Millennia HV-3D-4 »°Í²·Å´óÆ÷
3452870
2007-4-8 12:09:06
ÆäËü²úÆ·
HV-3D ËÄ»ò°ËͨµÀ»°Í²Ç°Ö÷ŴóÆ÷-Í»³öÌØµã
¡ñ ·ÖÁ¢Ôª¼þ¾§Ìå¹Üºó¼¶
¡ñ ±ê×¼¸ß·Ö±æÂÊÔöÒæ¿ª¹Ø(36²½½ø)
¡ñ ͨµÀÔö񾮴Åäµ½ .04 dB ¡ñ ËÄͨµÀ»ò°ËͨµÀÁ½ÖÖ¹æ¸ñ
¡ñ ÍêÈ«ÆÁ±ÎµÄ»·ÐͱäѹÆ÷¹©µç ¡ñ ÇáËÉÔÙÏÖ±ÆÕæµÄÒôÀÖ¶¯Ì¬ HV-3D ËÄ»ò°ËͨµÀ»°Í²Ç°Ö÷ŴóÆ÷-ÏêÏ¸ÌØÐÔ ¸ßËÙÎÞ±äѹÆ÷Éè¼Æ 23 dB ÊäÈëºÍ32 dB Êä³ö´ó¶¯Ì¬¿Õ¼ä (²»ÐèË¥¼õ) ÍêȫƽºâµÄÒôƵ·¾¶ ËùÓÐͨµÀ¶¼¿ÉÑ¡Ôñ B&K (DPA) +130 VÊäÈë ËùÓÐͨµÀ¶¼Ñ¡ÔñDC-COUPLED RIBBON INPUTS ¹âÏËÊä³ö ×Üг²¨Ê§Õæ²»¸ßÓÚ0.0005% HV-3D ËÄ»ò°ËͨµÀ»°Í²Ç°Ö÷ŴóÆ÷-¼¼ÊõÖ¸±ê ×îСÔöÒæ£º8.5 dB ×î´óÔöÒæ (ÿ²½1.5 dB, 36²½½ø)£º60.5 dB (up to 78 dB on rqst) ƵÂÊÏìÓ¦ +0 / -3 dB£º4 Hz £­300 kHz Á¢ÌåÉù·ÖÀë¶È £º< .04 dB ÔëÉù@ 60 dB ÔöÒæ, 10 Hz - 30 kHz, ÆÕͨÊäÈ룺-133 dB EIN ÔëÉù @ 60 dB ÔöÒæ, 10 Hz - 30 kHz, 50 ¦¸ÐźÅÔ´£º-130 dB EIN ÔëÉù @ 60 dB ÔöÒæ, 10 Hz - 30 kHz, 150 ¦¸ ÐźÅÔ´£º-128 dB EIN ×Üг²¨Ê§Õæ + ÔëÉù, 35 dB ÔöÒæ, 10 Hz - 20 kHz ´ø¿í, +27 dBu Êä³ö£º< .001%, µäÐÍ. < .0005%(< 5 PPM) »¥µ÷Ê§Õæ (50 Hz & 7 kHz) 35 dB ÔöÒæ, +27 dBu Êä³ö£º< .0009% ÏàÎ»Ê§Õæ 35 dB Gain, 50 Hz - 20 kHz ´ø¿í, +27 dBu Êä³ö£º< 2 ¡ã ÏàÎ»Ê§Õæ, Á¢ÌåÉù·ÖÀë¶È35 dBÔöÒæ, 20 Hz - 40 kHz ´ø¿í, +27 dBuÊä³ö£º< 1/2 ¡ã ¹²Ä£ÒÖÖÆÂÊ 35 dB ÔöÒæ, 10 Hz - 20 kHz ´ø¿í, 100 mV C.M£º> 65 dB, µäÐÍ > 85 dB ת»»ÂÊ 35 dB ÔöÒæ, +27 dBu Êä³ö£º> 25 V/ms ×î´óÊäÈëµçƽ 20 Hz - 40 kHz£º+23 dBu* ×î´óÊä³öµçƽ20 Hz - 40 kHz£º+32 dBu ͨµÀ´®ÈÅ 35 dB ÔöÒæ, 1 kHz, +27 dBu ËùÓÐÊä³ö£ºÓÅÓÚ -120 dB (> 20 Bits) »ÃÏñÊäÈë×迹 @ 20 Hz £º6,700 Ohms »ÃÏñÊäÈë×迹@ 20 kHz £º6,800 Ohms Êä³ö×迹£º 24.3 ohms (x2) B&K (DPA) »°Í²¹©µç£º+130 VDC, max, direct (non-phantom) powered »ÃÏñ¹©µç£º+48 VDC, +/- 2 VDC ×î´ó¹¦ºÄ£º45 W, µçÔ´ £º100 £­240 VAC, 50/60 Hz Ìå»ý£º19 W x 12 D x 3.5 H
ÆÀÂÛÁÐ±í£¨2£©
Millennia HV-3D-4 »°Í²·Å´óÆ÷ ,:victory:
2007-4-8 19:33:16 »Ø¸´
²»´í²»´í``ºÍºÍ```
2007-4-10 07:00:33 »Ø¸´
