Hum808 X Synth (Hybrid) Plugin by Callybeat
2021-7-24 08:59| ·¢²¼Õß: 6055190| ²é¿´: 1075| ÆÀÂÛ: 0
ÕªÒª: Hum808 X.It is a synthesizer designed to be easy to use thanks to its intuitive all-in-one interface.The reading of the signal is possible thanks to its spectrum analyzer andto your oscilloscope that ...
Hum808 X.
to your oscilloscope that allow us to shape the sound with great ease from a technical as well as a creative approach.
Its three oscillators together with the sampler can operate in subtractive synthesis or FM according to the configuration of each user, facilitating sound experimentation with unimaginable ranges., .
A quick example.
1., Load the Default preset
2., In master panel put Carrier freq with Osc1 - Osc2 and Mod in Sampler activate the FM button
3., Drag a sample from a bell to the sampler and activate it
4., Activate the Pitch Modulator with a 10% mix in the Envelope tab
5., Adjust modulation from -3.84 to 3.80 st in 2 steps
6., Remember to Activate the Pitch mod and Loop button
7., Increase voices, unison and spread to your liking and listen to your patch.
And to finish creating your idea you can process your sound with its 5 included effects ...
Let's have fun designing something with the Hum808x.
These are its main characteristics:
Additive Synthesis and FM.
3 oscillators with 5 waveforms.
1 sample book with 70 useful samples in FM synthesis.
Maximum 16 voices with unison.
Spread voices.
1 ADSR surround sound control.
8 dedicated modulators.
Modulation to time synced DAW.
16 types of filters with modulators.
5 effects: distortion, compression, limiter, reverb, delay.
1 parametric equalizer.
5 Zoom settings for GUI.
Midi Learn with Left Click and move on buttons, knobs and pitch wheel for any MIDI controller.
Assign CC with Left Click on buttons, knobs and pitch wheelfor any MIDI controller.
Spectrum analyzer.
Oscilloscope.
Velocity response adjustment.
130 presets.
Freeware and open source (GPL3).
http://soundcloud.com/callybeat/hum808x-100-music
{See video at top of page}
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
