HLQSE 4.0 : Extraordinary Type 69 Equalizer - Analog Obsession
2021-8-9 08:11| ·¢²¼Õß: 703831| ²é¿´: 909| ÆÀÂÛ: 0
ÕªÒª: Type 69 style eq with discrete bands. So, you can boost or cut bands at the same time.FEATURES- 0 to -15dB cut @50Hz- 0 to 15dB boost @60/100/200/300Hz- 0 to -15dB cut @0.7/1/1.4/2/2.8/3.5/4.5/6kHz- 0 ...
FEATURES
- 0 to 15dB boost @0.7/1/1.4/2/2.8/3.5/4.5/6kHz
- 0 to -6dB cut @ 10k Hz
- 0 to 15dB boost @ 10k Hz
- +/-15dB output control
- ANALOG OBSESSION LOGO: Oversampling. It will turn to red when oversampling is engaged. Also, show you a notification.
Available Formats
VST/VST3/AU | Mac 10.9 - 11.X
VST/VST3 | Windows 7 - 8 - 10
UPDATE - VERSION 4.0 - 3.8.2021
- Fully optimized circuit and improved DSP
- Lower CPU usage
- Added 4x Oversampling
- Added readout
Patreon
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
