Nomad Factory Bus Driver ¹âѧѹËõÆ÷
Bus Driver ÊÇÒ»ÖÖ¹âѧѹËõÆ÷£¬¿ÉÌṩ¹ã·ºµÄѹËõЧ¹û£¬ÈÃÈËÏëÆð 60 Äê´ú×îºÃµÄÀÏʽѹËõÆ÷¡£
ѹËõÊÇÄÇЩ¾­³£±»ÈÏΪÊÇÀíËùµ±È»²¢ÇÒͨ³£Ã»Óгä·Ö·¢»ÓÆäDZÁ¦µÄ¹¤×÷ÊÒÁ÷³ÌÖ®Ò»¡£½ñÌìµÄÖÆ×÷ÈËÈÏΪÔÚ»ìÒôʱÔÚ DAW µÄÿ¸öͨµÀÉ϶¼²åÈëѹËõÆ÷²¢²»ÖØÒª£¬µ«ÊÇÀÏÅɹ¤³Ìʦ±ØÐëѧ»á³ä·ÖÀûÓü¸¸öѹËõµ¥Ôª£¬ÕâʹËûÃÇ´ÓÀïµ½ÍâѧϰËüÃÇÒÔ³ä·ÖÀûÓÃËüÃÇ. Bus Driver ÒÔµç×Ó¹ÜѹËõ»ú¡°»Æ½ðʱ´ú¡±µÄ¾­µäΪÀ¶±¾¡£
Bus Driver Öл¹°üÀ¨Ò»¸ö Tube-Driver ±¥ºÍ¹¦ÄÜ¡£ËüÔÊÐíÄúÌí¼ÓÀÏʽµç×ӹܷŴóÆ÷µÄÉùÒô£¬ÎªÄúÌṩÈý¼«¹Ü¡¢Ëļ«¹ÜºÍÎ弫¹ÜÕæ¿Õ¹ÜµÄ²»Í¬µç×ÓÌØÐÔ¡£Òò´Ë£¬Äú¿ÉÒÔ½«ÄÇЩ¾­µäµç×ӹܣ¨ÀýÈç ECC83¡¢12AX7 µÈ£©µÄ¸´¹ÅÎÂůÌí¼Óµ½ÄúµÄ¹ìµÀ»ò»ìÒô×ÜÏßÉÏ¡£
Nomad Factory Éè¼ÆÁËÒ»¸öÊä³ö¼¶ÈíÏ÷²¨£¬ÒÔÏû³ýÈκÎÊä³öµçƽµÄÊý×ÖÏ÷²¨²¢²úÉú¸üƽ»¬µÄÊ§ÕæÌØÐÔ¡£´Ë¹¦ÄÜÊÇ¶Ô Bus-Driver Öаüº¬µÄ Tube-Driver Saturation Modeling µÄ²¹³ä¡£
Bus Driver is an optical compressor that provides a wide range of compression effects, reminiscent of the best vintage compressors made in the ¡®60s.
Compression is one of those studio processes that is all too often taken for granted and not usually used to its full potential. Today¡¯s producers think nothing of inserting compressors on every single channel of their DAW when mixing, but old school engineers had to learn to make the most of only a few units of compression and this made them learn them inside out to use them to their best advantage. Bus Driver is modelled on the classics from the ¡®golden age¡¯ of tube compressors.
Also included in Bus Driver is a Tube-Driver Saturation feature. It allows you to add the sound of a vintage tube amplifier giving you the differing electronic characteristics of triode, tetrode, and pentode vacuum tubes. So you can add the vintage warmth of the those models of the classic tubes (e.g. ECC83, 12AX7, etc..) to your tracks or on your mix bus.
Nomad Factory designed an Output Stage Soft-Clipping to eliminate digital clipping at any output level and produce a smoother distortion characteristic. This feature is in addition to the Tube-Driver Saturation Modeling included in Bus-Driver.
