Äã±ØÐëÖªµÀµÄ»ìÒô֪ʶ
TIP 1 - Get it right at the source °ÑÎÕºÃÉùÔ´
If you are recording and mixing the same track, spend more time and effort on the recording phase. A high-quality mix is 80% the recording and 20% the mix.
WB Studios£º×÷ÕßÈÏΪ¸ßÖÊÁ¿µÄÒôÏìÉóÃÀ×÷Æ·£¬°Ë³É¼ÒôÁ½³É»ìÒô¡£²»¹ýÎÒ¸öÈËÈÏΪ£¬ÏÖÔÚÒѾ2019ÄêÁË£¬¾ßÌåµÄ±ÈÖØ»¹Êǵÿ´ÊÖÀïµÄ»î¶ùÊÇʲô£¨±Ï¾¹¿ÉÄܲ»Éæ¼°µ½Â¼Òô½×¶Î£©£¬ÒÔ¼°Â¼Òô½×¶ÎÒªÓлìÒô¹ÛÄ»ìÒô½×¶ÎÒªÓмÒô¹ÛÄî¡£µ«ÕâÀïµÄ°Ë¶þ·Ö¹ÛÄîÊǷdz£ÖµµÃÏÖÔÚÊý×ÖÒôÀÖʱ´úµÄ´ÓÒµÕßÃÇ×¢ÒâµÄ¡£
TIP 2 - Get the balance right first ÏÈÈ·¶¨Æ½ºâ
Before you jump to EQ, compression etc. spend plenty of time (30 mins or more) adjusting the faders and getting a good static mix.
WB Studios£ººÃµÄ»ìÒô£¬°Ë³ÉÔÚÓÚÒôÁ¿µÄƽºâ±ÈÀý£¬Õâ¸ö¹ÛÄîÎÒÈÏΪ·Ç³£ÕýÈ·¡£µ«ÊÇÊDz»ÊÇÒªÔÚEQ¡¢Ñ¹Ëõ֮ǰ¾Í°Ñƽºâ±ÈÀý×öºÃÄØ£¬Õâ¸ö¾ÍÊÇ¿´¾ßÌåµÄ¸öÈËworkflowÁË¡£Èç¹ûµ±ÏÂÒªÊÕʰµÄ·Ö¹ìÒѾ×öºÃÁËËùÓеÄÒôÉ«¡¢¿ØÖÆ»·½Ú£¬ÄÇôȷʵ¿ÉÒÔÏÈ×öÒôÁ¿Æ½ºâ¡£
TIP 3 - Time is of the essence ʱ¼äµÄÀûÓÃÂÊÖÁÉÏ
Mixing is a race against the clock. Don¡¯t waste time. Make the most of every second.
WB Studios£º»ìÒôÒª°ÑÎÕºÃʱ¼äµÄ½Ú×࣬ÒÔ¼°×öºÃʱ¼äµÄ¹æ»®£¬±ÈÈç²»Òª°ÑһЩ±à¼ÐÞÕýµÄ¹¤×÷ÒÔ¼°×¼±¸µÄ¹¤×÷²ôÔÓµ½ÄãµÄ»ìÒôʱ¼äÀʱ¼äЧÂÊÒ²ÊÇÄãworkflowµÄÒ»²¿·Ö¡£
TIP 4 - Focus on the key elements ¾Û½¹ÓڹؼüÔªËØ
Don¡¯t waste 30 minutes tweaking a shaker. Focus on the vocals, drums, lead guitar etc.
WB Studios£ºÍ¨³£Ò»¸ö»ìÒô×÷Æ·×îÖØÒªµÄÔªËØÊÇ×îÖµµÃÎÒÃÇ»¨Ê±¼äÈ¥×ÁÄ¥ºÍ·´¸´µñ×ÁµÄ£¬Í¨³£»ù±¾¼Ü¹¹ÅªºÃÁË£¬Ò»Ê×»ìÒôÊDz»»á²îµÄ¡£
TIP 5 - Loop the loudest section of the song ´ÓÏì¶È×î´óµÄ²¿·Ö×ÅÊÖ
Get the mix right here first and then automate and check the rest of the song.
WB Studios£ºÒ»°ã´Ó¸±¸è£¨Ïì¶È×î´óµÄµØ·½£©¿ªÊ¼loop»ì£¬ÕâÑù·½±ãƽºâÕûÊ׸èµÄ¶¯Ì¬¡£
TIP 6 - Start with the bigger picture ´ó¼Ü¹¹¹ÛÄî
Leave the finer details to the end of the mix. After balancing, I address the mix buss and group busses (where most of my processing is) before individual channels.
WB Studios£ºÍ¬ÑùµÄ£¬´Ó×î´óµÄ»ù±¾¼Ü¹¹¿ªÊ¼×ÅÊÖ£¬¿ÉÒÔÖ±½ÓÒÔÄã×Ô¼ºµÄsubmix×éΪµ¥Î»È¥´î½¨£¬²»ÒªÔÚ¸Õ¿ªÊ¼È¥¾À½áµ¥¶À·Ö¹ìµÄ´¦Àí¡£
TIP 7 - Avoid the solo button É÷ÓÃsolo
If you can¡¯t hear what you¡¯re doing, just turn the channel up instead of hitting solo.
WB Studios£ºÒòΪÑÚ±ÎЧӦµÄ´æÔÚ£¬²»Òªµ¥¶ÀµØsoloÒ»¸ö¹ìµÀÈ¥´¦Àí¡£¾¡Á¿ÔÚÒ»¸öÕûÌåÀïÈ¥ñöÌýÉùÒôµÄ±ä»¯¡£
TIP 8 - Have an intention behind every move Ïȶ¯ÄÔ£¬ÔÙ¶¯ÊÖ
Think about what you want to achieve before you adjust anything.
WB Studios£ºÕâÊdzõѧÕß×îÈÝÒ×·¸µÄÒ»¸ö´íÎó£¬Äãµ½µ×ÏëҪʲôÑùµÄÉùÒô£¿²»ÖªµÀ£¿ÄÇΪºÎÄãÒª²Ù×÷£¿ËùÒÔÐÄÀïÒ»¶¨ÒªÏÈÓÐÒ»¸öÒôÏìµÄÆÚ´ýÄ¿±ê£¬ÔÙÈ¥¸ù¾ÝÄãµÄÄ¿±êȥ˼¿¼ÄãµÄ²Ù×÷¡£
TIP 9 - Check your moves ¼ì²éÄãµÄ²Ù×÷
Always bypass to check that you¡¯ve made an improvement (don¡¯t be afraid to start again if you haven¡¯t). Adjust the output so you aren't tricked by a change in volume.
WB Studios£ºÔÚProtoolsÀÎÒºÜϲ»¶ÓÃshift+AÈ¥¶Ô±ÈÎÒ´¦ÀíǰºóÉùÒôµÄ²îÒ죬¶øÇÒҪעÒ⣬Ïì¶È²»Í¬µÄ¶Ô±ÈÊÇûÓÐÒâÒåµÄ¡£Í¬ÑùµÄ£¬Ò²²»ÄÜsoloµØÈ¥¶Ô±È£¬ÒòΪͨ³£´¦ÀíÖ®ºóµÄÉùÒô¿ÉÄܱÈÔÊ¼ËØ²ÄÄÑÌý£¬µ«ÊǷŵ½ÕûÀíÀȴÊÇ×îºÏÊʵġ£
TIP 10 - Use good reference tracks ʹÓúõIJο¼
Choose a well produced track in a similar genre and constantly compare while mixing. You can use several references - one for vocals, one for drums etc.
WB Studios£º»ìÒô¹¤×÷µÄʱºò£¬¿ÉÒÔ²»¶Ï¶Ô±ÈһЩÓÅÐãµÄ×÷Æ·À´²Î¿¼£¨¾¡Á¿ºÍÄã×Ô¼ºµÄ×÷Æ·µÄ·ç¸ñÅäÆ÷¶¼ÒªÏàËÆ£©Õâµã¶ÔÓÚÐÂÊÖÀ´ËµÓÈÎªÖØÒª¡£Í¬ÑùµÄ£¬»ìÒôÀÏÅÚÒ²ÐèÒª×Ô¼ºµÄ²Î¿¼Çú¿â£¬Í¨³£¿ÉÒÔÊÇ×Ô¼ºÔø¾µÄÓÅÐã×÷Æ·£¬·½±ã×Ô¼ºÈ¥µ½²»Í¬µÄÅï¡¢²»ÊìϤµÄ¼àÌý»·¾³ÏÂÈ¥½øÐй¤×÷£¨ÐÄÇé»òÕß״̬²»ºÃÒ²ÊǺÜÓбØÒªÌý²Î¿¼µÄ£©¡£
TIP 11 - Mix in mono for the majority of the mix µ¥ÉùµÀ»ìÒôÊÇÍ·µÈ´óÊÂ
Flip to stereo at the end to sort your panning. This helps you to create separation with EQ and balancing rather than panning.
WB Studios£ºÕâµã»¹ÊÇ¿´×Ô¼ºµÄworkflow°É£¬ÎÒ¸öÈ˲»Ï°¹ßÔÚ³õÆÚ¾ÍÓõ¥ÉùµÀÈ¥½øÐлìÒô£¬µ«ÊÇ£¬³õÆÚÒ»¶¨ÒªÃ÷È·Ê²Ã´ËØ²ÄÊÇÒ»¶¨Òªµ¥ÉùµÀµÄ£¬Ò»¶¨Òª¾Û½¹ÔÚÖмäµÄ£¬ÕâÊǹؼü¡£
TIP 12 - Listen back on multiple speakers/headphones ÔÚ²»Í¬µÄ¶ú»úºÍÑïÉùÆ÷ÏÂÖØ·Å
I like to constantly flick between my pair of large Yahamas, my single small Auratone style speaker and my open-back headphones. This helps to reveal flaws in your mix and prevent ear fatigue.
WB Studios£ºÒ»·½Ãæ¿ÉÒÔ¶Ô±ÈÄãµÄ×÷Æ·£¬ÔÚ²»Í¬µÄÌõ¼þÏÂÖØ·ÅµÄʱºòÊDz»ÊǶ¼×ã¹»ok£¬ÁíÒ»·½Ãæ¿ÉÒÔÔö¼ÓÄã»ìÒôµÄ»ý¼«¶ÈÒÔ¼°´ø¸øÄãÁíÍâµÄÐÂÏʸÐÊÜ¡£
TIP 13 - Mix at a low volume µÍÒôÁ¿»ìÒô
The ideal volume for mixing is around casual speech level. You should be able to easily talk to somebody else in the room without raising your voice.
WB Studios£ºµÍÒôÁ¿»ìÒô£¬ËäȻ˵ÒòΪµÈÏìÇúÏߣ¬ÆµÆ×µÄ¸ÐÖª²»³ä·Ö£¬µ«ÊÇÕâ¿ÉÒÔ¼ì²é×Ô¼ºµÄ»ìÒô»ù´¡¼Ü¹¹ÊÇ·ñ±ÈÀýºÏÊÊ¡£
TIP 14 - Take regular breaks ¶àÐÝÏ¢
Ear fatigue is a mix killer.
WB Studios£º¶ú¶äµÄÆ£ÀÍÊÇÄ㹤×÷µÄ´óµÐ¡£
TIP 15 - Assume that volume automation is needed ÒôÁ¿×Ô¶¯»¯ÊǷdz£ÐèÒªµÄ
It¡¯s rarely possible to get a perfect balance throughout the entire song without some volume automation.
WB Studios£º²»×ö×Ô¶¯»¯£¬²»Ì«¿ÉÄÜ×öµ½ÍêÃÀµÄƽºâ¡£
TIP 16 - You don¡¯t need a load of expensive plugins ²»ÐèҪʲô°º¹óµÄ²å¼þ¡£
You can get a great mix with stock plugins. It often helps to limit your options, too - so the less plugins you use the better.
WB Studios£ººÃµÄ»ìÒôÆäʵ²å¼þ²»Êǹؼü£¬Ó²¼þÉ豸Ҳ²»Êǹؼü£¬Æäʵֻռµ½ÁËÒ»³É°É¡£¶øÇÒÑо¿²å¼þ¡¢Ó²¼þµÄʱ¼ä³É±¾ÊǺܴóµÄ£¬Õâ¸öʱ¼ä²»Èç¶àÌýÌýÒôÀÖ£¬¶à»ì¼¸Ê׸裬¶ÔÓÚËùνµÄÒôÖʵÄÌáÉýµÄ°ïÖúÊÇ×î´óµÄ¡£ |
