norCtrack Yamaha Motif ES KONTAKT
norCtrack - Yamaha Motif ES NKIÊÇ×îÇ¿´óµÄ¹¤×÷Õ¾Yamaha Motif ESµÄÉùÒô¿â¡£ ÕâÀï°üÀ¨Ó²¼þÐͺÅYamaha Motif ESµÄ×î¼ÑÉùÒôÔ¤Éè¡£ Yamaha Motif ESÊÇËûÃÇ×îÊÜ»¶ÓµÄ¹¤×÷Õ¾Ö®Ò»¡£ ¸ø¶¨µÄ¿âÔÊÐíÔÚ¼ÆËã»úÉÏΪÄúÌṩ´ËÀÖÆ÷µÄÉùÒô¡£ ÌýÆðÀ´ÊǶàÖØ²ÉÑùµÄ¡£ Äú¿ÉÒÔ½«´ËÉùÒôÓÃÓÚרҵĿµÄ¡£
ÔÎÄ
norCtrack ¨C Yamaha Motif ES NKI is a library of sounds of the most powerful workstation Yamaha Motif ES. Here included the best sound presets from hardware model Yamaha Motif ES. Yamaha Motif ES it is one their most popular workstations. The given library allows to have sounds of this instrument at you on a computer. Sounds multisampled. You can use this sounds for professional purposes.
Instrument List:
Acoustic Pianos
Acoustic Pianos
Electric Pianos
Keyboards
Pipe Organ
Acoustic Guitars
Electric Guitars
Overdriven Guitars
Plucked
Bells
Mallets
Synth Bass
Soft Lead
Hard Lead
Dance Lead
Orchestral Strings
Ensemble Strings
Synth Strings
Flutes
Choir
Acoustic Brass
Synth Brass
Pads
Synth Fx
Hits Stabs
Sound Effects
Percussions
Percussions Kits
Drum Kits
norCtrack Yamaha Motif ES KONTAKT | 5.13 GB
ÏÂÔØµØÖ·£ºÓοͣ¬Èç¹ûÄúÒª²é¿´±¾ÌûÒþ²ØÄÚÈÝÇë »Ø¸´ |
