| Solina2K is physical modeling based Solina strings ensemble emulation that uses 8 independent oscillators, each with its own synthesis section. Solina2K has also 2 different MIDI velocity options, a user friendly global hipass-lopass filter, a full section of built in effects (saturation, chorus, phaser, tremolo, reverb and delay), built-in draw-bars system, advanced mono mode, keyboard split option with hi-lo-both zones for both the upper and the bass sections, full automation and unique gleam effect per section (upper and bass). The sections can also get routed into any of the the effects separately. |
