ATC SCM25A ¼ÒôÅïÓÐÔ´¼àÌýÒôÏä
Ó¢¹ú´¿ÊÖ¹¤ÖÆ×÷¼àÌýÒôÏä
The quickest way to upgrade the sound of your studio is with the ATC SCM25A 3-way active studio monitors. All of ATC&££39;s speakers are handmade in the UK. Even the low and mid drivers are handmade and wound to exacting specifications so your playback is as accurate as possible. The SCM25A gives you full-range playback via a 7" woofer, 3" midrange, and a 1" dome tweeter. Tri-amped with a total of 235W, this system is clear and accurate. Hear what you have been missing from your music with the ATC SCM25A active studio monitors.
ATC SCM25A Active 3-way Studio Monitor Pair at a Glance:
Engineering the best speaker possible
Proprietary speakers offer life-like playback
The legacy of ATC monitors
Heavy science and engineering backs up every ATC product. These monitors aren&££39;t just cobbled together from parts that will work together. The ATC SCM25A was thoroughly engineered to give you the best sound, response, and reproduction of your audio possible. You&££39;ll hear every change and every detail in your recordings. Hear the difference of truly engineered monitors with the ATC SCM25A.
Great-sounding monitors start with great-sounding speakers. The ATC SCM25A&££39;s low and mid drivers are manufactured to exacting standards at their in-house facility. Hand-wound voice coils are made from flat oxygen-free copper wire and operate in a precision long magnetic gap. Specially designed magnet vents not only reduce air flow noise and heat, but increase power handling and reliability. These drivers are designed to give you a smooth and even frequency response without built-in EQ. In short, the SCM25A was designed to perform and sound better.
A young engineer named Billy Woodman spent his younger days working side by side with some of the best speaker engineers of his day. In 1974 Billy went on to found ATC, Acoustic Transducer Company, and began building amazing-sounding speakers. Today ATC hand builds speakers one at a time to ensure the utmost quality and best sound. Billy continues to invent new drivers, new speakers and new ideas, giving you the best monitors in the industry. How good are ATC monitors? Just ask producers and engineers like George Massenburg, Chuck Ainley and Doug Sax. You&££39;ll also find them in Abbey Road Studios, Sony Studios New York, Blackbird Studios. and many more. Grab a pair of ATC SCM25A monitors and hear the difference they&££39;ll make in your studio.
ATC SCM25A Active 3-way Studio Monitor Pair Features:
Premium 3-way active studio monitors
Extremely accurate and life-like playback of your recordings
235W tri-amped monitor
Engineered to give you the best playback possible
Used by many professional engineers, producers, artists and studios
Sold as a pair
Increase your studio&££39;s performance and accuracy with a set of ATC SCM25A 3-way active monitors.
Tech Specs| Powered | Yes | | Power Configuration | Tri-amped | | LF Driver Size | 7" | | LF Driver Type | ATC proprietary short-coil | | LF Driver Material | Carbon-paper cone | | HF Driver Size | 3" (Mid), 1" (High) | | HF Driver Type | Dome | | HF Driver Material | Soft Dome | | LF Driver Power Amp | 150W | | HF Driver Power Amp | 60W (Mid), 25W (High) | | Total Power | 235W | | Frequency Range | 47Hz-22kHz | | Crossover Frequency | 380Hz, 2.5kHz | | Maximum Peak SPL | 109 dB SPL @ 1m | | Enclosure Type | Ported | | Input Types | 1 x XLR | | Height | 10.4" | | Width | 16.9" | | Depth | 16.1" | | Weight | 66 lbs. |
