»ìÒôÈíʵÏÖ
alone68
2006-6-26 00:16:00
ÒôÊÓÆµ
»ìÒôÈíʵÏÖ
Hi !!!!
I am not sure weather I have fully understood your question or not, I persume that you are asking
"How can we mix two or more audio stream", If this is the question then I am explaning below the
mixing of the two audio stream (You Can Mix More Audio Stream),
Step 1,
Get the Raw data of the two files, (Example, of the sample 8bit and 8Kh, means one sample is of
8bit)
Step 2
Let the two audio signal be A and B respectively, the range is between 0 and 255.  Where A and B are the
Sample Values (Each raw data) And store the resultant into the Y
If Both the samples Values are possitve
Y = A  +  B - A * B / 255
Where Y is the resultant signal which contains both signal A and B, merging two audio streams into single
stream by this method solves the  problem of overflow and information loss to an extent.
   If the range of 8-bit sampling is between -127 to 128
   If both A and B are negative
Y = A +B - (A * B / (-127))
   Else
Y = A + B - A * B / 128
Similarly for the nbit (ex 16bit data)
   For  n-bit sampling audio signal
Y = A + B - (A * B  /  (-(2 pow(n-1) -1)))
   Else
Y = A + B - (A * B /  (2 pow(n-1))
Step 3.
Add the Header to the Resultant (mixed) data and play back.
If some thing is unclear and ambigious let me know.
Regards
Ranjeet Gupta.
»¹Óмòµ¥C³ÌÐòʾÒâ´úÂ룬µ«ÊÇÆäÖаüº¬Á˺ËÐÄËã·¨£º
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#include <math.h>
int main(int argc,char *argv[]) {
  char mixname[255];
  FILE *pcm1, *pcm2, *mix;
  char sample1, sample2;
  int value;
  pcm1 = fopen(argv[1],"r");
  pcm2 = fopen(argv[2],"r");
  strcpy (mixname, argv[1]);
  strcat (mixname, "_temp.wav");
  mix = fopen(mixname, "w");
  while(!feof(pcm1)) {
    sample1 = fgetc(pcm1);
    sample2 = fgetc(pcm2);
    if ((sample1 < 0) && (sample2 < 0)) {
      value = sample1 + sample2 - (sample1 * sample2 / -(pow(2,16-1)-1));
    }else{
      value = sample1 + sample2 - (sample1 * sample2 / (pow(2,16-1)-1));
    fputc(value, mix);
  fclose(pcm1);
  fclose(pcm2);
  fclose(mix);
  return 0;
ÁíÍ⣬Èç¹ûÖ»ÊÇÔÚSymbianÉÏʵÏÖ»ìÒô£¬ÔÚNokia µÄ¹Ù·½ÍøÕ¾ÉÏ£¬Ò²ÓÐÒ»¸öSoundMixerµÄexamples
http://www.forum.nokia.com/info/ ... ample_v1_0.zip.html
ÆÀÂÛÁÐ±í£¨2£©
»ìÒôÈíʵÏÖ ·ÖÏí
2006-6-26 07:15:00 »Ø¸´
alone68 Â¥Ö÷
<p>ллºÏÃù°¡&nbsp;
2006-6-26 07:50:00 »Ø¸´
