Meet Sound Forge Pro 16 Suite!
This professional software package for recording, editing and processing high-quality audio files includes a range of powerful plug-ins such as the latest Steinberg SpectraLayers Pro 8 and Melodyne Essential and sets a new standard in audio.
* Personally tested on Windows 8.1 Pro x64 ¨C everything works , in isolated cases small anomalies with the interface graphics were noticed, but this may be due to the lack of a
normal graphics card (I work on a chip built into the CPU). They also confirmed the normal installation and operation in Windows 7 Pro x64 .
Add. information
Steinberg SpectraLayers Pro 8 is the most advanced audio spectrum editor on the market that transforms audio into a unique visual world of multi-dimensional audio data. With such a visual approach and an extensive set of tools, SpectraLayers makes it easy to rearrange, extract and optimize sounds in ways that were previously unimaginable. The new version 8 is the perfect addition to the Sound Forge Pro 16 Suite with improved tools and workflows. This allows automatic processes based on artificial intelligence at several levels to provide the best possible results.
Separation of layers.
Thanks to new tools based on artificial intelligence technology, audio tracks can now be separated in Steinberg SpectraLayers Pro 8. This means that music can be separated and separated into separate layers. Extract vocals, piano, bass, drums and other instruments from stems or separate sound, noise and transition layers. Use the new split feature as a creative tool for remixing new songs.
Integration of external DAWs.
Steinberg SpectraLayers Pro 8 can seamlessly access editing effects from other audio applications, meaning it can be used immediately with the selected audio file. Any changes you make are also synced.
New in version
NEW!
dynamicEQ
wizardFX Modern Reverb
Celemony Melodyne 5 essential
essential FX Suite (11 high-quality effect plug-ins)
Analogue Modeling Suite (4 mastering plug-ins)
Vintage Effects Suite (3 vintage effects)
VariVerb II (versatile reverb plug-ins) in)
Vandal (virtual guitar & bass amps)
https://audiostorrent.com/magix-sound-forge-pro-suite-16-0-0-79-x64/
