ºÃÀ³Îë±ßÔµÒôЧ¿â Foley Impact ÒôЧ Vol.2 FLAC
ÒÕÊõ¼Ò£ººÃÀ³Îë±ßÔµÒôЧ¿â
±êÌ⣺Foley Impact ÒôЧ Vol.2 FLAC
±êÇ©£ºHot Ideas
TEAM DjYOPMiX
¸ñʽ£º FLAC
ÀàÐÍ£ºÒôЧ
The Hollywood Edge Sound Effects Library - Foley Impact Sound Effects Vol.2 FLAC
ÇúÄ¿:
001 Light Wood Hit with Small Echo Take 1 00:07
002 Light Wood Hit with Small Echo Take 2 00:07
003 Light Wood Hit with Small Echo Take 3 00:07
004 Light Wood Hit with Small Echo Take 4 00:07
005 Light Wood Hit with Small Echo Take 5 00:07
006 Light Wood Hit with Small Echo Take 6 00:07
007 Muffled Wood Thud Impact Take 1 00:07
008 Muffled Wood Thud Impact Take 2 00:07
009 Muffled Wood Thud Impact Take 3 00:07
010 Muffled Wood Thud Impact Take 4 00:07
011 Muffled Wood Thud Impact Take 5 00:07
012 Muffled Wood Thud Impact Take 6 00:07
013 Muffled Wood Thud Impact Take 7 00:06
014 Single Light Hit with Wood Bat Take 1 00:07
015 Single Light Hit with Wood Bat Take 2 00:07
016 Single Light Hit with Wood Bat Take 3 00:07
017 Single Light Hit with Wood Bat Take 4 00:07
018 Single Medium Wood Bat Hit with Dull Impact Take 1 00:07
019 Single Medium Wood Bat Hit with Dull Impact Take 2 00:06
020 Single Medium Wood Bat Hit with Dull Impact Take 3 00:06
021 Single Medium Wood Bat Hit with Dull Impact Take 4 00:06
022 Single Medium Wood Bat Hit with Dull Impact Take 5 00:06
023 Several Light Wood Pieces Fall to the Ground with Debris Take 1 00:07
024 Several Light Wood Pieces Fall to the Ground with Debris Take 2 00:08
025 Several Light Wood Pieces Fall to the Ground with Debris Take 3 00:08
026 Several Light Wood Pieces Fall to the Ground with Debris Take 4 00:08
027 Several Light Wood Pieces Fall to the Ground with Debris Take 5 00:07
028 Single Heavy Piece of Wood Falls to the Ground Take 1 00:08
029 Single Heavy Piece of Wood Falls to the Ground Take 2 00:07
030 Single Heavy Piece of Wood Falls to the Ground Take 3 00:08
031 Single Heavy Piece of Wood Falls to the Ground Take 4 00:07
032 Single Heavy Piece of Wood Falls to the Ground Take 5 00:07
033 Single Heavy Piece of Wood Falls to the Ground Take 6 00:07
034 Heavy Wood Impact with Big Hit and Debris Fall Take 1 00:08
035 Heavy Wood Impact with Big Hit and Debris Fall Take 2 00:09
036 Heavy Wood Impact with Big Hit and Debris Fall Take 3 00:09
037 Light Wood Fall and Bounce on Ground Take 1 00:07
038 Light Wood Fall and Bounce on Ground Take 2 00:07
039 Light Wood Fall and Bounce on Ground Take 3 00:07
040 Light Wood Fall and Bounce on Ground Take 4 00:07
041 Light Wood Fall and Bounce on Ground Take 5 00:07
042 Lumber Fall and Tumble on Ground with Light Bounce Take 1 00:08
043 Lumber Fall and Tumble on Ground with Light Bounce Take 2 00:08
044 Lumber Fall and Tumble on Ground with Light Bounce Take 3 00:08
045 Lumber Fall and Tumble on Ground with Light Bounce Take 4 00:08
046 Lumber Fall and Tumble on Ground with Light Bounce Take 5 00:09
047 Lumber Fall and Tumble on Ground with Light Bounce Take 6 00:11
048 Lumber Fall and Tumble on Ground with Light Bounce Take 7 00:09
049 Short, Heavy Wood Fall with Light Chain Rattle and Debris Take 1 00:08
050 Short, Heavy Wood Fall with Light Chain Rattle and Debris Take 2 00:09
051 Short, Heavy Wood Fall with Light Chain Rattle and Debris Take 3 00:10
052 Short, Heavy Wood Fall with Light Chain Rattle and Debris Take 4 00:10
053 Short, Heavy Wood Fall with Light Chain Rattle and Debris Take 5 00:11
054 Distant Single Wood Drop and Bounce on Hard Surface Take 1 00:08
055 Distant Single Wood Drop and Bounce on Hard Surface Take 2 00:09
056 Distant Single Wood Drop and Bounce on Hard Surface Take 3 00:08
057 Single Quick Metal Impact on Wood with Light Debris Take 1 00:07
058 Single Quick Metal Impact on Wood with Light Debris Take 2 00:07
059 Single Quick Metal Impact on Wood with Light Debris Take 3 00:07
060 Single Quick Metal Impact on Wood with Light Debris Take 4 00:06
061 Single Quick Metal Impact on Wood with Light Debris Take 5 00:07
062 Single Quick Metal Impact on Wood with Light Debris Take 6 00:07
063 Single Quick Metal Impact on Wood with Light Debris Take 7 00:07
064 Single Quick Metal Impact on Wood with Light Debris Take 8 00:07
065 Single Quick Metal Impact on Wood with Light Debris Take 9 00:07
066 Single Quick Metal Impact on Wood with Light Debris Take 10 00:07
067 Single Metal Thud on Wood with Light Clang Take 1 00:06
068 Single Metal Thud on Wood with Light Clang Take 2 00:06
069 Single Metal Thud on Wood with Light Clang Take 3 00:07
070 Single Metal Thud on Wood with Light Clang Take 4 00:07
071 Single Metal Thud on Wood with Light Clang Take 5 00:08
072 Single Metal Thud on Wood with Ring out and Light Debris Take 1 00:07
073 Single Metal Thud on Wood with Ring out and Light Debris Take 2 00:07
074 Single Metal Thud on Wood with Ring out and Light Debris Take 3 00:07
075 Single Metal Thud on Wood with Ring out and Light Debris Take 4 00:07
076 Single Metal Thud on Wood with Ring out and Light Debris Take 5 00:07
077 Single Metal Thud on Wood with Ring out and Light Debris Take 6 00:07
078 Single Metal Thud on Wood with Ring out and Light Debris Take 7 00:07
079 Single Metal Thud on Wood with Ring out and Light Debris Take 8 00:07
080 Single Metal Thud on Wood with Ring out and Light Debris Take 9 00:07
081 Single Heavy Thump Impact on Wood with Debris Fall Take 1 00:07
082 Single Heavy Thump Impact on Wood with Debris Fall Take 2 00:07
083 Single Heavy Thump Impact on Wood with Debris Fall Take 3 00:08
084 Single Heavy Thump Impact on Wood with Debris Fall Take 4 00:07
085 Single Heavy Thump Impact on Wood with Debris Fall Take 5 00:07
086 Single Hard Reverberant Wood Hit with Light Debris Take 1 00:07
087 Single Hard Reverberant Wood Hit with Light Debris Take 2 00:07
088 Single Hard Reverberant Wood Hit with Light Debris Take 3 00:06
089 Heavy Wood Impact on Metal with Crack and Rattle Take 1 00:07
090 Heavy Wood Impact on Metal with Crack and Rattle Take 2 00:07
091 Heavy Wood Impact on Metal with Crack and Rattle Take 3 00:07
092 Heavy Wood Impact on Metal with Crack and Rattle Take 4 00:07
093 Heavy Wood Impact on Metal with Crack and Rattle Take 5 00:07
094 Single Ax Hit on Wood with Splinter and Lots of Debris Take 1 00:07
095 Single Ax Hit on Wood with Splinter and Lots of Debris Take 2 00:07
096 Single Heavy Wood Ax Impact with Heavy Debris Take 1 00:08
097 Single Heavy Wood Ax Impact with Heavy Debris Take 2 00:07
098 Single Heavy Wood Ax Impact with Heavy Debris Take 3 00:08
099 Single Heavy Wood Ax Impact with Heavy Debris Take 4 00:08
100 Single Heavy Wood Ax Impact with Heavy Debris Take 5 00:07
101 Single Heavy Wood Ax Impact with Heavy Debris Take 6 00:08
102 Sandy Bullet Thud into Wood Take 1 00:07
103 Sandy Bullet Thud into Wood Take 2 00:07
104 Sandy Bullet Thud into Wood Take 3 00:07
105 Sandy Bullet Thud into Wood Take 4 00:07
106 Sandy Bullet Thud into Wood Take 5 00:07
107 Sandy Bullet Thud into Wood Take 6 00:07
108 Sandy Bullet Thud into Wood Take 7 00:07
109 Hard Bullet Thud into Wood Take 1 00:06
110 Hard Bullet Thud into Wood Take 2 00:06
111 Hard Bullet Thud into Wood Take 3 00:06
112 Hard Bullet Thud into Wood Take 4 00:06
113 Hard Bullet Thud into Wood Take 5 00:06
114 Hard Bullet Thud into Wood Take 6 00:06
115 Bullet Thud into Wood with Rattle Take 1 00:06
116 Bullet Thud into Wood with Rattle Take 2 00:06
117 Bullet Thud into Wood with Rattle Take 3 00:07
118 Bullet Thud into Wood with Rattle Take 4 00:07
119 Bullet Thud into Wood with Rattle Take 5 00:07
120 Hard Bullet Impact into Wood Take 1 00:06
121 Hard Bullet Impact into Wood Take 2 00:06
122 Hard Bullet Impact into Wood Take 3 00:06
123 Hard Bullet Impact into Wood Take 4 00:06
124 Hard Bullet Impact into Wood Take 5 00:07
125 Bullet Hits Wood with Crack and Crunch Take 1 00:06
126 Bullet Hits Wood with Crack and Crunch Take 2 00:06
127 Bullet Hits Wood with Crack and Crunch Take 3 00:06
128 Bullet Hits Wood with Crack and Crunch Take 4 00:06
129 Bullet Hits Wood with Crack and Crunch Take 5 00:06
130 Bullet Hits Wood with Crack and Crunch Take 6 00:06
131 Multiple Fast Bullet Impacts into Wood with Metallic Bangs 00:06
132 Break Down Wood Door with Thud Impacts and Rattle Take 1 00:08
133 Break Down Wood Door with Thud Impacts and Rattle Take 2 00:07
134 Break Down Wood Door with Thud Impacts and Rattle Take 3 00:07
135 Wood Impact and Crash with Splinters and Debris Take 1 00:09
136 Wood Impact and Crash with Splinters and Debris Take 2 00:10
137 Wood Impact and Crash with Splinters and Debris Take 3 00:08
138 Wood Impact and Crash with Splinters and Debris Take 4 00:09
139 Wood Impact and Crash with Splinters and Debris Take 5 00:08
140 Wood Impact and Crash with Splinters and Debris Take 6 00:08
141 Heavy Wood Impact and Crash with Boards and Debris Take 1 00:08
142 Heavy Wood Impact and Crash with Boards and Debris Take 2 00:08
143 Heavy Wood Impact and Crash with Boards and Debris Take 3 00:07
144 Heavy Wood Impact and Crash with Boards and Debris Take 4 00:07
145 Heavy Wood Impact and Crash with Boards and Debris Take 5 00:08
146 Heavy Wood Impact and Crash with Boards and Debris Take 6 00:09
147 Heavy Wood Crash and Fall to the Ground with Light Debris Take 1 00:10
148 Heavy Wood Crash and Fall to the Ground with Light Debris Take 2 00:09
149 Wood Crash with Debris Fall Take 1 00:08
150 Wood Crash with Debris Fall Take 2 00:09
151 Subsonic Thud and Wood Crash with Debris Fall Take 1 00:09
152 Subsonic Thud and Wood Crash with Debris Fall Take 2 00:08
153 Subsonic Thud and Wood Crash with Debris Fall Take 3 00:08
154 Subsonic Thud and Wood Crash with Debris Fall Take 4 00:09
155 Subsonic Thud and Wood Crash with Debris Fall Take 5 00:10
156 Subsonic Thud and Wood Crash with Debris Fall Take 6 00:11
157 Heavy Wood Cracks and Splinters with Heavy Debris Fall and Bounce Take 1 00:19
158 Heavy Wood Cracks and Splinters with Heavy Debris Fall and Bounce Take 2 00:08
159 Heavy Wood Cracks and Splinters with Heavy Debris Fall and Bounce Take 3 00:05
160 Heavy Wood Cracks and Splinters with Heavy Debris Fall and Bounce Take 4 00:10
161 Heavy Wood Cracks and Splinters with Heavy Debris Fall and Bounce Take 5 00:07
162 Heavy Wood and Glass Crash with Debris Take 1 00:07
163 Heavy Wood and Glass Crash with Debris Take 2 00:08
164 Heavy Wood and Glass Crash with Debris Take 3 00:08
165 Heavy Wood and Glass Crash with Debris Take 4 00:07
166 Heavy Wood and Glass Crash with Debris Take 5 00:08
167 Heavy Wood and Glass Crash with Debris Take 6 00:08
168 Heavy Wood and Glass Crash with Debris Take 7 00:08
169 Wood Creak and Crash with Debris Fall Take 1 00:09
170 Wood Creak and Crash with Debris Fall Take 2 00:12
171 Wood Breaks with Stress and Twists Take 1 00:17
172 Wood Breaks with Stress and Twists Take 2 00:09
173 Wood Breaks with Stress and Twists Take 3 00:16
174 Wood Breaks with Stress and Twists Take 4 00:13
175 Wood Breaks with Stress and Twists Take 5 00:09
176 Wood Breaks with Stress and Twists Take 6 00:13
177 Wood Breaks with Stress and Twists Take 7 00:17
178 Wood Splinters and Cracks with Board Fall to Ground Take 1 00:08
179 Wood Splinters and Cracks with Board Fall to Ground Take 2 00:07
180 Very Reverberant Wood Crack and Twists Take 1 00:09
181 Very Reverberant Wood Crack and Twists Take 2 00:09
182 Very Reverberant Wood Crack and Twists Take 3 00:07
183 Very Reverberant Wood Crack and Twists Take 4 00:10
184 Very Reverberant Wood Crack and Twists Take 5 00:09
185 Very Reverberant Wood Crack and Twists Take 6 00:11
186 Very Reverberant Wood Crack and Twists Take 7 00:09
187 Very Reverberant Wood Crack and Twists Take 8 00:11
188 Very Reverberant Wood Crack and Twists Take 9 00:08
189 Wood Splits and Tears with Crackle Take 1 00:07
190 Wood Splits and Tears with Crackle Take 2 00:07
191 Wood Splits and Tears with Crackle Take 3 00:07
192 Wood Splits and Tears with Crackle Take 4 00:07
193 Wood Splits and Tears with Crackle Take 5 00:07
194 Wood Splits and Tears with Crackle Take 6 00:07
195 Wood Splinter, Crack or Crunch with Reverb Take 1 00:08
196 Wood Splinter, Crack or Crunch with Reverb Take 2 00:08
197 Wood Splinter, Crack or Crunch with Reverb Take 3 00:09
198 Wood Splinter, Crack or Crunch with Reverb Take 4 00:09
199 Wood Splinter, Crack or Crunch with Reverb Take 5 00:10
200 Wood Splinter, Crack or Crunch with Reverb Take 6 00:17
201 Distant Wood Crack and Splinter Take 1 00:08
202 Distant Wood Crack and Splinter Take 2 00:08
203 Distant Wood Crack and Splinter Take 3 00:08
204 Tree Branch Bends, Cracks, And Splinters with Reverb Take 1 00:12
205 Tree Branch Bends, Cracks, And Splinters with Reverb Take 2 00:12
206 Tree Branch Bends, Cracks, And Splinters with Reverb Take 3 00:10
207 Hit on Wood Door with Cracks and Stress Take 1 00:18
208 Hit on Wood Door with Cracks and Stress Take 2 00:13
209 Hit on Wood Door with Cracks and Stress Take 3 00:11
210 Hit on Wood Door with Cracks and Stress Take 4 00:11
211 Hit on Wood Door with Cracks and Stress Take 5 00:20
212 Light Wood Debris and Grit Falling to Floor Take 1 00:14
213 Light Wood Debris and Grit Falling to Floor Take 2 00:15
214 Glass Break with Light Crash Take 1 00:07
215 Glass Break with Light Crash Take 2 00:08
216 Glass Break with Light Crash Take 3 00:07
217 Glass Break with Light Crash Take 4 00:07
218 Glass Break with Light Crash Take 5 00:07
219 Glass Break with Light Crash Take 6 00:07
220 Glass Break with Light Crash Take 7 00:07
221 Distant Tinkly Glass Break Take 1 00:08
222 Distant Tinkly Glass Break Take 2 00:08
223 Distant Tinkly Glass Break Take 3 00:08
224 Distant Tinkly Glass Break Take 4 00:08
225 Distant Tinkly Glass Break Take 5 00:07
226 Distant Tinkly Glass Break Take 6 00:07
227 Distant Tinkly Glass Break Take 7 00:08
228 Distant Tinkly Glass Break Take 8 00:08
229 Ceramic Pieces Break and Rattle Take 1 00:08
230 Ceramic Pieces Break and Rattle Take 2 00:07
231 Ceramic Pieces Break and Rattle Take 3 00:08
232 Ceramic Pieces Break and Rattle Take 4 00:08
233 Ceramic Pieces Break and Rattle Take 5 00:08
234 Medium Glass Crash with Falling Pieces Take 1 00:07
235 Medium Glass Crash with Falling Pieces Take 2 00:08
236 Medium Glass Crash with Falling Pieces Take 3 00:07
237 Medium Glass Crash with Falling Pieces Take 4 00:07
238 Medium Glass Crash with Falling Pieces Take 5 00:08
239 Medium Glass Crash with Falling Pieces Take 6 00:08
240 Light Metallic Glass Shatter and Crash Take 1 00:07
241 Light Metallic Glass Shatter and Crash Take 2 00:08
242 Light Metallic Glass Shatter and Crash Take 3 00:08
243 Distant Light Glass Shatter Take 1 00:07
244 Distant Light Glass Shatter Take 2 00:07
245 Distant Light Glass Shatter Take 3 00:08
246 Medium Glass Shatter and Crash Take 1 00:07
247 Medium Glass Shatter and Crash Take 2 00:08
248 Medium Glass Shatter and Crash Take 3 00:08
249 Distant Glass Smash and Shatter Take 1 00:07
250 Distant Glass Smash and Shatter Take 2 00:07
251 Distant Glass Smash and Shatter Take 3 00:08
252 Distant Glass Smash and Shatter Take 4 00:08
253 Distant Glass Smash and Shatter Take 5 00:09
254 Distant Glass Smash and Shatter Take 6 00:08
255 Large Pane of Glass Hit and Shattered with Pieces Falling to Ground Take 1 00:09
256 Large Pane of Glass Hit and Shattered with Pieces Falling to Ground Take 2 00:09
257 Large Pane of Glass Hit and Shattered with Pieces Falling to Ground Take 3 00:08
258 Heavy Glass Impact and Crash with Falling Glass Take 1 00:08
259 Heavy Glass Impact and Crash with Falling Glass Take 2 00:09
260 Heavy Glass Impact and Crash with Falling Glass Take 3 00:09
261 Heavy Glass Impact and Crash with Falling Glass Take 4 00:09
262 Heavy Glass Impact and Crash with Falling Glass Take 5 00:08
263 Heavy Glass Impact and Crash with Falling Glass Take 6 00:07
264 Heavy Glass Impact and Crash with Falling Glass Take 7 00:08
265 Heavy Glass Impact and Crash with Falling Glass Take 8 00:14
266 Very Fast Multiple Glass Impacts with Crash and Shatter Take 1 00:09
267 Very Fast Multiple Glass Impacts with Crash and Shatter Take 2 00:08
268 Very Fast Multiple Glass Impacts with Crash and Shatter Take 3 00:08
269 Very Fast Multiple Glass Impacts with Crash and Shatter Take 4 00:07
270 Very Fast Multiple Glass Impacts with Crash and Shatter Take 5 00:09
271 Window Pane or Mirror Breaks Take 1 00:08
272 Window Pane or Mirror Breaks Take 2 00:08
273 Window Pane or Mirror Breaks Take 3 00:09
274 Window Pane or Mirror Breaks Take 4 00:10
275 Window Pane Shatter with Debris Take 1 00:10
276 Window Pane Shatter with Debris Take 2 00:09
277 Window Pane Shatter with Debris Take 3 00:09
278 Window Pane Shatter with Debris Take 4 00:07
279 Light Window Pane Break Take 1 00:07
280 Light Window Pane Break Take 2 00:07
281 Light Window Pane Break Take 3 00:08
282 Distant Light Window Pane Break with Glass Fall 00:06
283 Glass Tube Shatters 00:07
284 Bullet Hits Glass with Medium Impact Take 1 00:08
285 Bullet Hits Glass with Medium Impact Take 2 00:07
286 Bullet Hits Glass with Medium Impact Take 3 00:08
287 Bullet Hits Glass with Medium Impact Take 4 00:08
288 Single Bullet Impact with Glass Break Take 1 00:07
289 Single Bullet Impact with Glass Break Take 2 00:07
290 Single Bullet Impact with Glass Break Take 3 00:07
291 Single Bullet Impact with Glass Break Take 4 00:07
292 Multiple Rapid Bullet Impact Glass Hits 00:07
293 Light Impact of Glass Bulb Drop and Roll with Light Break in Distance Take 1 00:10
294 Light Impact of Glass Bulb Drop and Roll with Light Break in Distance Take 2 00:06
295 Light Bulb Breaks and Shatters Take 1 00:07
296 Light Bulb Breaks and Shatters Take 2 00:07
297 Light Bulb Breaks and Shatters Take 3 00:09
298 Light Bulb Breaks and Shatters Take 4 00:08
299 Fluorescent Bulb Bounces and Breaks Take 1 00:08
300 Fluorescent Bulb Bounces and Breaks Take 2 00:08
301 Single Medium Impact on Windshield with Dull Crash and Crunch Take 1 00:07
302 Single Medium Impact on Windshield with Dull Crash and Crunch Take 2 00:07
303 Single Medium Impact on Windshield with Dull Crash and Crunch Take 3 00:07
304 Single Medium Impact on Windshield with Dull Crash and Crunch Take 4 00:08
305 Heavy Impact on Windshield with Glass Crash and Shatter Take 1 00:08
306 Heavy Impact on Windshield with Glass Crash and Shatter Take 2 00:08
307 Light Glass Hits Floor and Breaks Take 1 00:08
308 Light Glass Hits Floor and Breaks Take 2 00:08
309 Light Glass Hits Floor and Breaks Take 3 00:08
310 Light Glass Hits Floor and Breaks Take 4 00:07
311 Light Glass Hits Floor and Breaks Take 5 00:08
312 Light Glass Drops and Hits Floor with Rattle but No Break Take 1 00:07
313 Light Glass Drops and Hits Floor with Rattle but No Break Take 2 00:11
314 Steady Light Rain of Falling Glass 00:06
315 Very Light Tinkling Rain of Falling Glass Pieces Take 1 00:08
316 Very Light Tinkling Rain of Falling Glass Pieces Take 2 00:09
317 Very Light Tinkling Rain of Falling Glass Pieces Take 3 00:08
318 Medium Glass Debris Falls and Hits Floor Take 1 00:10
319 Medium Glass Debris Falls and Hits Floor Take 2 00:05
320 Medium Glass Debris Falls and Hits Floor Take 3 00:08
321 Medium Glass Debris Falls and Hits Floor Take 4 00:10
322 Medium Glass Debris Falls and Hits Floor Take 5 00:10
323 Medium Glass Debris Falls and Hits Floor Take 6 00:06
324 Medium Glass Debris Falls and Hits Floor Take 7 00:11
325 Medium Glass Debris Falls and Hits Floor Take 8 00:11
326 Medium Glass Debris Falls and Hits Floor Take 9 00:10
327 Heavy Glass Debris Falls and Hits Floor Take 1 00:09
328 Heavy Glass Debris Falls and Hits Floor Take 2 00:14
329 Heavy Glass Debris Falls and Hits Floor Take 3 00:14
330 Heavy Glass Debris Falls and Hits Floor Take 4 00:12
331 Reverberant Glass Debris Movement and Fall Take 1 00:13
332 Reverberant Glass Debris Movement and Fall Take 2 00:11
333 Glass and Metal Crashing Take 1 00:08
334 Glass and Metal Crashing Take 2 00:10
335 Glass and Metal Crashing Take 3 00:11
336 Glass Debris Falling and Crashing on Floor 00:25
337 Glass Stress with Creaks and Tear 00:49
338 Close up Glass Grind with Stress and Squeak Take 1 00:06
339 Close up Glass Grind with Stress and Squeak Take 2 00:20
340 Close up Glass Grind with Stress and Squeak Take 3 00:10
341 Close up Glass Grind with Stress and Squeak Take 4 00:17
342 Close up Glass Grind with Stress and Squeak Take 5 00:10
343 Rubbing or Cleaning Glass Surface with High Glass Squeaks and Light Cloth Movement 00:29
344 Light Knocking on Glass Door Take 1 00:07
345 Light Knocking on Glass Door Take 2 00:08
346 Light Knocking on Glass Door Take 3 00:07
347 Light Knocking on Glass Door Take 4 00:07
348 Light Knocking on Glass Door Take 5 00:07
349 Light Knocking on Glass Door Take 6 00:07
350 Light Knocking on Glass Door Take 7 00:07
351 Glass Bottles Clinking and Rattling Take 1 00:08
352 Glass Bottles Clinking and Rattling Take 2 00:10
353 Glass Bottles Clinking and Rattling Take 3 00:08
354 Glass Bottles Clinking and Rattling Take 4 00:08
355 Glass Bottles Clinking and Rattling Take 5 00:10
356 Glass Bottles Clinking and Rattling Take 6 00:10
357 Light Glass Bottle Drop and Roll Take 1 00:10
358 Light Glass Bottle Drop and Roll Take 2 00:10
359 Light Glass Bottle Drop and Roll Take 3 00:06
360 Light Glass Bottle Drop and Roll Take 4 00:07
361 Light Glass Bottle Drop and Roll Take 5 00:10
362 Heavy Glass Shatter with Impact and Crash Take 1 00:10
363 Heavy Glass Shatter with Impact and Crash Take 2 00:10
364 Heavy Glass Shatter with Impact and Crash Take 3 00:11
365 Heavy Glass Crash and Shatter with Weird Hollow Decay Tones 00:10
366 Very Low-End Impact with Heavy Glass Crash and Shatter Take 1 00:08
367 Very Low-End Impact with Heavy Glass Crash and Shatter Take 2 00:09
368 Very Low-End Impact with Heavy Glass Crash and Shatter Take 3 00:09
369 Very Low-End Impact with Heavy Glass Crash and Shatter Take 4 00:09370 Very Low-End Impact with Heavy Glass Crash and Shatter Take 5 00:11
The Hollywood Edge Sound Effects.txt (350 Bytes, ÏÂÔØ´ÎÊý: 0)
https://www.amazon.com/Hollywood-Foley-Sound-Effects-Vol/dp/B00YFT3R3Y
