| É豸ÀàÐÍ | É豸ÐͺŠ| É豸Ãû³Æ | ¼¼Êõ²ÎÊýÒªÇó£¨ÔÊÐíϸ΢µÄºÏÀíÆ«²î£© | ÊýÁ¿ | µ¥Î» |
| 1 | ʰÒôÉ豸 | Nuemann U87Ai | ´óÕðĤµçÈÝ»°Í² | ÉùÒô¹¤×÷ÔÀí:ѹÁ¦Ìݶȴ«¸ÐÆ÷
Ö¸ÏòÐÔ:È«ÏòÐÔ£¬ÐÄÐÍ£¬8 ×ÖÐÍ
ƵÏì:20Hz-20KHz
ÁéÃô¶È£¨1KHz-1KOHM£©:20/28/22mVPa
Êä³ö×迹:200ohms
¸ºÔØ×迹:1000ohms
ÁéÃô¶È£¨CCIR486-3£©:26/23/25dB-A
ÁéÃô¶È£¨DIN/IEC 651£©:15/12/14dB-A
S/N ±È£¨CCIR 486-3£©:68/71/69dB
S/N ±È£¨DIN/IEC 651£©:79/82/80dB
½Ï´óÉùѹ¼¶£¨THD СÓÚ 0.5%£©:117dB(ÐÄÐÍ)
½Ï´óÉùѹ¼¶£¨THD СÓÚ 0.5%,Ԥ˥¼õ£©:127dB
½Ï´óÊä³öµçѹ:390Mv
Âó¿Ë·ç´«¸ÐÆ÷£¨DIN/IEC651£©¶¯Ì¬·¶Î§ :105Db
µçѹ:48v+4V µçÁ÷:0.8mA ½ÓÍ·:XLR 3F ÖØÁ¿:500 ¿Ë Ö±¾¶:56 ºÁÃ×
³¤¶È:200 ºÁÃ× | 2 | Ö§ |
| 2 | | Neumann M 149 | ÐÄÐÍÖ¸ÏòµçÈÝ»°Í² | ÉùÒô²Ù×÷ÔÀí£ºÑ¹Á¦Ìݶȴ«¸ÐÆ÷
Ö¸ÏòÐÔ£ºÐÄÐÍ
ƵÏ죺20Hz-20KHz
ÁéÃô¶È£¨ 1KHz-1Kohm £©£º21mV/Pa
Êä³ö×迹£º50ohms
¸ºÔØ×迹£º1000ohms
Áé Ãô ¶È £¨ CCIR 468-3 £©£º17.5dB
Áé Ãô ¶È £¨ DIN/IEC 651 £©£º7dB-A
S/N ±È £¨ CCIR 468-3 £© £º 76.5dB
S/N ±È £¨ DIN/IEC 651 £© £º 87dB
×î´óÉùѹ£¨ THD СÓÚ 0.5% £©£º 138dB
×î´óÊä³öµçѹ£º13dBu
´«¸ÐÆ÷¶¯Ì¬·¶Î§£¨DIN/IEC 651£©£º131dB
µçѹ£º48+4V
µçÁ÷£º3mA
¼Òô»°Í²½ÓÍ·£ºXLR3F
ÖØÁ¿£ºÔ¼500¿Ë
Ö±¾¶£º 60ºÁÃ×
³¤¶È£º132 ºÁÃ× | 2 | Ö§ |
| 3 | | Neumann TLM103 | µç×ӹܻ°Í² | ÉùÒô²Ù×÷ÔÀí£ºÑ¹Á¦Ìݶȴ«¸ÐÆ÷
Ö¸ÏòÐÔ£ºÈ«Ïò£¬°ëÇòÐÍ£¬ÐÄÐÍ£¬¹ýÐÄÐͺÍ
8 ×ÖÐÍ
ƵÂÊ·¶Î§£º20Hz-20KHz
ÁéÃô¶È£º34/37/62Mv/Pa*
Êä³ö×迹£º50ohms
¸ºÔØ×迹£º1000ohms
ÁéÃô¶È£¨CCIR 468-3£©£º28/25/23dB*
ÁéÃô¶È£¨DIN/IEC 651£©£º16/13/11dB*
ÐÅÔë±È£¨CCIR 468-3£©£º66/69/71dB*
ÐÅÔë±È£¨DIN/IEC 651£©£º78/81/83dB*
Éùѹ¼¶£¨µç×Ó¹ÜÌØÐÔ£©£º
СÓÚ 0.5%THD(<5%THD)£º120£¨136£©dB
½Ï´óÊä³öµçѹ£º18dBu Âó¿Ë·ç´«¸ÐÆ÷¶¯Ì¬·¶Î§£º
DIN/IEC 651£¨Ð¡ÓÚ 0.5% THD£©£º101£¨121£© dB
µçÔ´£ºµçÔ´¹©Ó¦ N149A
Âó¿Ë·çÁ¬½Ó£ºDIN 8F
Âó¿Ë·çÁ¬½ÓµçÔ´£ºXLF 3F ÖØÁ¿£º730 ¿Ë | 1 | Ö§ |
| 4 | AKG C414XLS | ¶àÖ¸ÏòµçÈÝ»°Í² | ÒôƵ´ø¿í£º20 - 20000 Hz
µÈЧÔëÉùµçƽ£º6 dB-A
ÁéÃô¶È£º23 mV/Pa
ÐÅÔë±È£º88 dB-A
ǰÖÃË¥¼õÆ÷£º-6¡¢ -12¡¢-18dB
µÍÒôË¥¼õÂ˲¨Æ÷£º160; 80; 40 Hz
×迹£º200 Ohms
ÍÆ¼ö¸ºÔØ×迹£º2200 Ohms
Ö¸Ïò£ºÈ«Ïò/¿íÐÄÐÍ/ÐÄÐÍ/³¬ÐÄÐÍ/°Ë×ÖÐÍ
µçѹ£º44 ÖÁ 52 V µç Á÷ £º4.5 mA ÀàÐÍÆ½ºâ XLR
´¥ µã 3 Õë ³¤ ¶È £º38 mm ¿í ¶È £º50 mm ¸ß¶È£º160 mm
¾»ÖØ£º300 g | 2 | Ö§ |
| 5 | | PLATANE Scallion | СÕðĤµçÈÝ»°Í² | СÕðĤµçÈÝ»°Í²
ÕðĤ³ß´ç: 12mm (@ 3um)
Ö¸Ïò: ÐÄÐÍ
ƵÂÊÏìÓ¦·¶Î§: 18Hz-20kHz
ÁéÃô¶È@1KHz: -33dBV¡À1dB (-54dB @ 180¡ã)
×î´óÉùѹ¼¶: 132dB
Ê§Õæ: <0.5%
Âö³åÏìÓ¦: 11us
Êä³ö×迹: <200 ohms
¹¤×÷»·¾³: 10-40¡ãC & R.H.<85%
Á¬½Ó·½Ê½: XLR-3
µçѹ: 48V phantom power | 4 | Ö§ |
| 6 | SENNHEISER MD 421-II | ¶¯È¦»°Í² | Ö¸ÏòÐÔ£ºÐÄÐÍ
ƵÏ췶Χ£º30Hz£17KHz
ÁéÃô¶È£º(1kHz)2mV/Pa+3dB
Õý³£×迹£º200¦¸
×îµÍÖÕ¶Ë×迹£º200¦¸
³ß´ç(mm)£º215¡Á46¡Á49 | 2 | Ö§ |
| 7 | Shure SM57 | ¶¯È¦ÀÖÆ÷»°Í² | ´«¸ÐÆ÷ÀàÐÍ: ¶¯È¦
ʰÒôģʽ: ÐÄÐÎ
ƵÂÊÏìÓ¦×Ô: 40 Hz
ƵÂÊÏìÓ¦ÖÁ: 15 KHz
ÁéÃô¶È (dBV/Pa): -54,5 dBV/Pa
ÁéÃô¶È (mV/Pa): 1,88 mV/Pa | 4 | Ö§ |
| 8 | Shure PGADRUMKIT 7 | ¹Ä×黰ͲÌ××° | ÊÖÌáÏä 1 ¸ö
µ×¹Ä¶¯È¦»°Í² 1 Ö§£º
³ß´ç£º60x153mm
½Ó Í· £ºXLR-3
ƵÏ죺20-16000Hz
ÖØÁ¿£º318g
×ÔÓɳ¡ÖеÄÁéÃô¶È£ºÎÞ¸ºÔØ£¨1kHz£©
0,25mV/Pa;(50Hz£©0£¬9mV/Pa
±ê³Æ×迹£º350¦¸
×îСÖÕ¶Ë×迹£º1000¦¸
¾ü¹Äà̹Ķ¯È¦»°Í² 4 Ö§
»»ÄÜÔÀí (»°Í²)£º¶¯È¦Ê½Ê°Òô·½Ê½£ºÐÄÐÍ
ƵÂÊÏìÓ¦ (»°Í²)£º40-18000 Hz
×ÔÓɳ¡£¬¿ÕÔØÊ±µÄÁéÃô¶È£º (1kHz)1,8 mV/Pa
×迹£º350 ¦¸
½ÏСÖÕ¶Ë×迹£º1000 ¦¸
Á¬½ÓÍ·£ºXLR-3
³ß´ç£º 33 x 59 mm ÖØÁ¿£º 60 g
ïïÆ¬µçÈÝ»°Í² 2 Ö§
»°Í²»»ÄÜÔÀí Ô¤¼«»¯µçÈÝ»°Í²Ö¸ÏòÌØÕ÷ ³¬ÐÄÐÎ
ƵÂÊÏìÓ¦ 40 Hz-20 kHz
×ÔÓɳ¡ÁéÃô¶È£¬ÎÞ¸ºÔØ£¨1kHz£© 3 mV/Pa =
- 50dB (0 dB = 1 V/Pa)
¶î ¶¨ ×è ¿¹ 350 ¦¸ ×îµÍ¸ºÔØ×迹 1000 ¦¸ ×î´óÉù¼¶Ñ¹£¨ÎÞÔ´£©
139 dB/SPL µÈЧÔëÉùµçƽ24 dB(A£©
°´ CCIR 468-3 ¼ÓȨµÄµÈЧÔëÉùµçƽ
35 db | 1 | Ì× |
| 9 | | Tegeler Audio Vari Tube VTRC | µç×Ó¹ÜͨµÀÌõ | µç×ӹܻ°·Å£¨3 Ö»µç×ӹܣ©
A Àà·Å´óµç·
ƵÂÊÏìÓ¦£º20 - 20.000 ºÕ×È+/- 1,5dB ±äѹÆ÷ƽºâÊäÈëºÍÊä³ö
»·ÐαäѹÆ÷ÄÚ²¿µçÔ´
Vari-¦ÌѹËõÆ÷£¨¹âµçºÍ¿É±äѹËõÆ÷¿ÉÒÔͬʱʹÓã©
ÓжÀÁ¢µÄÏß·ÊäÈë±äѹÆ÷Ïß·ÊäÈëÁ½¸ö VTRC ¿ÉÁ¬½ÓÁ¢ÌåÉù²Ù×÷EQ£º24kHz ÌáÉý¸ßƵÂÊµÄ¿ÕÆø¸Ð Çл»Ñ¹ËõÆ÷ʱ¼ä
±»¶¯ Pultec ·ç¸ñ EQ
Âó¿Ë·çǰÖ÷ŴóÆ÷£¬Ï¸½Ú¿ÉÒԴӸɾ»µ½·Ê׳
EQ ÔÚѹËõÆ÷֮ǰ»òÖ®ºó¿Éµ÷
¾ùºâÆ÷¿ÉÒÔÇл»µ½Ñ¹ËõÆ÷µÄ²àÁ´ | 1 | ̨ |
| 10 | »°·ÅµÈÖܱßÉ豸 | Heritage audio DMA73 | ˫ͨµÀ»°Í²·Å´óÆ÷ | »°Í²ÊäÈë×迹£ºHI 1200Ohm ×îС£¬LO 300Ohm ×îС
ÏßÐÔÊäÈë×迹£º10K Ohm ÇŽӣ¬Carnhill
±äѹÆ÷
DI ÊäÈë×迹£º´óÓÚ 2 Megohms£¨Õ×Å·Ä·£©£¬ ·Çƽºâ
Êä³ö×迹£º СÓÚ 75Ohms
×î´óÊä³ö£º´óÓÚ+26dBm£¨600ohms£© THD£¨×Üг²¨Ê§Õ棩£ºÐ¡ÓÚ 0.025% @1Khz£¬ СÓÚ 0.05% @ 100Hz
ƵÂÊÏìÓ¦£º20Hz ( +0.3dB ) to 20Khz (-0.2dB)
×î´óÔöÒæ£º´óÓÚ 80dB
ÔëÉù£ºÐ¡ÓÚ -100dBm
µçÔ´£º88 mA per rail @+-16VDC. | 1 | ̨ |
| file:///C:\Users\ADMINI~1\AppData\Local\Temp\ksohtml\clip_image4.png11 | | Tegeler Audio Classic Equalizer EQP-1 | Á¢ÌåÉù¾ùºâÆ÷ | ˫ͨµÀµç×Ó¹Ü EQ
µÍƵ¸é¼ÜʽÔöÇ¿/Ë¥¼õƵÂʵ㣺20Hz, 30Hz, 60Hz, 100Hz
¿É±äÔö񾮵µã£¨¿É±ä´ø¿í£©£º
3kHz, ,4kHz, ,5kHz, 6kHz, 8kHz, 10kHz, 12kHz, 16kHz, 20kHz
¸ßƵ¸é¼Üʽ˥¼õƵÂʵã: 5kHz, 10kHz, 20kHz
ƽºâʽÊäÈëÊä³ö
ÊäÈëÊä³ö¾ù²ÉÓñäѹÆ÷ÉèÖà | 1 | ̨ |
| 12 | Tegeler Audio Vari Tube VTRC | Á¢ÌåÉùĸ´øÑ¹ËõÆ÷ | µç×Ó¹Ü×ÜÏßĸ´ø EQ ѹÏÞ´¦ÀíÆ÷Á¢ÌåÉùÊäÈëÊä³ö
¾ùºâÆ÷ÓëѹËõÆ÷ǰºóÁ´¿ÉÇл»µÍÇÐÂËÆ÷ÅÔÁ´¹¦ÄÜ
EQ£º±»¶¯ EQ£¨Pultec ·ç¸ñ£© ĸÏßѹËõÆ÷
ƵÂÊÏìÓ¦£º20 - 40.000 ºÕ×È+/-1.5 dB µÄ
ƽºâÊäÈëºÍÊä³ö | 1 | ̨ |
| 13 | Bricasti Design M7 | ¶¥¼¶»ìÏìÆ÷ | Ó²ÌåÉè¼ÆÌØÐÔ Ë«¶ÀÁ¢µçÔ´¹©Ó¦
רΪÀà±Èµç·Éè¼ÆµÄ¶ÀÁ¢»·ÐαäѹÆ÷ רλÊýλµç·Éè¼ÆµÄ¸ß±íÏÖÇл»Ê½±äѹÆ÷
ÊýλÓëÀà±ÈÄ£×é·ÖÀ뿹¸¯Ê´²»Ðâ¸ÖÍâ¿Ç
Ãæ°å¡¢ÐýÅ¥ÒÔ¼°°´¼ü²Éµç¶ÆÂÁ¿Ç´¦Àí
Postive feel 2 db ²¦¶ÎʽÀà±ÈÊäÈë¿ØÖÆMIDI I/O | 1 | ̨ |
| I/O Êý×ÖÒôƵ½Ó¿Ú | Antelope Orion32 HD GEN3 | ÒôƵ½Ó¿Ú | Ä£Ä⣺ģÄâÊäÈë
4 x D-SUB 25£¨¹² 32 ͨµÀ£©, ×î¸ß+24 dBu, 11.2 kOhms
Ä£ÄâÊä³ö 4 x D-SUB 25 ¹² 32 ͨµÀ£©,
×î¸ß+24dBu£¬56 Ohms 2 x TRS ¼àÌýÊä³ö A/D ת»»
¶¯Ì¬·¶Î§: 124 dB THD + N: -112 dB D/A ת»»£¨¼àÌýÊä³ö£© ¶¯Ì¬·¶Î§: 136 dB THD + N: -112dB
D/A ת»»£¨Ïß·Êä³ö£© ¶¯Ì¬·¶Î§: 129 dB THD + N: -120 dB
1 x MADI ¹âÏË (×î¸ß 64 ͨµÀ) 2 x ADAT (×î¸ß 16 ͨµÀ) 1 x S/PDIF
Êý×ÖÊä³ö 1 x MADI ¹âÏË (×î¸ß 64 ͨµÀ) 2 x ADAT (×î¸ß 16 ͨµÀ) 1 x S/PDIF USB I/O
USB 3.0 ¨C 64 ͨµÀ I/O£¬×î¸ß 192kHz, USB 3.0 Type B ½Ó¿Ú 2 x mini HDX ½Ó¿Ú, Ö§³ÖÓë Protools Á¬½Ó,
ÿ¸ö½Ó¿ÚÌṩ 32 ͨµÀ I/O £¨¹² 64 ͨµÀ£© Word Clock ×ÖʱÖÓÊäÈë 1 x BNC@75 Ohms 3Vpp£¬32 ¨C 192kHz Word Clock ×ÖʼÖÕÊä³ö
2 x BNC@75 Ohms 3Vpp£¬ 32 ¨C 192kHz Atomic Ô×ÓÖÓÊäÈë 1 x BNC@ 75 Ohms 1Vpp£¬10M
ʱÖÓУ׼ < +/-0.001 ppm
²ÉÑùƵÂÊ 32, 44.1, 48, 88.2, 96, 176.4, 192 (kHz) | 1 | ̨ |
| | | Apple Mac pro | ÒôƵ¹¤×÷Õ¾ | 3.5GHz 8 ºË Intel Xeon W ´¦ÀíÆ÷£¬Turbo Boost ×î¸ß¿É´ï 4.0GHz
96GB (6x16GB) DDR4 ECC ÄÚ´æRadeon Pro 580X ͼÐδ¦ÀíÆ÷£¬Å䱸 8GB
GDDR5 ÏÔ ´æ 2TB ¹Ì̬ӲÅÌ
²»Ðâ¸Ö¿ò¼ÜÅäÖ§½ÅÃî¿ØÊó±ê 2
´øÓÐÊý×ÖС¼üÅ̵ÄÃî¿Ø¼üÅÌ - ÖÐÎÄ (Æ´
Òô) | 1 | ̨ |
| 16 | DAW ¹¤×÷Õ¾²¿·Ö | Æ·ÅÆ | 27 ´çרҵÏÔʾÆ÷ | ÆÁÄ»³ß´ç 27 Ó¢´ç×î¼Ñ·Ö±æÂÊ 1920x1080 ÆÁÄ»±ÈÀý 16:9£¨¿íÆÁ£©
¸ßÇå±ê×¼ 1080p£¨È«¸ßÇ壩
Ãæ°åÀàÐÍ IPS
±³¹âÀàÐÍ LED ±³¹â | 2 | ̨ |
| 17 | | Avid Pro Tools HDX | ÒôƵ²É¼¯¿¨ | DSP ÔËËãÒôƵ½Ó¿Ú¿¨·¢ÒôÊý£º256
ÒôƵ¹ìµÀ£º256 ÑÓ³Ù£º¡Ü0.7 ºÁÃëI/O ͨµÀ´¦Àí£º¡Ý64
×Ô¶¯ÑÓ³Ù ²¹³¥ (ADC)£º16,383 ¸öÑù±¾´¦ÀíÉî¶È£º¡Ý32 ±ÈÌØ¸¡µã
»ìÒôÆ÷Éî¶È£º¡Ý64 ±ÈÌØ¸¡µãÖ§³Ö Protools HD Èí¼þ
Ö§³Ö 64 λ AAX DSP ²å¼þ | 1 | ÕÅ |
| 18 | Avid Pro Tools Ultimate | ¼ÒôÖÆ×÷Èí¼þ | DAW ÒôƵ¹¤×÷Õ¾Èí¼þ
×î´óÊýÁ¿Í¬²½ÒôƵ¹ìµÀ£¨48/96/192 kHz£©£º
384/192/96
Í¬Ê±Â¼ÖÆ×î´óÊýÁ¿ÒôƵ¹ìµÀ£º256 ÀÖÆ÷¹ì£º256
MIDI ¹ì £º512 Aux ¹ì £º512 ×ÜÏߣº256
Ö§³Ö 64 ¸öÊÓÆµ¹ìµÀ
Ö§³ÖµÄ×î´ó²ÉÑùÂÊ£º32bit/192 kHz Ö§³Ö 64 λ AAX DSP ºÍ AAX Native ²å¼þ | 1 | Ì× |
| 19 | Avid ÊÚȨ | ÊÚȨ | Ö§³ÖµÚÈý·½ I/O É豸ÊÚȨ | 1 | Ì× |
| 20 | iLok | ¼ÓÃܹ· | ¿É´æ´¢¶à´ï 1,500 ¸öÈí¼þºÍ²å¼þÊÚȨ ¼á¹ÌµÄÂÁÖÆÍâ¿ÇºÍÝ^Ç¿µÄ°²È«»·È·±£¸üºÃµÄ°²È«ÐÔ
ͨ¹ý¸üС£¬¸ü±¡µÄÉè¼Æ½ÚÊ¡¿Õ¼ä-ÏÖÔÚ½öΪ
1.5 x .5 Ó¢´ç£¨3.8 x 1.3 ÀåÃ×£© ʹÓà iLok Ðí¿ÉÖ¤¹ÜÀíÆ÷ͨ¹ý¼òµ¥µÄÍÏ·Å
¼´¿ÉÌí¼ÓºÍ×ªÒÆÐí¿ÉÖ¤
ÇáËɽ«Èí¼þÊÚȨ´Óһ̨¼ÆËã»ú×ªÒÆµ½Áíһ̨¼ÆËã»ú | 1 | Ì× |
| 21 | Waves Diamond | ÉùЧ²å¼þ°ü | ½áºÏ×ÛºÏÐÔÒôЧ´¦Àí¹¤¾ßÓÚÒ»ÉíµÄ
Diamond Èí¼þ£»
Ϊ¹¤×÷ÊÒÌṩÎÞ¿ÉÆ¥µÐµÄÐźŴ¦ÀíÁ¦Á¿£» °üÀ¨Â¼Òô»ìÒô¡¢Ä¸´øºóÖÆ¡¢´´ÒâÒôЧÉè¼Æ¡¢ÒÔ¼°ÒôЧ»¹Ô£»
ÄÚº¬ MaxxVolume, Q-Clone, Waves Tune LT, L3 Multimaximizer, L3-LL Multimaximizer, IR-L Convolution Reverb ÒÔ¼°ÔÚ Wave Platinum¡¢Restoration¡¢Transform Ì×¼þÖеÄËùÓвå
¼þ£»
¸»º¬¶¯Ì¬´¦Àí¡¢µÈ»¯¡¢²ÐÏì´¦Àí£¬»òÊÇÒô
×¼µ÷Õû¡¢¿Õ¼ä¸Ð¼ÓÈëµÈµÈ | 1 | Ì× |
| 22 | ´óÐÍÊý¿ØÄ£Äâ
µ÷Òǫ̂²¿·Ö | Audient ASP 8024 | µ÷Òǫ̂
¿ò¼Ü | Ϊ¼Òô¿ØÌ¨Éè¼ÆµÄ°²×°¿ò¼Ü
¿ÉÒÔ°²×°ÕûºÏ Ö÷¿Ø¡¢»°·ÅͨµÀ¡¢×ÜÏß¡¢Ë«²ãÍÆ¸Ë¡¢ÍÆ×ÓµÈÄ£¿éÓÚÒ»Ìå
ÓµÓÐ180 ºÁÃ×Éî¶È¿ÉÖ§³Å50kg ÑïÉùÆ÷µÄ¶¥²¿Ö§¼Ü
ÅäÖÃÓа²¾²µÄ¶ÀÁ¢Ë«µçÔ´±¸·Ýϵͳ | 1 | Ïî |
µ÷Òǫ̂
Ö÷¿ØÄ£¿é | Ò»×éÁ¢ÌåÉùÖ÷Êä³öÄ£Äâµç·Ö÷¿ØÄ£¿é
²»ÉÙÓÚ 8 ¸ö¿É·ÖÅäµÄ´Î±à×éÊä³ö ²»ÉÙÓÚ 8 ¸ö´Î±à×éÊä³ö led µçƽ±í
²»ÉÙÓÚ 12 ¸ö Aux ¸¨ÖúÊä³öĸÏߣ¬Ã¿¸öĸÏß¿ÉÒÔµ¥¶À¼àÌý
²»ÉÙÓÚ 2 ¸ö Cue ĸÏߣ¬Ã¿¸öĸÏß¿ÉÒÔµ¥¶À¼àÌý
²»ÉÙÓÚ 24 ¸ö¼Òô±à×éĸÏߣ¬¿É¶Ôÿ¸öĸÏß½øÐÐ 20dB µÄµçƽÐÞÕý
²»ÉÙÓÚ 4 ×éÁ¢ÌåÉùÊäÈë
²»ÉÙÓÚ 8 ¸ö´Î±à×éÊä³öµçƽ±íºÍ¹ýÔØÖ¸Ê¾µÆ
ÅäÖÃÓÐÖ÷Êä³öµçƽ±íºÍ¹ýÔØÖ¸Ê¾µÆ | 1 | Ïî |
µ÷Òǫ̂
»°·ÅÄ£¿é | ¾ßÓÐÒôÀÖÐÔ£¬Á¦Á¿¸ÐÒÔ¼°¸É¾»µÄÐźÅÌØÖÊÿ¸öÄ£¿é¾ùº¬ 12 ¸öͨµÀ£¬ÇÒÿͨµÀ¾ùº¬²»µÍÓÚ 54dB ÔöÒæ·¶Î§µÄ A CLASS ÀàÐÍ»°·Å ƵÂÊÏìÓ¦£º»°Í²ÊäÈë ¡À0.3dB (20Hz to 20kHz with 6 to 40dB gain)
Ïß·ÊäÈë¡À0.3dB (20Hz to 20kHz with 0dB gain)
СÓÚÐźŠ3000 ±¶¼«µÍµÄµ×Ôë
ÎÞ±äѹÆ÷Éè¼Æ¿ÉÒÔÃâÒßÉ䯵ÐźŴøÀ´µÄÔëÉùË«ÏßÊäÈëÉè¼Æ¿É±£Ö¤Ò»¸öͨµÀÌõÉÏͬʱ¾ßÓÐÏß··Å´óÆ÷ºÍ»°Í²·Å´óÆ÷
Áé»îµÄ·ÓÉÉè¼Æ¿ÉÈÃÿ¸öÊäÈëͨµÀ×ÔÓɵķÖÅ䏸×î¶à 48 ¸ö¼ÒôĸÏß
»°·ÅÉϾßÓÐ 4 ¶Î¿É²ð·Ö²ÎÁ¿¾ùºâÆ÷ÿͨµÀÉϾßÓл°·ÅºÍÏß··Å´óÆ÷Á½¸öÔöÒæ
ÐýÅ¥
ÿͨµÀÉϾßÓÐ 14 ¸ö Aux ¸¨ÖúÊä³ö£¬Ã¿¸ö¸¨ÖúÊä³ö¿ÉÑ¡ÔñÍÆ×Óǰºó·¢ËÍ
ÿͨµÀÉϾßÓÐÁ½¸ö Cue ĸÏßÊä³ö£¬¿ÉÇл»ÍÆ×Óǰºó·¢ËÍ
ÿͨµÀÉϾßÓжÀÁ¢µÄƽºâʽ¶Ïµã²åÈë½Ó¿Ú
ºÍ¶Ïµã²åÈ뼤»î¿ª¹Ø
ÿͨµÀÉϾßÓм«ÐÔ·´×ª°´Å¥ ÿͨµÀÉϾßÓÐ 75Hz µÄ¸ßͨÂ˲¨Æ÷
¾ßÓÐË«²ãÍÆ¸ËÉè¼Æ£¬²¢ÇÒÁ½¸öÍÆ¸Ë¿É±»ÇÐ
»»Ê¹Óà | 2 | Ïî |
µ÷Òǫ̂
¶Ô½²Ä£¿é | ´øÓÐÖÁÉÙÒ»¸ö¶ÀÁ¢µÄ¾ßÓжԽ²»°Í²Í¨µÀ ´øÓÐ×Ô¶¯Ë¥¼õÆ÷¿ÉÔÚ¶Ô½²Ê±×Ô¶¯½µµÍ¼àÌýÒôÁ¿
´øÓÐÒ»¸ö¿ÉÒÔµ÷½Ú¶Ô½²»°Í²ÒôÁ¿µÄÐýÅ¥´øÓÐÈý¸ö¶Ô½²»°Í²Êä³ö·Óɰ´Å¥
¿ÉÒÔÍâ½Ó̤°åÒ£¿Ø¶Ô½²°´Å¥ | 1 | Ïî |
µ÷Òǫ̂
¿É±äÒôɫģ¿é | Ä£Äâµç·ѹËõÆ÷
¼¯³ÉÓÚÕûÌåµ÷Òǫ̂Ö÷¿ØÄ£¿éÖпɱäÒôɫģ¿é¾ßÓлìºÏ·Å´óÆ÷Óв»µÍÓÚËÄÖÖģʽ¿Éµ÷½Ú | 1 | Ïî |
µ÷Òǫ̂
ѹËõÆ÷Ä£¿é | ×ÜÏßѹËõÄ£¿é Ä£Äâµç·ѹËõÆ÷
¼¯³ÉÓÚÕûÌåµ÷Òǫ̂Ö÷¿ØÄ£¿éÖРѹËõ±È£º2:1¡¢4:1¡¢10:1 Èýµµ¿Éµ÷
½éÈëʱ¼ä£º0.1¡¢0.3¡¢1¡¢3¡¢10¡¢30ms ¿Éµ÷
ÊÍ·Åʱ¼ä£º0.1¡¢0.3¡¢0.6¡¢1.2¡¢2.4 Ãë ºÍ×Ô¶¯Êͷſɵ÷
ÓµÓÐÒ»¸ö 350Hz ²àÁ´µÄ¸ßͨÂ˲¨Æ÷
ÓµÓÐÒ»¸öÓÃÓÚÊÓ¾õ·´À¡µÄ VU GR ±í | 1 | Ïî |
µ÷Òǫ̂
¸¨Öú×ÜÏßÄ£
¿é | 14 ¸ö Aux ¸¨ÖúÊä³ö£¬Ã¿¸ö¸¨ÖúÊä³ö¿ÉÑ¡ÔñÍÆ×Óǰºó·¢ËÍ
×ÜÏßÊä³ö×ÜÒôÁ¿¿Éµ÷¼àÌýͨµÀÓÐרÃÅÐýÅ¥ | 1 | Ïî |
µ÷
Òô
¼àÌýÄ£¿é | ÓµÓв»µÍÓÚ 4 ×éÁ¢ÌåÉùÊäÈëÔ´Ñ¡Ôñ
ÓµÓв»µÍÓÚ 4 ×éÁ¢ÌåÉùÊä³ö¿ÉÑ¡Ôñ
ÿ¸ö ALT Êä³ö¼àÌýÉ϶¼ÓÐÊä³öµçƽÐÞÕýÐýÅ¥
ÓµÓÐÒ»¸ö±ê×¼ TRS ¶ú»ú¼àÌý½Ó¿Ú¿ÉÒÔµ¥¶ÀÑ¡ÌýÊä³öÉùµÀ
ÓµÓо²ÒôºÍ dim Ë¥¼õÆ÷ ÓµÓÐÇ¿ÖÆµ¥ÉùµÀ¼àÌý°´Å¥ÓÐÈý×é·µËÍÁ¢ÌåÉùÊä³ö
·µËÍÊä³ö¿ÉÑ¡Ôñ²»µÍÓÚ 5 ×éÊäÈëÔ´¿ÉÒÔ¶ÀÁ¢¼àÌýÿ¸ö·µËÍÊä³öͨµÀ
ÓµÓÐÒ»¸öÕýÏÒ²¨·¢ÉúÆ÷£¬ÆµÂÊ 40¡¢1k¡¢10k
ºÍ 15k ¿Éµ÷½ÚSolo ÒôÁ¿¿Éµ÷
ÍÆ×ÓÇ°ÍÆ×Óºó solo ¿Éµ÷
SIP ¿Éµ÷ | 1 | Ïî |
µ÷Òǫ̂
Êý¿ØÄ£¿é | 8 ͨµÀÊý¿ØÄ£Äâ×Ô¶¯»¯Ä£¿éͨ¹ýÍøÂç¿ØÖÆ DAW Èí¼þ
Ö§³Ö Protools,Logic,Nuendo µÈÖ÷Á÷Èí¼þ¶¨ÖÆÇ¶ÈëÖ÷̨
Ä£Äâ/Êý×ÖË«Ä£Ê½ÍÆ×ÓÑ¡Ïî
ͨ¹ý FADERLINK Plug-in ×Ô¶¯»¯¿ØÖÆÄ£Äâ²ãÍÆ×Ó
Ä£ÄâÐźſɻìºÏµ½×ÜÏß
Êý¿ØÄ£Äâ¿ÉÍⲿÊäÈë 8 ͨµÀÄ£ÄâÐźÅÊý¿ØÄ£Äâ¿É»ñÈ¡±à×éͨµÀÐźŠ| 1 | Ïî |
µ÷Òǫ̂
±íÇÅÄ£¿é | Å䱸ÓÐ 24 ¸ö LED ³¤µçƽ±íºÍ 24 ¸ö¶Ìµçƽ±í
×ÜÏß 8 ¸ö LED µçƽ±í ×ÜÒ»×éÁ¢ÌåÉùµçƽ±í ±íÍ·¿ÉÏ໥ת»» | 1 | Ïî |
| 23 | ¼àÌý¿ØÖÆÏµÍ³ | GENELEC 8351B | Èý·ÖƵ¼àÌýÒôÏä | Èý·ÖƵÉùѧͬÖáÖÇÄÜÓÐÔ´ÒôÏä½Ï´óÉùѹ£º113dB
ƵÂÊÏìÓ¦£º32Hz - 43kHz
µ¥Ôª´óС£ºµÍÒô:ÍÖÔ²ÐÎË«µÍƵµ¥Ôª 218¡Á 101 mm ÖÐÒô:5' ¸ßÒô:1' ÖиßÒôͬÖáµ¥Ôª¹¦ÂÊ£ºµÍÒô:250W ÖÐÒô:150W ¸ß
Òô:150W
ÒôÏä³ß´ç£º452 x 287 x 278 mm ÒôÏäÖØÁ¿£º14.3kg
½Ó¿ÚÀàÐÍ£º
1 x XLR Ä£ÄâÊäÈë
1 x XLR AES/EBU Êý×ÖÊäÈë
1 x XLR AES/EBU Êý×ÖÊä³ö
2 x RJ45 ¿ØÖÆÍø¿Ú
ÖÇÄܼ¼ÊõÖ§³Ö£ºSAM & GLM ÉùѧÖÇÄÜУÕý¼¼Êõ | 2 | Ö» |
| 24 | Dynaudio LYD 8 | Á½·ÖƵ¼àÌýÒôÏä | ƵÏ췶Χ:45 Hz - 21 kHz ×î´óÉùѹ¼¶ 1m,ÿ¶Ô:112dB µÍÒôÔÀí:µÍÒô·´Éäʽ
ƵÂÊÏìÓ¦:3900 Hz
¸ßÒôµ¥Ôª:28 mm Ö¯ÎïÈíÇò¶¥µÍÒôµ¥Ôª:8 Ó¢´ç
¹¦·Å:¸ßÒô 50W/µÍÒô 80W D À๦·Å³ß´ç(¿í x ¸ß x Éî):234 x 369 x 328 mm
ÖØÁ¿:12.8 kg
I/O Á¬½Ó¶Ë×Ó:XLR ƽºâ: RCA µ¥¶Ë | 2 | Ö» |
| 25 | Beyerdynamic DT 1770 Pro | ¼Òôʦ¼àÌý¶ú»ú | ´«Ê䷽ʽ: ÓÐÏß¶ú»ú¹¤×÷ÔÀí: ·â±Õʽ
ƵÂÊÏìÓ¦: 5Hz-40,000Hz ×迹: 250¦¸
±ê³ÆÉùѹ¼¶: 102 dBSPL (1mW/500Hz) ¶úµæ½Ó´¥·½Ê½: °ü¶úʽ
¿ØÖƹ¦ÄÜ: ÎÞ¿ØÖƹ¦ÄÜ
½Ó²åÍ·: 3.5mm ¶Æ½ðÁ¢ÌåÉùСÐͲåÍ·¸½´ø6.35mm(1/4)ת½Ó²åÍ·
Åä¼þ: ±ãЯ°ü | 1 | Ö» |
| 26 | SONY MDR-750 | ¸èÊÖ¼àÌý¶ú»ú | ²úÆ·ÀàÐÍ ¶¯È¦¶ú»úÅå´÷·½Ê½ Í·´÷ʽ
ƵÏ췶Χ 10-20000Hz ²úÆ·×迹 63 Å·Ä·
ÁéÃô¶È 106dB ¶ú»úÏß 3m
²úÆ·ÖØÁ¿ 230g | 12 | Ö» |
| 27 | Samson S-Phone 12 | ¶ú·Å´¦ÀíÆ÷ | 4 ×éͨµÀ¶ú»ú»ìÒô/·ÖÅäÆ÷
ÿ¸ö¶ú»úÉùµÀÌṩ 3 ¸ö¶ú»ú²å¿Ú£¬Ç°Ò»ºó¶þ
×î´óÊä³ö¹¦ÂÊ£º32 ŷʱ 140 mW£¬66 ŷʱ
385mW
2 ¶ÔÖ÷Á¢ÌåÉùÊäÈë¿Ú£¬1 ¸öÁ¢ÌåÉùÁ´½ÓÊä³ö¿Ú
×î´óÊäÈëµçƽ£º+26 dBv
Ö÷Á¢ÌåÉùÉùµÀºÍ 4 ¸ö¶ú»úÉùµÀ¾ù´øÓÐ 8 ¶ÎµÄµçƽ±í
ÿ¸ö¶ú»úÉùµÀ¾ùÌṩ¸ß¡¢µÍÁ½¶ÎµÄ¾ùºâÆ÷
ÿ¸ö¶ú»úÉùµÀ¾ùÌṩ´øÉùÏñ¿ØÖƵĸ¨ÖúÊäÈë¿Ú
ÿ¸ö¶ú»úÉùµÀ¾ùÌá¹©ÑÆÒô¿ª¹ØºÍÁ¢ÌåÉù/2 ·µ¥ÉùµÀ¿ª¹Ø
ÿ¸öÉùµÀ¾ùÌṩ´ó¹¦ÂʵĶú»úÐźţ¨²»¹Ü¶ú»úµÄ×迹ÊǶàÉÙ£©
³ß´ç£º 44.5 ¡Á 482.6 ¡Á 217£¬ºÁÃ×
ÖØÁ¿£º2.5 ¹«½ï | 2 | ̨ |
| 28 | Redco Little Red Cue Box | ·µÌý¶ú»ú·ÖÅäÆ÷ | ¶ú»ú·ÖÅäÆ÷
1 ·ÐźÅÊäÈë 2 ·¶ú»úÐźÅÊä³öÿ·¶ú»úÊä³ö¾ù¿Éµ÷½ÚÒôÁ¿
ֱͨÊä³ö´®ÁªÏÂһ·¶ú»ú·ÖÅäÆ÷ | 6 | ̨ |
| 29 | | ÌøÏßÅÌ | 96 ¿×ÌøÏßÅÌDB25 Ô¤Á¬½Ó
¿É»·Í¨£¯°ë»·Í¨±à³ÌBantam ²å¿×
1U ¸ß¶È | 2 | Ö» |
| 30 | | ÌøÏß | ³ÉÆ·ÌøÏßBantam ²åÍ· ³¤£º60 ÀåÃ× 4 о˫½ÊоÏß
±àÖ¯ÆÁ±Î²ã | 16 | ¸ù |
±¾¹«Ë¾ÎªÊµÌå¾ÓªµÄºÏ·¨×¢²á¹«Ë¾£¬ËùÓвɹº¼°ºÏ×÷ÏîÄ¿¾ù¿ÉÇ©ÊðºÏ·¨ÕýʽºÏͬ£¡
±¾¹«Ë¾ÊÛǰ³Ðŵ£ºËù¹©É豸¾ùΪȫÐÂÔ×°Ðлõ£¡¼ÙÒ»·£Ê®£¡±£Ö¤°´³§¼Ò¹æ¶¨Ãâ·Ñ±£ÐÞ£¡
±¾¹«Ë¾ÊÛºó³Ðŵ£º±¾¹«Ë¾Å䱸·Ç³£×¨ÒµµÄÒôƵ¼¼ÊõÍŶӣ¬ÎªÄúÌṩ¼¼ÊõÖ§³Ö·þÎñ£¡
ÀÖ³ÇÊËÏîÄ¿¾Àí£ºÁõÑó µç»°/΢ÐÅ£º13370149101 QQ£º3490029085 ³Ð½ÓÈ«¹ú¼ÒôÅïÏîÄ¿
