»ìÒôÆ÷¹¦ÄÜ (1) µÈ»¯Æ÷ »ìÒôÆ÷¾ß±¸µÈ»¯Æ÷¹¦ÄÜ£¬¿Éµ÷Õû¸÷ÉùµÀµÄÒôÉ«¡£ÓÐЩµÈ»¯Æ÷Ö»ÓÐÁ½¸öƵ¶Î£¬¿Éµ÷Õû¸ßµÍƵ¡£ÓÐЩµÈ»¯Æ÷ÓÐÈý¸öƵ¶Î£¬¿ÉÇ¿»¯»òÏû¼õµÍÖÐ¸ßÆµÀ´¸Ä±äÉùÒô¡£ÓÐЩÈýƵ¶ÎµÈ»¯Æ÷¾ß±¸ÖÐÆµÉ¨Ã蹦ÄÜ£¬¿ÉÓÃÓڸıäÖÐÆµ£¬ÈöàÊýÀÖÆ÷¼°ÈËÉù¸ü¾ßÌØÉ«¡£Æµ¶ÎÔ½¶à£¬ÉùÒôÖÆ×÷Ò²¾ÍԽϸÄå¡£
Knob Characteristic Affected sounds Boost Effect Cut Effect
HIGH 10 kHz (+/- 15 dB)High overtones exceeding the register of the instrument.Crunchy, metallic echoing increases, and the tone becomes sharp. If boosted too much, will sound noisy.Tones become smooth. "S" noise canceling is effective. If cut too much, high range transparency will be lost.
MID 3 kHz (+/- 15 dB)Instrument/vocals high registersSound becomes bright and hard. Sound becomes modulated and bright. If boosted too much, sound will become unpleasant.Audio balance tends toward lows. If cut too much, audio will become dark.
1 kHz (+/- 15 dB)Instrument/vocals medium registers.The outline of the audio can be made clear. Audio sounds as if it is projected forward. Emphasizes the attack of toms and bass drums.Tones become rounded and pleasant. Sounds are more muffled and no longer stand out in the mix.
500 Hz (+/- 15 dB)Instrument/vocals medium-low registers.The sound becomes thicker and more powerful, and tonal balance tends toward lows. If boosted too much, the sound becomes unnatural, as if it were coming out of a telephone.The sound becomes hard and has a feeling of attack. Tonal balance tends toward highs. If cut too much, the sound becomes thinner.
LOW 100 Hz (+/- 15 dB)Instrument low registers.The sound becomes rounder and deeper, giving it more strength and a sense of scale. If boosted too much, the sound becomes less crisp.The sound takes on a lighter quality, improving its crispness. Floor noise or howl canceling is effective.
(2) HPF (¸ßͨÂ˲¨Æ÷)
HPF ÄÜÈ¥³ýÊäÈëÖв»±ØÒªµÄµÍƵ¡£´ó²¿·ÖÂó¿Ë·çºÍMIC/ÏßÐÔÊäÈë¶¼ÓÐHPF ¹¦ÄÜ£¬µ«²¿·Ö´¿ÏßÐÔÊäÈë¿ÉÄÜÎ޴˹¦ÄÜ¡£
HPF ͨ³£ÓÃÓÚС¹Ä¡¢½Å̤îàºÍÈËÉù£¬½èÒÔÈ¥³ý²»±ØÒªµÄµÍƵ£¬²¢ÒԴ˲úÉú¸ü´¿¾»µÄÉùÒô¡£HPF Ò²¿ÉÓÃÓÚÔÚÈËÉùÊÕÒô(ÀýÈçÑݽ²) ʱÏû³ý²»±ØÒªµÄÆøÒô¡£
(3) ×óÓÒÏàλ
¿Éµ÷Õû´Ó×óÓÒÀ®°È²¥·ÅÒôѶʱµÄÊä³ö±ÈÂÊ¡£Õâͨ³£ÓÃÓÚÈÃÉùÒôÓ°Ïñ¸ü¼Ó¿ªÀ«£¬»òµ÷Õû¸÷ÊäÈëÏà¶ÔÓÚÆäÎę̀ÉÏλÖõĶ¨Î»¡£¶øÁ¢ÌåÉùµÀµÄÒôѶÒÑÉèΪÁ¢ÌåÉùÓ°Ïñ£¬Òò´Ë¿ÉʹÓÃBAL ¿ØÖÆÀ´µ÷Õû×óÓÒÀ®°È¼äµÄƽºâ¡£
(4) ÒôÁ¿ÍƸË/ÐýÅ¥
ÕâЩ¿ØÖƿɵ÷Õû¸÷ÉùµÀ¡¢Èº×é¼°Á¢ÌåÉùÊä³öµÈµÄÒôÁ¿¡£ÍƸËʽµÄ¿ØÖƿɽøÐпìËÙ²Ù×÷¡£µ«ÈÔÓÐЩ»ìÒôÆ÷»¹ÔÚʹÓÃÐýÅ¥ÀàÐ͵ÄÒôÁ¿¿ØÖÆÆ÷¡£ |
