EXC!TE Snare Drum free VST3 plugin for Windows, Mac & Linux
2021-8-8 08:43| ·¢²¼Õß: audiolab| ²é¿´: 833| ÆÀÂÛ: 0
ÕªÒª: EXC!TE Snare Drum free VST3 plugin for Windows, Mac LinuxThe Center for Haptic Audio Interaction Research has released a virtual instrument that delivers an ultra-realistic snare drum sound through p ...
The Center for Haptic Audio Interaction Research has released a virtual instrument that delivers an ultra-realistic snare drum sound through physical modeling algorithms.
EXC!TE Snare Drum¡®s algorithms are tuned by ear to resemble snare drums of different sizes, different tip hardnesses, rimshot sounds and adjustable snare rattle.
The instrument is available to download for free as a VST3 plugin.
There¡¯s also a Pro version ($19.99 USD) which adds a side-chain input, frequency shift for playing different resonances with external input, and a crunch parameter to change the timbre of the snare rattle sound.
If you are into sound experiments, or you are seeking for more intimate control over a complex sound generator, you should definitely get the PRO version. You will love to play the snare drum with your hands or drum sticks just as we do!
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
