查看: 29744|回复: 5
[资讯] Native Instruments Kinetic Toys KONTAKT
发表于 2008-2-24 21:04:21 | 显示全部楼层 |阅读模式
动态玩具提供动态播放200多种复古儿童玩具,工具和对待的录音,每个都有自定义合成图层,以创建可播放的色调。然后使用动态X-Y调制系统对这些进行变形和处理。结果是原始的,令人回味的和独特的声音,是出色的线索或古怪的节奏效果和氛围的理想选择。
KINETIC TOYS的声音范围从发条机器人,火车总成和本生燃烧器到乒乓球,弹球机和爆米花。这个盒子包含35个主题声音集,每个都有八个动态混合的玩具和合成的声音,并由四个效果操纵。可以手动分配声音和效果,准备进行调制和变形。
KINETIC TOYS的中心是两个X-Y控制器,用于调制声场和效果场景。芭蕾舞演员控制声音场景。当她跳舞时,八个玩具声音和八个合成器之间的声音变形。她的动作可以手动和自动进行。机器人的控制完全像芭蕾舞演员,其进度调节最多八个效果处理器。个人效果是针对每个主题量身定制的,分为四个类别:共振效应(EQ和滤镜),空间处理器(如延迟),比特破碎器和失真以及调制工具。还有四种可分配的调制源:两个包络和两个LFO。
原文
KINETIC TOYS offers dynamic playback of 200+ recordings of vintage children’s toys, tools, and treats, each with a custom synthesized layer to create playable tones. These are then morphed and processed using a dynamic X-Y modulation system. The result is pristine, evocative, and distinctive sound, ideal for standout leads or quirky rhythmic effects and atmospheres.
Sounds in KINETIC TOYS range from clockwork robots, train sets, and bunsen burners to ping pong balls, pinball machines, and popcorn. This box of treats overflows with 35 themed sound sets, each with eight dynamically mixable toy and synthesized sounds, and manipulated by up to four effects. Both sounds and effects can be manually assigned, ready for modulation and morphing.
Central to KINETIC TOYS are two X-Y controllers for modulating sound scenes and effects scenes. The ballerina controls the sound scenes. As she dances, sound morphs between eight toy sounds and eight synth layers. Her motion can be played manually and automated. The robot is controlled exactly like the ballerina, its progress modulating up to eight effects processors. Individual effects are tailored to each theme and fall into four categories: Resonant effects (EQ and filters), spatial processors (such as delays), bitcrushers and distortions, and modulation tools. There are also four assignable modulation sources: Two envelopes and two LFOs.
下载地址:
游客,如果您要查看本帖隐藏内容请回复
Native Instruments Kinetic Toys KONTAKT | 3.52 Gb
4万
音频应用中级会员
Rank: 5Rank: 5Rank: 5
发表于 2008-2-25 16:04:36 | 显示全部楼层
:lol
220
 楼主| 发表于 2008-2-27 19:37:10 | 显示全部楼层
是的,请多支持!
28
发表于 2021-2-17 11:45:20 | 显示全部楼层
这个音色老爱了
6
发表于 2021-7-18 08:33:01 | 显示全部楼层
45555555555555
GMT+8, 2025-7-12 15:03 , Processed in 0.044485 second(s), 21 queries , Redis On.
