Free T-De-Esser​ effect plugin offers a pure natural sound (VST/AU)
2021-7-17 08:26| ·¢²¼Õß: 2697280| ²é¿´: 912| ÆÀÂÛ: 0
ÕªÒª: Free T-De-Esser​ effect plugin offers a pure natural sound (VST/AU)Techivation has announced the release of the T-De-Esser​, an easy to use de-esser plugin that smooths out high frequencie ...
Free T-De-Esser effect plugin offers a pure natural sound (VST/AU)
Techivation has announced the release of the T-De-Esser, an easy to use de-esser plugin that smooths out high frequencies while maintaining a natural and musical sound.
Make your audio sound smooth and crystal clear. T-De-Esser uses the latest technological innovation to help you achieve crisp and bright results, without any harshness or sibilance.
T-De-Esser features
Side Chain Frequency Modes: Includes 4 specific side-chained frequency bands to detect the harsh sounds.
CPU Optimized: Carefully optimized for low CPU usage on both Windows and macOS.
GUI Scale: Scale up/down from 80% to 150% depending on your preferences.
Undo/Redo: Undo and redo options are built inside the plugin so you no longer need to worry about losing setting values.
A/B Switch: Quickly and simply compare different settings to find out which would fit well.
Available for Windows and Mac in VST and AU plugin formats, T-De-Esser is free to download.
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
