Valhalla DSP ValhallaPlate for Mac£¬»ìÏìЧ¹ûÆ÷²å¼þ
Valhalla DSP ValhallaPlate ¼ò½é£º
Valhalla DSP ValhallaPlate for MacÊÇÒ»¿î»ìÏìЧ¹ûÆ÷²å¼þ¡£ÊÇÎÒÃǶԾ­µä°æ»ìÏìÉùÒôµÄËã·¨¡£ÆßÖÖԭʼË㷨ģÄâÏÖʵÊÀ½ç¸Ö°å»ìÏìµÄÉùÒôºÍÐÐΪ£¬²¢½«ÉùÒôת»¯ÎªÎïÀí°å²»ÄܽӴ¥µÄ³ß´ç¡£ÊÇÕæÕýµÄWavesfactory CassetteÁ¢ÌåÉù£¬·ÂÕæ¸Ö°å£¬ÓÐ2¸öÊäMusicLab RealGuitarÈëÇý¶¯Æ÷ºÍ2¸öÊä³öʰÒôWavesfactory CassetteÆ÷¡£Ëü¿ÉÒÔ×÷Ϊµ¥iZotope NectarÊäÈë/µ¥Êä³ö£¬µ¥ÊäÈë/Á¢ÌåÉùÊä³ö»òÁ¢ÌåÉùÊäÈë/Á¢ÌåÉùÊä³ö²å¼þÔËÐС£
ValhallaPlate±ÆÕæµØÄ£ÄâÁ˰åʽ»ìÏìµÄÎïÀíÌØÐÔ£º
¸ßÀ©É¢£¬ÓÃÓÚ¾ßÓÐ×î¸ß»ØÉùÃܶȵĻìÏì¡£
ÔÚµ¥¸öË¥¼õ²ÎÊýµÄ¿ØÖÆÏ£¬ÆµÂÊÏà¹ØµÄË¥¼õʱ¼ä£¬¶ÔÓÚ¾Þ´óµÄµÍµãºÍÃ÷ÏԵĸߵ㡣
Dispersion£¬ÓÃÓÚÔÚË¥±äÖд´½¨3D³ÉÏñ¡£»ìÏìÀ´×ÔÑïÉùÆ÷Íⲿ£¬²¢Ë¥¼õµ½ÑïÉùÆ÷ºóÃæµÄÉî¶È¡£
ValhallaPlate½«°åʽ»ìÏìÀ©Õ¹ÎªÊµ¼Ê°åÎÞ·¨´ïµ½µÄ³ß´ç£º
¿É±ä³ß´ç£¬ÓÃÓÚ¿ØÖÆ»ìÏìģʽµÄ½ðÊôÉùÒô¡£Ð¡³ß´çµ¼Ö¸ü¶à½ðÊôÑÓ³Ù£¬¶ø¸ü´ó³ß´çÌýÆðÀ´¸üÇåÎú¡£
Lushµ÷ÖÆ£¬Ïû³ýÈκνðÊôαӰ£¬Í¬Ê±±£³ÖÊäÈëµÄÒô¸ß¡£
ÆßÖÖԭʼ»ìÏìËã·¨£º
ËÄÖÖ»ìÏìģʽ£¨¸õ£¬¸Ö£¬»ÆÍ­£¬îÜ£©Ä£ÄâÕæÊµ°å»ìÏìÆ÷ÖеĹ²ÕñÃܶȡ£
ÈýÖÖ¶îÍâµÄ»ìÏìģʽ£¨ÂÁ£¬Í­£¬·ÇÏÔÏñ£©£¬½áºÏÁ˸ְåµÄ3DÉ«É¢ÌØÐԺͻìÏìÊÒÖеĸ߹²ÕñÃܶȡ£
ValhallaPlate½¨Á¢ÔÚValhalla DSP²å¼þ´«Í³µÄ»ù´¡ÉÏ£º
¼«¼òÖ÷Ò壬¿Éµ÷Õû´óСµÄ2D GUI£¬¾ßÓÐ×ÔÎҼǼ¹¤¾ßÌáÊ¾ÇøÓò¡£
È«ÃæµÄÔ¤Éèä¯ÀÀÆ÷ʹ±£´æ£¬µ÷Óú͹²ÏíÉèÖñäµÃ¼òµ¥¡£
ÍêÈ«¼æÈÝ32λºÍ64λDAW£¨OSXºÍWindowsΪ32/64λVST£¬OSXΪ32/64λÒôƵµ¥Ôª£¬OSXºÍWindowsΪ32λRTAS£¬OSXºÍWindowsΪ64λAAX£©¡£
¹Ù·½¼ò½é£º
Valhalla DSP ValhallaPlate is our algorithmic take on the classic plate reverberation sound. Seven original algorithms emulate the sound and behavior of real world steel plate reverbs, and take the sound into dimensions that physical plates can¡¯t touch.
Valhalla DSP ValhallaPlate is true stereo, emulating a steel plate that has 2 input drivers and 2 output pickups. It can be run as a mono-in/mono-out, mono-in/stereo-out, or stereo-in/stereo-out plugin.
ValhallaPlate realistically models the physics of plate reverbs:
High diffusion, for reverbs that have maximally high echo density.
Frequency dependent decay time, for huge lows and clear highs, under the control of a single Decay parameter.
Dispersion, for creating 3D imaging in the decay. The reverb comes from outside the speakers, and decays into the depths behind the speakers.
ValhallaPlate extends the plate reverb into dimensions that real plates can¡¯t reach:
Variable size, to control how metallic a reverb mode sounds. Small sizes result in more metallic delays, while larger sizes sound clearer.
Lush modulation, that eliminates any metallic artifacts, while retaining the pitch of the input.
Seven original reverberation algorithms:
Four reverb modes (Chrome, Steel, Brass, Cobalt) that model the resonance density found in real plate reverberators.
Three additional reverb modes (Aluminum, Copper, Unobtanium) that combine the 3D dispersive characteristics of steel plates with the high resonance density found in reverberation chambers.
ValhallaPlate builds upon the Valhalla DSP plugin heritage:
Minimalist, resizable 2D GUI, with selfdocumenting tool tip area.
A comprehensive preset browser makes saving, recalling and sharing settings easy.
Fully compatible with 32 and 64 bit DAWs (32/64 bit VST for OSX and Windows, 32/64 bit Audio Units for OSX, 32bit RTAS for OSX and Windows, 64bit AAX for OSX and Windows).
ÏÂÔØµØÖ·£º
Óοͣ¬Èç¹ûÄúÒª²é¿´±¾ÌûÒþ²ØÄÚÈÝÇë»Ø¸´
ÆÀÂÛÁÐ±í£¨4£©
Valhalla DSP ValhallaPlate for Mac£¬»ìÏìЧ¹ûÆ÷²å¼þ£¬Ö§³Ö£¡
2008-8-6 12:33:59 »Ø¸´
:handshake Îʺ÷½ÏèÀÏʦ,ÕâÑù¸üºÃ!Çú¼ÒµÄ¶þ¶È´´×÷,Ö»Òª´ÊÒâ²»±ä,´ó¿É²»±Ø¾ÐÄàÓÚÔ­´Ê×÷µÄÏÞÖÆ!
2008-8-6 12:40:41 »Ø¸´
ÏêÏêϸϸлл
2020-9-28 23:06:28 »Ø¸´
лл¥Ö÷µÄ·ÖÏí66666666666666666666666666
2022-1-21 17:54:11 »Ø¸´
