Rane XP 2016S À©Õ¹´¦ÀíÆ÷
Upgrade Your MP 2016S Mixer
Want to add stereo metering, EQs, and crossfading capabilities to your Rane MP 2016S rotary DJ mixer? This Rane XP 2016S processor is just what you need. For starters, each of the MP 2016S&££39;s six buses gets its own 3-band equalizer with total kills on each band. Sweetwater DJs love how easy they make carving out sonic space between tracks. Select from A, B, or post-crossfader assignments, and flip between mixes with the XP 2016S&££39;s active crossfader. You can even adjust the contour from smooth blending to sharp enough to satisfy any turntablist.
Rane XP 2016S Processor Expansion Features:
The perfect way to expand the capabilities of your Rane MP 2016S rotary DJ mixer
3-band isolator equalizers on each bus provide a range from +6dB to total kill
Assign each bus to either side of the crossfader or post crossfader
Replaceable active crossfader includes smooth to extremely sharp contour control
10-segment LED meter lets you keep an eye or your stereo or cue/program levels
Get more from your MP 2016S rotary DJ mixer with a Rane XP 2016S processor!
Tech Specs| Channels | 6 | | Crossfader | Replaceable | | EQs | 3-band with kills | | Rackmountable | Yes | | Width | 19" | | Depth | 5.3" | | Height | 5.25" | | Weight | 11 lbs.
