GFilter Filter Plugin by Flandersh Tech
2021-7-17 08:58| ·¢²¼Õß: telemon| ²é¿´: 871| ÆÀÂÛ: 0
ÕªÒª: GFilter is an easy and quick to use multitype filter for VST3 (64-bit). It was born out of a need for something quick to add to instruments in a mix, and evolved to a processor able to clean up the mi ...
GFilter is an easy and quick to use multitype filter for VST3 (64-bit). It was born out of a need for something quick to add to instruments in a mix, and evolved to a processor able to clean up the mix as well as spice it up with creative effects. Bundled with the GFilter comes GGen, which is a standalone filter impulse response generator for Windows made specifically for use with the GFilter IR Filter processor, and some example impulse responses made with it and ready for use in Gfilter.
Features of GFilter:
14 types of filters.
Impulse Response Filter and DC Blocker.
Delay and creative effects.
Simple LFO modulation.
Spectrum meter.
Features of GGen:
4 filter types.
10 window types.
2048-taps impulse responses.
Impulse and spectrum meters.
High quality WAV export up to 32-bit float and 384000 Hz samplerate.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
