Sinevibes Corrosion 2 Gives Mac Users 15 Ways To Distort Sounds
2021-7-29 08:31| ·¢²¼Õß: 3935310| ²é¿´: 828| ÆÀÂÛ: 0
ÕªÒª: Sinevibes Corrosion 2 Gives Mac Users 15 Ways To Distort SoundsSinevibes let us know that they¡¯ve introduced Corrosion v2, a major update to their Mac distortion effect, featuring a total of 15 diffe ...
Sinevibes let us know that they¡¯ve introduced Corrosion v2, a major update to their Mac distortion effect, featuring a total of 15 different distortion algorithms.
Here¡¯s what they have to say about it:
¡°Corrosion includes a wide selection of different distortion algorithms, from classic clippers and folders to very unique curves invented at Sinevibes. Distortion gain can go up to 24 dB and has a tilt control for natural stereo width effects, plus the plugin also features an exponential gate which can be used for both for noise reduction on analog recordings ¨C as well as more creatively to ¡°chop¡± audio.
With its special ability to adjust the upsampling filter¡¯s cutoff frequency and mix in the dry input signal processed via a steep high-pass filter, Corrosion delivers a huge variety of sophisticated distortion effects, from subtle boosting and drive all the way to dramatic waveform bending, warping and destruction ¨C and it does so via extremely simple controls.¡±
Features:
Distortion engine with 15 different algorithms and 4x oversampling
Flexible frequency crossover capabilities with simultaneous control of distortion upsampling filter and dry signal high-pass filter
Gain tilt control for stereo width effects
Built-in exponential noise gate with variable threshold, attack, and release
Lag filters on all continuous parameters for smooth, click-free adjustment
Supports mono › mono, mono › stereo, and stereo › stereo channel configurations
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
