Soundcells bitBUMPER Deluxe v2 Reason ReFill
ÒôÔ´
bitBUMPER deluxe ¨C the ultimate 4 and 8 bit Pandora Box filled with hundreds of low bit surprises.
This ReFill is your best friend when you¡äre looking for inspiring new sounds with a character and a bite ¨C it sounds cool, adventurous, nostalgically warm and noisy at the same time! To catch this character some amazing sources were sampled:
RozzBox One v2, QuadraSID, the old grey Gameboy from 1989 with ¡®Nanoloop 1¡® and ¡®LittlesoundDJ¡®, the Gameboy Advance SP from 2003 with ¡®Nanoloop 2¡® and the Nintendo DS Lite from 2006 with ¡®DS Electroplankton¡® and ¡®Korg DS-10¡®.
Thor and the RPG-8 have had great influence during the upgrading process of the original bitBUMPER. Lots of patches go through Thor¡äs fine stereo filter 3 section and 30 inspiring ¡°live looping¡± combinator patches making use of the rex files and the RPG-8 were added.
With bitBUMPER deluxe v3 the art of lofi has reached a new era!
Contents:
-382 combinators containing keys, pads, basses, leads, FX, drums, bleeps, noises and percussion, including many velocity controlled counter parts:
-83 Basses
-92 Pads
-61 Keys
-47 Leads
-41 FX
-58 Misc
-185 NNXT patches.
-138 rex loops.
-650 unique low bit samples.
-40 scream patches helping you to lofi your sound.
-12 demo tracks in Reason format included
Reason 6 and up needs to be installed to use this product.
Version 2.0 (March, 3th 2010)
130 new combinator patches (mainly velocity controlled counterparts of existing patches)
New rex loops using KORG¡®s DS-10 for the Nintendo DS lite
ÏÂÔØµØÖ·£º
Óοͣ¬Èç¹ûÄúÒª²é¿´±¾ÌûÒþ²ØÄÚÈÝÇë»Ø¸´
ÆÀÂÛÁÐ±í£¨2£©
ѧϰSoundcells bitBUMPER Deluxe v2 Reason ReFill
:victory:
2008-1-16 01:25:06 »Ø¸´
:victory: :victory:
2008-1-22 12:09:18 »Ø¸´
