YAMAHA HSϵÁÐ ¼àÌýÒôÏä ¼ÒôÅïרÓÃÒôÏä
É豸
Powered Studio Monitor: HS8/ HS8I/ HS7/ HS7I/ HS5/ HS5I
HS8
HS8I
HS7
HS7I
HS5
HS5I
ÒôÏäÀàÐÍ
2·˫¹¦·ÅÓÐÔ´¹¤×÷ÊÒ¼àÌýÒôÏä
ƵÂÊÏìÓ¦ (-10dB)
38Hz - 30kHz
38Hz - 30kHz
43Hz - 30kHz
43Hz - 30kHz
54Hz - 30kHz
54Hz - 30kHz
Frequency response (-3dB)
47Hz - 24kHz
47Hz - 24kHz
55Hz - 24kHz
55Hz - 24kHz
74Hz - 24kHz
74Hz - 24kHz
²¿¼þ
LF
8" cone
8" cone
6.5" cone
6.5" cone
5" cone
5" cone
HF
1" dome
1" dome
1" dome
1" dome
1" dome
1" dome
·ÖƵ
2kHz
2kHz
2kHz
2kHz
2kHz
2kHz
Êä³ö¹¦ÂÊ
120W (LF:75W, HF:45W)
95W (LF:60W, HF:35W)
70W (LF:45W, HF:25W)
ÊäÈëÁéÃô¶È/×迹
-10 dBu/10k ohms
-10 dBu/10k ohms
-10 dBu/10k ohms
-10 dBu/10k ohms
-10 dBu/10k ohms
-10 dBu/10k ohms
ÊäÈë½Ó¿Ú
XLR3-31 type (balanced), PHONE (balanced)
ָʾµÆ
Power ON (White LED)
ºÄµçÁ¿
60W
60W
55W
55W
45W
45W
ÏäÌåÀàÐÍ
µÍÒô·´ÉäÐÍ
µÍÒô·´ÉäÐÍ
µÍÒô·´ÉäÐÍ
µÍÒô·´ÉäÐÍ
µÍÒô·´ÉäÐÍ
µÍÒô·´ÉäÐÍ
²ÄÁÏ
MDF
MDF
MDF
MDF
MDF
MDF
Íâ¹Û³ß´ç
W
250mm (9-13/16")
250mm (9-13/16")
210mm (8-1/4")
210mm (8-1/4")
170mm (6-11/16")
170mm (6-11/16")
H
390mm (15-3/8")
390mm (15-3/8")
332mm (13-1/16")
332mm (13-1/16")
285mm (11-1/4")
285mm (11-1/4")
D
334mm (13-1/8")
334mm (13-1/8")
284mm (11-3/16")
284mm (11-3/16")
222mm (8-3/4")
222mm (8-3/4")
ÖØÁ¿
10.2kg (22.5 lbs.)
10.7kg (23.6 lbs.)
8.2kg
(18.1 lbs.)
8.7 kg
(19.2 lbs.)
5.3kg
(11.7 lbs.)
5.5 kg
(12.1 lbs.)
¸½¼þ
Owner&££39;s Manual, Power cord
Owner&££39;s Manual, Power cord, Screws for installing brackets x 2
Packaging
Single
Single
Single
Single
Single
Single
ÆäËû
LEVEL control (+4dB/center click) , EQ: HIGH TRIM switch (+/- 2dB at HF) / ROOM CONTROL switch (0/-2/-4 dB under 500Hz)
Flying and mounting hardware
Four surfaces x 2 x M8 (120 mm pitch)
Four surfaces x 2 x M5 (60 mm pitch)
Options
Baton bracket BBS251, Ceiling bracket BCS251, Wall bracket BWS251, Wall / ceiling bracket BWS50
Wall / ceiling bracket BWS20, Ceiling bracket BCS20
Powered Subwoofer: HS8S
HS8S
ÒôÏäÀàÐÍ
ÓÐÔ´³¬µÍÒôÒôÏä
ƵÂÊÏìÓ¦ (-10dB)
22Hz - 160Hz
²¿¼þ
LF
8" cone
Êä³ö¹¦ÂÊ
150W
ÊäÈëÊä³ö½Ó¿Ú
INPUT: XLR3-31 type (balanced) x2, PHONE (balanced) x2 / OUTPUT: XLR3-32 type (balanced) x2 (L&R)
ºÄµçÁ¿
70W
ÏäÌåÀàÐÍ
µÍÒô·´ÉäÐÍ
²ÄÁÏ
MDF
Íâ¹Û³ß´ç
W
300mm (11.8")
H
350mm (13.8")
D
389mm (15.3")
ÖØÁ¿
12.5kg (27.6 lbs.)
ÆäËû
LEVEL control, PHASE switch : NORM./REV., HIGH CUT control (80-120Hz, center click), LOW CUT control (80-120Hz, center click), LOW CUT switch (ON/OFF)
ÆÀÂÛÁÐ±í£¨1£©
YAMAHA HSϵÁÐ ¼àÌýÒôÏä ¼ÒôÅïרÓÃÒôÏä £¡Ö§³Ö£¬ÐÀÉÍ£¡
2007-2-27 10:56:10 »Ø¸´
