Loopback Mac Ç¿´óµÄÒôƵ²¼Ïß¹¤¾ß
תÌû
Loopback MacÆÆ½â°æÊÇÖªÄúÍøËѼ¯µ½µÄMac osϵͳÉÏÒ»¿î¿ÉÒÔ´´½¨ÐéÄâÒôƵÉ豸µÄ¹¤¾ß£¬´ÓÓ¦ÓóÌÐòºÍÒôƵµÄÊäÈëµÄÉ豸´´½¨ÐéÄâÒôƵÉ豸µÄÉùÒô£¬È»ºó½«Æä·¢Ë͸øÒôƵ´¦ÀíÓ¦ÓóÌÐò¡£Loopback »á¸øÁËÄãÒ»¸ö¸ß¶Ë¼Òô¹¤×÷ÊÒ¡£
Loopback for MacÆÆ½â°æ¹¦ÄܽéÉÜ
1¡¢½áºÏÒôƵԴ
À´×Ô¶à¸öÔ´µÄÅäÖÃÒ»¸öÐéÄâÒôƵÉ豸ÊÇÈÝÒ׵ġ£Ö»ÐèÌí¼ÓÎïÀíÒôƵÉ豸Ҫ°üÀ¨ÒôƵԴ±í¿ªÊ¼Ó¦Óá£
2¡¢¿ÉÓõÄϵͳ
ÄãµÄMac»á»ØË͵ÄÐéÄâÉ豸ÍêȫһÑùµÄÎïÀíÉ豸¡£ÕÒµ½ËûÃÇÁÐÔÚϵͳƫºÃÆäËûÉ豸֮¼ä»òÑ¡ÔñÔÚÈκÎÒôƵӦÓóÌÐòµÄÊäÈë»òÊä³ö¡£
3¡¢·¢ËÍÒôƵӦÓóÌÐòÖ®¼ä
»·Ò²¿ÉÒÔͨ¹ýÉ豸£¬½«ÒôƵ´ÓÒ»¸öÓ¦ÓóÌÐòµ½ÁíÒ»¸ö¡£ÉèÖû·»ØÉ豸×÷ΪÊä³öÔÚÒ»¸öÓ¦ÓóÌÐò£¬ÊäÈëÁíÒ»¸öʹÒôƵÁ÷Ö®¼äµÄÖ±½ÓÓ¦Óá£
Loopback for MacÆÆ½â°æ¹¦ÄÜÌØÉ«
1¡¢Èκι¤×÷ÖеÄÓ¦ÓÃ
ÒôƵ´ÓÄúµÄMacÉϵÄÓ¦ÓóÌÐòµÄÐéÄâÒôƵÉ豸£¬°üÀ¨Âß¼­ºÍÀíÐÔµÄÉú²úÓ¦ÓóÌÐò£¬ÒÔ¼°¼òµ¥µÄÒôƵ²¥·ÅÆ÷£¬ÈçiTunes»òQuickTime¡£
2¡¢ÈκÎÊäÈë×°ÖõŤ×÷Ô­Àí
´ÓÎïÀíÒôƵÉ豸Á¬½Óµ½ÄúµÄMacÒôƵÀ­¡£ÄãÊÇ·ñÒѾ­ÓÐÁ˼òµ¥µÄUSBÂó¿Ë·ç£¬»ò¸ß¶Ë¹¤×÷ÊÒ½Á°è»ú£¬»Ø»·¿ÉÒÔ·ÃÎÊËüµÄËùÓС£
3¡¢½«Ó¦ÓóÌÐòºÍÎïÀíÉ豸
µ±È»£¬Äã¿ÉÒÔ´´½¨Ò»¸öÐéÄâÒôƵÉ豸£¬°üÀ¨ÒôƵӦÓóÌÐòºÍÎïÀíÒôƵÉ豸¡£
4¡¢¶àͨµÀÒôƵ
ÄãµÄÐéÄâÒôƵÉ豸¿ÉÒÔÅäÖÃÓжà´ï32¸öƵµÀ£¬Ìṩ¾Þ´óµÄ¶¯Á¦¡£
5¡¢×Ô¶¨ÒåÐŵÀÓ³Éä
ĬÈÏÇé¿öÏ£¬»·»ØÉèÖÃÐŵÀÓ³Éä×Ô¶¯¡£Èç¹ûÄãÏëÊÖ¶¯ÅäÖõĶ«Î÷£¬ËäÈ»ÄãÓÐÇ¿´óµÄÑ¡Ôñ£¡
6¡¢ÎÞÏÞµÄÉ豸
´´½¨¶à¸öÐéÄâÒôƵÉ豸£¬ÄãÐèÒª°Ñ¹¤×÷×öºÃ¡£
DESCRIPTION
Loopback makes it easy to pass audio between applications on your Mac. Create virtual audio devices to take the sound from applications and audio input devices, then send it to audio processing applications. Loopback gives you the power of a high-end studio mixing board, right inside your computer!
Play Audio to All Your Podcast Guests ¨C Combine your mic with audio sources like iTunes or QuickTime Player, then select your Loopback device as your source in Skype. Presto! Your guests all hear both your voice and your audio add-ons.
Record Gameplay Videos ¨C Making gameplay videos with great audio can often be very difficult. If you¡¯re using a device like Elgato¡¯s Game Capture hardware and you want to record both your microphone and the game¡¯s audio at once, Loopback can assist!
Combine Hardware Devices ¨C Apps like GarageBand, Logic, and Ableton Live only record from a single audio device at once. Thankfully, they offer recording from many channels. With Loopback, you can combine multiple input devices into one virtual device for easy recording.
Create Top-Notch Screencasts ¨C Screen recorders, including QuickTime Player, allow you to include your mic¡¯s audio. Some allow recording of system audio instead, but neither option is ideal. Create a virtual device that grabs just the mic and the app¡¯s audio to get exactly the audio you want.
Route Audio For Broadcasts ¨C Set a simple (pass-thru) device as the output at the end of an Audio Hijack chain, and then as the input source in Nicecast. Now listeners can tune in to a live stream of your podcast as you record it!
Features
Combine Audio Sources ¨C Configuring a virtual audio device from multiple sources is easy. Just add the applications and physical audio devices you want to include to the Audio Sources table to get started.
Available System-Wide ¨C Your Mac will show Loopback¡¯s virtual devices exactly like physical devices. Find them listed among other devices in System Preferences or select them as an input or output in any audio app.
Send Audio Between Apps ¨C Loopback can also create pass-thru devices, which send audio from one app to another. Set the Loopback device as the output in one app and the input in another to make audio flow directly between the applications.
Works With Any Application ¨C Make a virtual audio device with audio from the applications on your Mac, including production apps like Logic or Reason, as well as simple audio players, like iTunes or QuickTime.
Works With Any Input Device ¨C Pull audio from the physical audio devices connected to your Mac. Whether you¡¯ve got simple USB microphones, or high-end studio mixers, Loopback can access it all.
Combine Apps and Physical Devices ¨C Of course, you can create a virtual audio device that includes audio from both apps and physical audio devices.
Multichannel Audio ¨C Your virtual audio devices can be configured to have up to 32 channels, providing tremendous power.
Custom Channel Mapping ¨C By default, Loopback sets up channel mapping automatically. If you want to manually configure things, though, you¡¯ve got powerful options!
Nested Devices ¨C You can now nest one Loopback device inside another, allowing for easier configuration, as well as even more power and control.
ÏÂÔØµØÖ·£º
Óοͣ¬Èç¹ûÄúÒª²é¿´±¾ÌûÒþ²ØÄÚÈÝÇë»Ø¸´
ÆÀÂÛÁÐ±í£¨1£©
Îʺà Loopback Mac Ç¿´óµÄÒôƵ²¼Ïß¹¤¾ß
2008-9-11 11:14:54 »Ø¸´
