01V96i±à¼Æ÷£¨01V96i EDITOR£©
01V96i±à¼Æ÷Èí¼þÓµÓÐMACÒÔ¼°WindowsϵͳÁ½¸ö°æ±¾£¬ËüÊÇ01V96iµÄ¹ÜÀí¿ØÖÆÈí¼þ£¬¿ÉÒÔ°ïÖúÄúÔÚPC¶ËÍê³Éµ÷Òǫ̂ËùÓвÎÊýµÄ¿ØÖƺ͵÷ÕûÔ¤Éè¡£±à¼Æ÷ÌṩÁË×ÛºÏ¼à¿Ø¹¦ÄÜ£¬Í¬Ê±£¬ÔÚÁ¬½ÓÖÁµ÷Òǫ̂ºó£¬»¹¿ÉÒÔʵʱÏÔʾѡ¶¨Í¨µÀµÄ״̬¡£ÔÚÀëÏß״̬Ï£¬Äú¿ÉÒԱ༹ÜÀí³¡¾°Êý¾Ý£¬ÌøÏßÁбíÒÔ¼°ÆäËû·á¸»¹¦ÄÜ£¬Õ⽫´ó´óÌá¸ßÄúµÄ¹¤×÷ЧÂÊ¡£Èç¹ûÄúÔÚʹÓÃһ̨ÁÙʱ½èÀ´µÄ»òÕßÊǹ̶¨°²×°Á˵ĵ÷Òǫ̂£¬Äú¿ÉÒÔͨ¹ý±à¼Æ÷ÇáËɵؽ«×öºÃµÄµ÷Òǫ̂ÉèÖñ£´æµ½ÄúµÄµçÄÔÉÏ£¬ÕâÑùÔÚ¸ü»»±ðµÄµ÷Òǫ̂ʹÓÃʱ£¬¿ÉÒÔ¿ìËÙ¼ÓÔØÖ®Ç°µÄÔ¤ÉèÁË¡£ÔÚÕâÒ»µãÉÏ£¬01V96i±à¼Æ÷ͬÑùÒ²³ÉΪÁËÄú±£´æ²¢¹ÜÀíµ÷Òǫ̂±¸·ÝµÄºÃ°ïÊÖ¡£
Cubase AI - ÍêÃÀµÄ¼ÒôÖÆ×÷½â¾ö·½°¸
Steinberg¹«Ë¾²»¶Ï×·ÇóÑз¢ÎªÏȽøµÄ×ÛºÏDAWÈí¼þϵͳ£¬Æä³öÆ·µÄCubaseÈí¼þ±ãÖØÐ¶¨ÒåÁËÒôÀÖÖÆ×÷Èí¼þµÄ±ê×¼¡£01V96iÔÚ¹ºÂò°ü×°Öи½ÔùÁËа汾µÄCubase AIÒôÀÖÖÆ×÷Èí¼þ£¬ËüΪÄúÌṩÁËÒ»¸öÎÞ±ÈÁé»îÖ±¹ÛµÄ´´×÷ƽ̨£¬°ïÖúÄú¼¤·¢ÎÞÏÞµÄÒôÀÖ´´×÷DZÄÜ¡£Cubase AIÊÇSteinberg CubaseÒôÀÖÖÆ×÷Èí¼þϵͳµÄ¼ò»¯°æ£¬ËüÍêȫʹÓÃÁËÓëCubaseÏàͬµÄÄÚºËÒÔ¼°²Ù×÷½çÃæ£¬ÕâЩCubaseµÄÓÅÒìÌØµãÔÚÊÀ½ç·¶Î§ÄÚ¹ãÊÜÔÞÓþ¡£Cubase AIÔÚ½áºÏ01V96iÊý×Öµ÷Òǫ̂ʹÓÃʱ£¬Ò»¸öÍêÕû¼Òôϵͳ½â¾ö·½°¸¼´¿ÉÍê³É¡£MACϵͳÒÔ¼°WindowsϵͳÓû§¿ÉÒÔÁé»îµØÔÚ¶àÖÖ³¡ºÏÍê³É¼ÒôÅï〜±ðµÄ±àÇú¡¢Â¼Òô¡¢±à¼ÒÔ¼°»ìÒôµÈµÈ¸÷ÖÖ¼ÒôÖÆ×÷¹¤×÷¡£
01V96i
Outline
Mixing capabilityMixing channels32 Mono + 4 Stereo
GROUP8
AUX8
MAINStereo
Input channel functionsGate, Attenuator, 4-band PEQ, 2x Compressor, Delay, Pan
Output channel functionsAttenuator, 4-band PEQ, Compressor, Delay
On-board processors4x SPX multi effectors
I/OMic inputs12
Phantom power+48V DC; ON/OFF per 4ch
Line inputs2x Stereo, 2x 2tr in
AD converter24-bit; 128-time over sampling
Line outputsStereo output, Monitor output, 4x Omni output
DA converter24-bit; 128-time over sampling
Digital I/OADAT (8-in/8-out), 2tr in/out
Expansion slotsMini-YGDAI (16-in/16-out)
Control and othersTo Host(USB), MIDI, Word clock I/O
General specifications
Internal processing32bit, Accumulator: 58bit
Sampling frequency rateInternal44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz
External44.1kHz/88.2kHz (-10%) - 48kHz/96kHz (+6%)
Signal delayLess than 1.6ms CH INPUT to STEREO OUT (@SampIing frequency = 48kHz) / Less than 0.8ms CH INPUT to STEREO OUT (@SampIing frequency = 96kHz)
Total harmonic distortionCH INPUT to STEREO OUT: Less than 0.05%, 20Hz to 20kHz @+14dBu into 600¦¸ / Less than 0.01%, 1kHz @+24dBu into 600¦¸ (@SampIing frequency = 48kHz) / Less than 0.05%, 20Hz to 40kHz @+14dBu into 600¦¸ / Less than 0.01%, 1kHz @+24dBu into 600¦¸ (@SampIing frequency = 96kHz)
Frequency responseCH INPUT to STEREO OUT: 0.5, -1.5dB, 20Hz - 20kHz @+4dBu into 600¦¸(@SampIing frequency = 48kHz) / 0.5, -1.5dB, 20Hz - 40kHz @+4dBu into 600¦¸(@SampIing frequency = 96kHz)
Dynamic range110dB typ. DA Converter (STEREO OUT) / 105dB typ. AD+DA (to STEREO OUT) @fs=48kHz / 105dB typ. AD+DA (to STEREO OUT) @fs=96kHz
Hum & noise levelEquivalent input noise-128dBu Equivalent Input Noise.
Residual output noise-86dBu residual output noise. STEREO OUT: STEREO OUT off. / -86dBu (90dB S/N) STEREO OUT: STEREO fader at nominal level and all CH INPUT faders at minimum level. / -64dBu (68dB S/N) STEREO OUT: STEREO fader at nominal level and one CH INPUT fader at nominal level
Crosstalk-80dB adjacent input channels (CH1-12) / -80dB adjacent inp |
