Reimagined, retuned and reincarnated ¨C MASSIVE X is the successor to the iconic synthesizer that helped spawn entire genres. Get everything you need to create any sound imaginable. Quickly fix difficult routes to bring your ideas to life ¨C no matter how incredible they may seem ¨C and go further than you thought with expressive, playable modulation. Think about it, type it in and figure out what the future sounds like. MASSIVE X will grow, adapt and evolve with regular free updates inspired and inspired by the cultures it helps to create.
1.4.0 ¨C 2022-05-05
•ADDED New browser which includes filtering by tags, text search, favorites and many other improvements
•ADDED New Bass enhancer insert effect
•ADDED New LP4 filter mode in SVF filter
•ADDED Control Sensitivity menu
•ADDED Version 1.4.0 required for Expansions Beam, Bump and Charge
•IMPROVED Faster preset loading
•KNOWN ISSUE VST3 crashes in Reaper on macOS during scan (but still passes validation)
•KNOWN ISSUE Host automation parameter names are fixed to ¡°Macro¡± in Logic and GarageBand on Apple Silicon computers
https://looptorrent.net/native-instruments-massive-x-v1-4-1-vsti-vsti3-aax-x64/ |
