'Hold' is 'on' position in Arp module, CC64 MIDI messages are filtered to facilitate multi-layer play with a sustain pedal (only on Qi-Rack versions).
Better MIDI integration of 'Pitch Filters' (after a MIDI learn) on all plugins versions and 'Fader Morph' on Qi-Rack versions.
Improvement of 'OSC Send' with Noise Waveform (better volume dosage) on Qi-Rack versions.
Display of Mod Wheels on 'OSC Setting' panel in all versions.
Better install and Update (autonomous).
And other some minor bug...
(version 0.51) ::
Mod wheels don't bother the keyboard anymore in all versions.
Fix bug on Fader Morph with mouse drag.
(version 0.6) :
[On Qi-Rack version] ::
Improvement in the Arp module for have the first note at start (always the second before this update).
Less value in speed of the Arp (deletion of 'd' value for a better incrementation of the speed for the moment).
Better view of 'OSC Setting' panels (by selected layer).
'Medals' in OSC Setting panel (modulation, Vibrato, Pan drag) are now connected to the audio out after Master bus (after Reverb & FiltoDrag modules) to have a better result and the medals are independants (does not depend on checked boxes wich are connected before the Master bus). And you can also have the 2 modifications of sounds (before & after) if you check boxes and activate medal of the parameter.
Better placement of cables images in PiKTrix Qi-Rack 32 and the cables don't bother the controls of the GUI Interface.
Memory in program change in the Mod Wheels on PiKTrix Qi-Rack 64 .
[on all versions]:
The stroke of mod wheels parameters (modulation, Vibrato, Pan drag) had been improved (better range & smooth at beginning of the stroke).
The Envelope is not the default mode of FiltoDrag when nothing is selected now (no movements in filter).
Envelope button now disable when Oscillator is selected.
Update of several patches which have been reworked (50 presets on all versions but on the 32-bit versions & 64-bits version of PiKTrix Qi-Rack, presets are not the same !).
Better 'Init' on 32-bits versions... and even better things soon (surely after the KVR DC2021).
(version 0.61) :
Fix bug in Install.bat for installation of VST3 Presets...
(the presets dated from the end of June with the old one !!!).
With install.bat in Update PiKTriX v.0.61.rar, you can update automatically the VST3 presets of PiKTrix already installed in your PC (with the plugins .dll & .vst3).
If you don't have PiKTrix, download PiKTrix Soundbank [Deluxe Version].rar
Good luck for all KVR DC2021 Entries.
(version 0.7) :
Fix Initialisation Bug in 32-bit versions .
Better organization of parameters in all versions (private or visible in your DAW).
(version 0.8) ::
Corrections in Install.bat (new folder 'Module\' with PiKTrix.txt for not delete this after Install.bat & Uninstall.bat). PiKTrix.txt allow you to write you 32-bit Plugin & 64-bit plugin repertory (no VST3 but only 64-bit. VST3 is in Common Files\VST3 & Documents\VST3 Presets...).
A file must be rename in the pataphysis soundbank : 'vintage Case (L2)~pitch.txt' (Install.bat do it).
Shortcut to the differents standalone versions of PiKTrix.
Some minor modifications in PiKTrix Ony presets...
(Version 0.81) ::
Add 'Chi-Rack__OSC_Set.PNG' & 'Chi-Rack__OSC_Set.txt' in PiKTrix Ony 32 (missing).
Better Installation to support [Deluxe] soundbank.
(Version 0.9 on Ony only) ::
Better memory in 'Master (Bypass)' (Background mode & reload session with PiKTrix Ony).
Improvement on PiKTriX Ony Presets.
(Version 1.0) ::
New interne architecture for improve the stability in multiplugins (test of 32 x 'PiKTrix Ony 32' in Cubase studio 5 with success !!!).
There will be more release in all presets. Lower it a bit .
(Don't use more than 4 occurences of PiKTrix Ony 64 for the moments while the modules developers adapt them to the 1.4 version 64-bit of synthedit
or simply a future update of synthedit to remove limitation of native wave player / ADSR / MIDI 2 CV if it's possible...
Thanks in advance to Jeff McClintok to the wished possible help !)
(Version 1.1 on Ony 64 only):
New audio modules in architecture core of 64-bit version for improve the stability in multiplugins mode (test of 10 x 'PiKTrix Ony 64' in cubase studio 5 with success !!! maybe more possible but never did the test...).
New function 'Looped' in PiKTrix Ony 64 (with new image 'Looped').
Presets updated (less release & Looped) with new picture & modules (ElenaSamplingModules_x64.sem, TD_MemoryPack.sem).
The 'Lock' image has been removed (was useless).
Correction in Install.bat to target 'PiKTrix.txt' localized in priority on "Modules\PiKTrix.txt" (from 'Update PiKTriX v.1.1').
Correction of some minor bug...
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
