DJ Spinz 808 Alternatives The Spinz 808 is probably the single best-known sample among Trap producers. It has a decent transient, rich low-end, a tiny bit of noise, and harmonic overtones, so you can hear it on smaller speakers. The problem? It¡¯s so overused that I honestly wouldn¡¯t recommend using it anymore (except you want to sound exactly like everyone else). However, we wouldn¡¯t make this post without offering a great alternative or more precisely: 20 FREE alternatives. That said, we got ourselves a copy of the infamous DJ Spinz 808, dragged it into Ableton, listened carefully, and eventually came up with 20 one-shot samples, which all have quite similar sound characteristics. The best parts? They haven¡¯t been used in thousands of beats yet, so you can use them with a clear conscience + they¡¯re all normalized and tuned to C so you can go through them in your mix without having to change your sampler¡¯s pitch all the time. Details Genres: Trap & Hip Hop License: Royalty-Free Size: 17.4 MB Files: 20 https://bvker.com/free/ |
