  • honet  2022-11-27 19:50
    Symphonic Distribution 100 Dark Room Techno Kicks
    100 Dark Room Techno Kicks for your next techno Banger. All kick sounds are mastered and optimized for stadium techno sound. Also all these kicks fit excellent for Hard Dance, Acid, Minimal, or any other subgenres. Produced by Yoodza. http:// yoodza.com The Pack contains: • 100 Dark Room Techno Kicks. • Type: One Shots • Format: wav 44100/24bit • Mastered. *Other genres that this package may be useful in: • Hard Dance • Drum & Bass • Electro-House • House • Tech-House • Acid Techno
    官网:https://bit.ly/3XlKikI
    下载
    peeplink.in/5e5fd946e17b
  • honet  2022-11-27 19:38
    Maxx Claster eJ VSTi v1.2-BEAT
    eJ 是一个 FM 合成器。
    特点:
    6 个操作员,每个操作员都有自己的 ADS 包络发生器。
    ADSR 振幅 EG。
    带 LFO 和 ADS 包络的共振 LP/HP 滤波器。
    3 种效果:合唱、回声和 6 段均衡器。
    450 个预设。
    官网: https://www.kvraudio.com/product/ej_by_maxx_claster
    • honet  2022-11-27 19:30
      Soundiron Voltage Bass KONTAKT 音色
      Voltage Bass is a four stringed electric bass guitar with hot pickups, wide tonal range, and a versatile sound ready for any genre of music. We put it through its paces, sampling 30 notes of fingered sustains, palm mutes, picked palm mutes, picked chokes, and harmonics with up to six velocity layers and eight round robin. We captured E1 to C#4 with a mic’d amp for steel character and beefy flavor, and direct line in for a transparent clean tone perfect for adding your own amps and effects.
      This low-end legend is rounded out by 20 ambient pads, synth sustains, staccatos, and a powerful FX rack so you can dial in your new favorite bass preset, create a practice track for your band, or compose an epic rock musical. You can also utilize our advanced options like the velocity range limiter and legato to get even finer control. For your next project, grab Voltage Bass… The results will shock you!
      CONTENTS
      The Kontakt interface includes a suite o ...查看全文
      • honet  2022-11-27 16:36
        Soulful House WAV-FANTASTiC 采样包
        Concept Samples 的“Soulful House”包含一系列 Leads、Chords、Strings、Drums 等等。此包是为 House、Soulful House、Dance 等制作人开发的,使用当今可用的一些最好的精品设备录制而成。
        该合集提供了一系列高品质声音,使用一系列外置设备开发和录制,并通过 Apogee Symphony AD/DA 进行处理。在里面你会发现大量独特的材料,将你的作品提升到一个全新的水平。只需将任何声音拖放到您的 DAW 中,然后开始创建独特的模拟风格音轨,这将接管世界并帮助您获得所需的位置。
        产品详细信息:
        • 98 个循环和采样
        • 100% 免版税
        • 24 位/96kHz
        官网
        https://bit.ly/3GOQegq
        下载:
      • honet  2022-11-27 16:29
        ACM8625/ACM8628/ACM8622 I2S输入内置DSP数字功放IC系列
        ACM8625/ACM8628/ACM8622 I2S输入内置DSP数字功放IC系列助推音频产品升级迭代
        引言随着科技地不断发展和进步,大家对音质听感上也有更高的追求,音乐能让生活充满激情也可以让紧张的心情得到放松,在生活中有很大的作用,是文化的延续。不管是听歌还是看电视,音响都起到了非常重要的作用。音响是将音频信号转换放大声音的一种设备。音响体内自带功率放大器,对音频信号进行放大处理后由音响本身放出声音,使声音放大,音响音质的好坏会直接影响音乐的品质。近几年越来越多的音频厂家选择从模拟输入功放升级到I2S数字功放,例如高性能Soundbar产品、大屏电视、车载音频、蓝牙音箱等,工程师越来越倾向于用数字功放。I2S输入数字功放芯片有以下优势:
        (1) 底噪超小。数字功放芯片因音频信号传输过程中不受干扰,底噪比模拟功放本身小很多。
        (2) 走线简单,外围少。绝大多数的底噪大,有杂音等问题都来源于PCB走线或者器件干扰,很多板子因面积结构限制无法很好的规避干扰;数字功放不容易受外围的干扰,无需担心分地不当,没有PCB走线的 ...查看全文
      • honet  2022-11-27 15:55
        鼓音源Native Instruments West Africa中东/非洲/拉丁打击乐音色
        • 1624960151_img-packshot-west-africa-product-finder-v2-fa998725f0bb0408338462d9fc.jpg
        西方和非洲拥有一系列精美采样的打击乐器和旋律乐器,可单独演奏或作为具有高度鼓舞人心的预编程模式的可定制合奏。所有打击乐器的节奏也可以通过内置的音序器轻松编辑,以即时创建复节奏凹槽。
        对于当代和传统音乐制作人来说,这款乐器确实是一个了不起的更新。
        独特的乐器
        聚焦系列:西方和非洲具有打击乐器,包括 djembe、dunun 和铃铛,可在合奏中使用。另外包括葫芦和 krin,它们可以用作独奏乐器。高音乐器再现了 kora、ngoni、bolon、balafon 和 fula 长笛的独特旋律。
        每个乐器的声音都经过仔细的高细节采样,并且可以在音高乐器的传统音阶和半音阶之间切换。WEST AFRICA 是一款真实且易于使用的工具,用于用永恒的传统声音制作现代节奏。
        即时多节奏
        西方和非洲音乐的根源涉及许多乐器一起演奏以产生复杂的多节奏结构。SPOTLIGHT COLLECTION系列:西方和非洲只需按一下播放按钮,即可轻松重现传统合奏。
        随附的 74 种预编程合奏模式让您可以立即访问令人惊叹的节奏和旋律,使用一个键轻松触发,而另一个键触发额外的独奏、填充和单击。打击乐模式也可以通过基于视觉模式的音序器和凹槽控制进行 ...查看全文
