Polychrome Èí¼þºÏ³ÉÆ÷
×ªÔØ
Polychrome Èí¼þºÏ³ÉÆ÷¡£Ç¿´óµÄ²¨±íºÍÐéÄâÄ£ÄâÈí¼þºÏ³ÉÆ÷£¬ÒÑÓÐ20ÄêµÄÀúÊ·¡£ÕâÊÇÑÕÁÏ£¬Ëü½«¸Ä±äÄúÖÆ×÷ÒôÀֵķ½Ê½¡£
2´úÓкÎй¦ÄÜ£¿
еÄÑù±¾ÒýÇæ
̽Ë÷Êý°Ù¸öÑù±¾£¬µ¼Èë×Ô¼ºµÄÑù±¾£¬½«Æä¼ÓÔØµ½¾ßÓÐ6ÖÖ²¥·ÅģʽµÄ6¸ö²»Í¬²å²ÛÖ®Ò»ÖС£Ê¹ÓÃPigmentsµÄµ÷ÖÆ¹¦ÄÜÑ­»·£¬±à¼­²¢Ê¹ËüÃÇèòèòÈçÉú¡£
ÐÂºÏ³ÉÆ÷ģʽ
Ö»Ð谴һϰ´Å¥¼´¿É½«Ñù±¾×ª»»Îª¿ÅÁ£×´µÄºÏ³ÉÆ÷²¹¶¡£¬µ÷ÕûÃܶȣ¬°üÂ磬´óСºÍÁîÈËÐ˷ܵÄËæ»ú»¯²ÎÊý£¬´Ó¶øÎªÄúµÄÉùÒôÉè¼ÆÔö¼ÓеIJã´Î¡£
ÐÂÒôÐòÆ÷
ÄÚÖÃÒôÐòÆ÷ÏÖÔÚÔÊÐíÄúÒÔ·ÇÆÆ»µÐԵķ½Ê½Ó¦ÓÃËæ»úÐÔ£¬ÈÃÄúʼÖÕ·µ»Øµ½¿ªÊ¼µÄµØ·½£¬·Ç³£ÊʺÏÏÖ³¡±íÑݺͼ´ÐËÑÝ×à¡£
йýÂËÆ÷ºÍÑÓ³Ù
ÎÒÃÇÒѽ«Buchla»­¼ÜµÍͨÃŵıêÖ¾ÐÔÉùÒôºÍÌ«¿Õʱ´úµÄ´Å´ø»ØÉùÌí¼Óµ½ÁËPigmentsµÄÉùÒôÎäÆ÷¿âÖУ¬ÒÔʹijЩŤÇú±äÐεÄÍâ¹Û·Ç³£ÃÀ¹Û¡£
¾«ÖµĹ¦ÄÜ
µ½´¦¶¼ÊÇûÓÐʲô¸Ä½øµÄ¸üн«ÊÇʲô£¿ÐµĽçÃæ£¬MPE¹¦ÄÜ£¬Ðµij·Ïû/ÖØ×ö¹¦ÄܺÍÔöÇ¿µÄµ÷ÖÆÌõµÈ´ý×ÅÄú¡£
ÐÂÔ¤Éè
ΪÁËչʾй¦ÄÜ£¬ÎÒÃÇÓ¢ÓµÄÉùÒôÉè¼ÆÊ¦ÍŶӴ´½¨ÁËÊý°ÙÖÖÁîÈË̾Ϊ¹ÛÖ¹µÄÐÂÉùÒô£¬¹©Äú̽Ë÷ºÍʹÓá£
Polychrome Software Synthesizer. An immensely powerful wavetable and virtual analog software synthesizer, 20 years in the making. This is Pigments, and it¡¯s going to change the way you make music.
WHAT¡¯S NEW IN VERSION 2?
New Sample Engine
Explore hundreds of samples, import your own, load them into one of 6 different slots with 6 playback modes. Loop, edit, and bring them to life with Pigments¡¯ modulation abilities.
New Synth Mode
Add another level to your sound design by transforming samples into granular synth patches at the touch of a button, adjust density, envelope, size, and exciting randomization parameters.
New Sequencer
The in-built sequencer now lets you apply randomness in a non-destructive way, letting you always return back to where you started, perfect for live performance and improvisation.
New Filter and Delay
We¡¯ve added the iconic sound of the Buchla Easel low pass gate and a space-age tape echo to Pigments¡¯ sonic arsenal, for some seriously nice warping, contorting analog flavor.
Refined Features
What would an update be without little improvements here and there? New interface, MPE capability, new undo/redo functionality and enhanced modulation bar await you.
New Presets
To show off the new features, our team of heroic sound designers have created hundreds of breathtaking new sounds for you to explore and use in your tracks.
V 2.0.1
New Features
Piqments 2.0 presents are now NKS compatible
No more time limit on user samples
Add non-vioce-stealinq poly mode
Sample enqine crossfade has been improved
MPE support has been improved
Micro tuninq support has been improved
Minor GUI improvements
Buqs
Sample loop pionts are now correctly saved
No more crashes with audiolove.club Ableton Live durinq preset scan
Parameter smoothinq has been improved
Samples too guiet are no lonqer normalized
Poly aftertouch is workinq aqain
Minor buqixes for the functoin in loop mode
Free run sources are now reset by the seguencer on each start
Home Page - https://www.arturia.com/products ... igments/overview#en
ÆÀÂÛÁÐ±í£¨1£©
2008-5-20 10:48:12 »Ø¸´
