| Êä³ö | LS9-16 | LS9-32 |
| »ìÒôÄÜÁ¦ | »ìÒôͨµÀ | 32 Mono + 4 Stereo | 64 Mono + 4 Stereo |
| ±à×é | 16 MIX (Group/AUX) ×ÜÏß | 16 MIX (Group/AUX) ×ÜÏß |
| AUX | 16 MIX (Group/AUX) ×ÜÏß | 16 MIX (Group/AUX) ×ÜÏß |
| Ö÷Êä³ö | Stereo Mono | Stereo Mono |
| MATRIX | 8 | 8 |
| ÊäÈëͨµÀ¹¦ÄÜ | HPF Ë¥¼õÆ÷ 4-¶Î PEQ 2x Dynamic Pan (LR »ò LCR ´ø CSR) | HPF Ë¥¼õÆ÷ 4-¶Î PEQ 2x Dynamic Pan (LR »ò LCR ´ø CSR) |
| Êä³öͨµÀ¹¦ÄÜ | Ë¥¼õÆ÷4¶Î PEQ Dynamic | Ë¥¼õÆ÷4¶Î PEQ Dynamic |
| ÄÚ½¨´¦ÀíÆ÷ | 4x GEQ 4x GEQ/SPX (GEQ: 31¶Î»ò 2x Flex15) 50x Output ¶Ë¿ÚÑÓ³Ù | 4x GEQ 4x GEQ/SPX (GEQ: 31¶Î»ò 2x Flex15) 66x Output ¶Ë¿ÚÑÓ³Ù |
| I/O | »°Í²ÊäÈë | 16 (¿Éµ÷³ö) | 32 (¿Éµ÷³ö) |
| »ÃÏñ¹©µç | +48V DC; ON/OFF ÿͨµÀ | +48V DC; ON/OFF ÿͨµÀ |
| ADת»»Æ÷ | 24-bit; 128-´Î ¹ý²ÉÑù | 24-bit; 128-´Î ¹ý²ÉÑù |
| Ïß·Êä³ö | 8 Omni Êä³ö | 16 Omni Êä³ö |
| DA ת»»Æ÷ | 24-bit; 128-´Î ¹ý²ÉÑù | 24-bit; 128-´Î ¹ý²ÉÑù |
| Êý×Ö I/O | 2tr in/out USB ´æ´¢Â¼Òô»ú/²¥·ÅÆ÷ | 2tr in/out USB ´æ´¢Â¼Òô»ú/²¥·ÅÆ÷ |
| À©Õ¹²Û | Mini-YGDAI (16-in/16-out); ÄÜͨ¹ýÀ©Õ¹²ÛÒ£¿ØHA ÔöÒæ | Mini-YGDAI (16-in/16-out); ÄÜͨ¹ýÀ©Õ¹²ÛÒ£¿ØHA ÔöÒæ |
| ¿ØÖÆÆ÷ºÍÆäËü | Ethernet MIDI USB (´æ´¢/Ô¿³×) ×ÖʱÖÓ I/O | Ethernet MIDI USB (´æ´¢/Ô¿³×) ×ÖʱÖÓ I/O ÕÕÃ÷µÆ |
| Ò»°ã¼¼Êõ¹æ¸ñ | LS9-16 | LS9-32 |
| ÄÚ²¿´¦ÀíÄÜÁ¦ | 32bit ÀÛ¼ÓÆ÷: 58bit | 32bit ÀÛ¼ÓÆ÷: 58bit |
| ²ÉÑùÂÊ | ÄÚ²¿ | 44.1kHz 48kHz | 44.1kHz 48kHz |
| Íⲿ | 44.1 kHz (-10%) µ½ 48 kHz (+6%) | 44.1 kHz (-10%) µ½ 48 kHz (+6%) |
| ÐźÅÑÓ³Ù | µÍÓÚ 2.5 ms (@48kHz) | µÍÓÚ 2.5 ms (@48kHz) |
| ×Üг²¨Ê§Õæ | µÍÓÚ 0.05% (20Hz-20kHz) | µÍÓÚ 0.05% (20Hz-20kHz) |
| ƵÂÊÏìÓ¦ | 0 +0.5 -1.5dB 20Hz-20kHz | 0 +0.5 -1.5dB 20Hz-20kHz |
| ¶¯Ì¬·¶Î§ | DA: 110dB; AD+DA: 108dB | DA: 110dB; AD+DA: 108dB |
| ÎËÒôºÍÔëÉùµçƽ | ƽ¾ùÊäÈëÔëÒô | -128dBu | -128dBu |
| ²ÐÓàÊä³öÔëÉù | -86dBu | -86dBu |
| ´®ÈÅ | -80 dB ÏàÁÚÊäÈëͨµÀ Input to Output | -80 dB ÏàÁÚÊäÈëͨµÀ Input to Output |
| ¹©µçÒªÇó | AC100-240V 50/60Hz ºÍ/»òʹÓÃPW800W | AC100-240V 50/60Hz ºÍ/»òʹÓÃPW800W |
| ¹¦ºÄ | 95W | 170W |
| Íâ¹Û³ß´ç | ¿í | 480mm; 18-7/8in | 884mm; 34-13/16in |
| ¸ß | 220mm; 8-11/16in | 220mm; 8-11/16in |
| Éî | 500mm; 19-11/16in | 500mm; 19-11/16in |
| ¾»ÖØ | 12.0kg; 26.5lbs | 19.4kg; 42.8lbs |
| ¸½¼þ | ʹÓÃ˵Ã÷Êé ACµçÔ´Ïß | ʹÓÃ˵Ã÷Ê飬ACµçÔ´Ïߣ¬·À³¾ÕÖ |
