DxO PureRAW 1.2 Build 237 x64 Multilingual File Size: 130.4 MB DxO PureRAW Simply better RAW files, Enhance your RAW files to open up even more possibilities with Adobe Photoshop and Lightroom®. Unlock the RAW-file editing capacity of Adobe Photoshop and Lightroom Create better RAW files before retouching them in Adobe Photoshop, Lightroom, or other programs thanks to DxO¡¯s exclusive demosaicing, denoising, and lens defect correction technologies. Pure, flawless, and noise-free RAW photos DxO PureRAW¡¯s artificial intelligence strikes the perfect balance between preserving detail and eliminating noise. DeepPRIME technology solves these problems before you and better than you. Your lenses deserve the very best corrections Automatically correct the defects in your equipment using DxO¡¯s specially designed optical modules. Recover your old RAW files Get back to editing your old photos that you set aside because of poor image quality, noise, or a lack of sharpness. DxO PureRAW gives you another chance. Perfection is in the details Enjoy large format photos: DxO PureRAW reveals all the details and finesse of every texture you capture so you can enjoy incredibly pure photos. Soft, non-grainy bokeh Permanently delete the ¡°parasitic¡± grain your camera creates in the blurry areas of your photos. DxO PureRAW adds incredible softness to your images. Photo editing made simple Use DxO PureRAW before your usual editing software and convert your RAW files into DNG files in just a few clicks¡ªall without sliders or complex adjustments. system Requirements: GPU COMPATIBILITY Starting from: NVIDIA GeForce 8 Series, ATI Radeon HD2000 Series, and Intel HD Graphics 2000 Series or Apple silicon. If no compatible card is available, GPU acceleration will be disabled, and the CPU will be used. MICROSOFT® WINDOWS® Intel Core® 2 or AMD Athlon™ 64 X2 or higher (Intel Core® i5 or higher recommended) 4 GB of RAM (8 GB recommended) 4 GB or more of available hard-disk space Microsoft® Windows® 10 version 1809 (64-bit) and above What's New: official site does not provide any info about changes in this version. Download rapidgator https://rg.to/file/d61b0788f49fd2c20b28d2bf5c726c66/DxO.PureRAW.1.rar.html Download nitroflare https://nitro.download/view/5735BFFF316270E/DxO.PureRAW.1.rar Download °Ù¶ÈÍøÅÌ Á´½Ó: https://pan.baidu.com/s/1DFrVP0pK9R30jobw80x5tg ÌáÈ¡Âë: sytk |
