Warm Audio EQP-WA ¾­µä¾ùºâÆ÷
EQP-WAÊÇÖøÃûµÄPultec EQP-1A·ç¸ñµÄ¾ùºâÆ÷£¬²ÉÓÃÁ˸úԭʼÉ豸һÑùµÄ¸ßµçѹµç×Ó¹ÜÔöÒæ£¬Ê¹ÓÃCineMagÊäÈëºÍÊä³ö±äѹÆ÷¡¢CineMag¸ÐÓ¦Æ÷¡¢Tung Sol¸ß¶ËÍâÖõç×ӹܣ¨12AX7ºÍ12AU7£©¡£
ÆäÉùÒô·Ç³£¾ßÓÐÒôÀÖÐÔ£¬µÃµ½Ï¸½Ú·á¸»¶øÆµÂÊÆ½»¬µÄÉùÒô£¬ÈÃÉùÒô¸üÉú¶¯¡£
EQP-WAÔÚPultec EQP-1AµÄ»ù´¡ÉϼÓÈëÁ˼¸¸öÐÂµÄÆµ¶Î£¬±ÈÈç200¡¢400¡¢800ÕâÈý¸öÖÐµÍÆµ£¬»¹ÓÐ3kHzºÍ4kHz¸ßÇС£
Euphonic Sonics
What if you could juice your tracks with massive bass, shimmering air, and addictive warmth - without having to shell out a fortune? Well, now you can, with the Warm Audio EQP-WA. A Pultec-style 2U rackmount tube equalizer, the EQP-WA rocks the look and feel of the classic original that graced countless hits. But with its fully discrete circuitry and top-drawer components such as CineMag transformers and premium tubes, it also nails those elusive euphonic sonics that make your recordings come alive. Add luster and brilliance to your music, affordably, with the Warm Audio EQP-WA.
Top-tier performance - and a stunning value
At Sweetwater, we&££39;re all about performance and value, and that&££39;s what the EQP-WA gives you. Top-notch performance, in fact, and incredible value. The EQP-W lets you shape your tracks with an exciting, vibey warmth that makes any vocal or instrument sound, well, gorgeous, and sit proud in the mix. We dig the Warm Audio EQP-WA, and - especially considering its gentle pricetag - we&££39;re confident you will, too!
Warm Audio EQP-WA Features at a Glance:
Tube Equalizer based on the classic "Pultec" EQP-1A
Genuine CineMag input and output transformers
Premium high-voltage 12AX7 and 12AU7 tubes
CineMag inductor EQ section
EQ bypass - signal still passes through tubes and transformers for warming enhancement
No insertion loss - loss restored by tube amplifier
XLR and TRS transformer-balanced inputs
XLR and TRS transformer-balanced outputs
Flat frequency response from 20Hz-50kHz
Boost and Cut controls can be used simultaneously for classic "phase" effect
Low-frequency boost (up to 12dB) at 20, 30, 60, 100, 200, 400, and 800Hz
Low-frequency cut (up to 18dB) at 20, 30, 60, 100, 200, 400, and800Hz
High-frequency boost (up to 18dB) at 3, 4, 5, 8, 10, 12, and 16kHz
High-frequency cut (up to 14dB) at 3, 4, 5, 10, and 20kHz
Five added frequency points for greater flexibility
Switchable 115-/230-volt IEC power inlet
2U rackmount chassis
Juice your tracks with the Warm Audio EQP-WA!
Tech Specs
TypeTube
Number of Channels1
TubeYes
BypassYes
Inputs1 x XLR, 1 x 1/4"
Outputs1 x XLR, 1 x 1/4"
Rack Spaces2U
Boost/Cut Range+18dB/-14dB
Frequency Response20Hz-50kHz
Height3.5"
Depth6"
Width19"
ÆÀÂÛÁÐ±í£¨4£©
:victory: :lol :victory:
2008-11-20 00:02:42 »Ø¸´
:victory: :victory: :victory: :victory:
2008-11-24 15:10:01 »Ø¸´
Warm Audio EQP-WA ¾­µä¾ùºâÆ÷   ,ѧϰÀ´ÁË:victory:
2008-11-25 23:03:39 »Ø¸´
:victory: ÐÀÉÍÖÐ:victory:
2008-11-26 15:00:02 »Ø¸´
