PreSonus Studio One Pro 5.5.2 WIN
´´ÔìÎޱ߽硣Éú²úÎÞ¼«ÏÞ¡£ÎÞËùη¾åµØÖ´ÐС£Í¨¹ýÒ»¸öÖ±¹ÛµÄÓ¦ÓóÌÐòÂ¼ÖÆ¡¢ÖÆ×÷¡¢»ìÒô¡¢Ä¸´øºÍÖ´ÐÐËùÓвÙ×÷¡£ Studio One® 5 ÒÔÒ×ÓÃÐÔΪºËÐÄÉè¼Æ£¬ÊÇÄú´Ó¹¤×÷ÊÒµ½Îę̀µÄ´´ÒâºÏ×÷»ï°é¡£ Studio One ÓÉ¿ÉÔöÇ¿ÄúµÄ´´ÔìÁ¦¶øÓÖ²»»á·Á°­ÄúµÄ¹¤¾ßÇý¶¯£»ÎÒÃÇ¿ª´´ÁËËüµÄÍÏ·Åʽ¹¤×÷Á÷³Ì£¬²¢ÔÚÆäËûµØ·½¼ÌÐø±»Ä£·Â¡£ÔÚÆäËû DAW ÖÐÐèÒªÎå¸ö²½ÖèµÄ·±ÖØÈÎÎñͨ³£Ö»ÐèÒª¡­¡­Ò»¸ö¡£Ò»¸öÁ÷ÐеÄÀý×Ó£ºÄú¿ÉÒÔͨ¹ý¼òµ¥µÄÍϷŲÙ×÷½« MIDI ת»»ÎªÒôƵ²¢·µ»Ø¡£
ÄúµÄ´ó²¿·Ö¹¤×÷½«ÔÚ¸èÇúÒ³ÃæÖнøÐУ¬ÔÚÄÇÀïÄú¿ÉÒÔ»ñµÃÎÞÏÞµÄÒô¹ìºÍ×ÜÏߣ¬ÒÔ¼°ÄúÐèÒªÂ¼ÖÆ¡¢×÷Çú¡¢±à¼­ºÍ»ìÒôµÄËùÓÐÆäËûÄÚÈÝ£ºÒ»ÕûÌ×ÓÃÓںϳɣ¨µ¥ÉùµÀºÍ¸´Òô£©Ñù±¾µÄÐéÄâÀÖÆ÷ -ÀÖÆ÷²¥·ÅºÍ½Ú×ࣻÍêÕûµÄ Native Effects ²å¼þÌ×¼þ£¬¾ßÓÐȫеÄÍâ¹ÛºÍ°æ±¾ 5 ÖеÄһЩй¦ÄÜ£¬°üÀ¨Ñ¡¶¨²å¼þÉϵÄ״̬¿Õ¼ä½¨Ä£Ä£ÄâÇý¶¯Æ÷£»ÒÔ¼°ÓÃÓÚ¸èÇú±àÇúºÍÔ­ÐÍÖÆ×÷µÄ¿ª´´ÐÔ¹¤¾ß¡£ Studio One µÄ¶À¼ÒÏîÄ¿Ò³ÃæÈÃÄúÖ»ÐèÍÏ·ÅÄúµÄ¸èÇúÎļþ¼´¿ÉÕÆÎÕÄúµÄÀÖÇú²¢ºÏ³ÉÄúµÄ³ªÆ¬¡£ Studio One ΪÄú´¦Àí°æ±¾¿ØÖƺÍäÖȾ£¬Òò´ËÄúʼÖÕÖªµÀ×Ô¼ºÕýÔÚ´¦Àí×îеĻìÒô¡£
°æ±¾ 5 ÖеÄй¦ÄÜ£ºÎÒÃÇÀûÓÃÁËһЩÂÅ»ñÊâÈÙµÄ Notion notation ¼¼ÊõÀ´Ìí¼ÓÎÒÃǵÄÐÂÀÖÆ×ÊÓͼ¡£²é¿´Í¬Ò»ÀÖÆ×ÉϵĶà¸öÇúÄ¿¡£Í¬Ê±ÔÚÀÖÆ×ºÍ¸ÖÇÙÊÓͼÖв鿴ÏàͬµÄÇúÄ¿¡£Á÷ÏßÐ͵IJ¥·Å·ûºÅÍÐÅÌÈÃÄúÎÞÐèÖØÐÂÂ¼ÖÆÇúÄ¿¼´¿ÉÌí¼Ó½¥Ç¿¡¢²üÒôµÈ¡£ÎÒÃÇ»¹ÎªÏȽøµÄÏÖ´ú MIDI ¿ØÖÆÆ÷Ìí¼ÓÁË MIDI ¸´Òô±í´ïÖ§³Ö¡£
×îºóÒ²ÊÇ×î²»ÖØÒªµÄ¡ª¡ªµÚÒ»´ÎºÍµÚ 5 °æµÄй¦ÄÜ£¬Studio One ¿ÉÒÔ¼ÓÈëÄúµÄÎę̀¡£Ð嵀 Show Page ÔÊÐíÄúͨ¹ýÒ×ÓÚʹÓÃµÄ Setlist ½«ÐéÄâÀÖÆ÷¡¢±³¾°Òô¹ìºÍ²å¼þЧ¹ûÌí¼Óµ½ÄúµÄÏÖ³¡ÀÖÆ÷ÖС£Ã¿ÍíËÜÔìÄúµÄ±íÑݲ¢¸ü¸ÄÄúµÄ½ÚÄ¿£¬»òÕßÔÚÁé¸ÐÀ´Ï®£¨»ò¿ª³¡ÀÖ¶ÓÔËÐÐʱ¼ä½Ï³¤£©Ê±½øÐпìËٱ༭¡£
¶Ëµ½¶ËÖÆ×÷µÄ±ê×¼£¬Ö»ÓÐ Studio One 5 ÓëÄúÎÞ·ìÏνӣ¬´Ó×î³õµÄÁé¸Ðµ½ÍêÕûÖÆ×÷£¬´Ó×îÖÕ»ìÒôµ½Ä¸´ø×¨¼­£¬´ÓÊý×Ö·¢Ðе½ÎèÌ¨ÖÆ×÷¡­¡­ÈÃÄúÕæÕýʵÏÖÎޱ߽紴×÷¡£
Create Without Boundaries. Produce Without Limits. Perform Without Fear. Record, produce, mix, master, and perform all from a single, intuitive application. Designed with ease of use at its core, Studio One® 5 is your creative partner from studio to stage. Studio One is driven by tools that enhance your creativity without getting in the way; we pioneered its drag-and-drop workflow that continues to be imitated elsewhere. Laborious tasks that take five steps in other DAWs usually only take¡­ One. A popular example: you can convert MIDI to audio and back with a simple drag-and-drop.
Most of your work will take place in the Song Page, where you get unlimited tracks and buses, alongside everything else you need to record, compose, edit, and mix: a complete set of virtual instruments for synthesis (mono and poly) sample-instrument playback, and rhythm; a complete suite of Native Effects plug-ins with a fresh new look and some amazing features new in Version 5, including State Space Modeled analog drive on select plug-ins; and groundbreaking tools for song arranging and prototyping. Studio One¡¯s exclusive Project page lets you master your compositions and comp your record, simply by dragging and dropping your Song file. Studio One handles the versioning and rendering for you, so you always know you¡¯re working on the latest mix.
New in version 5: we¡¯ve leveraged some of our award-winning Notion notation technology to add our new Score View. View multiple tracks on the same Score. View the same track in Score and Piano View at the same time. A streamlined pallet of playback symbols lets you add crescendos, trills and more without rerecording your track. We¡¯ve also added MIDI Polyphonic Expression support for advanced, modern MIDI controllers.
Last and far from least¡ªfor the first time and new with version 5, Studio One can join you on stage. The new Show Page lets you add virtual instruments, backing tracks, and plug-in effects to your live instruments with an easy-to-use Setlist. Sculpt your performance and change your show each night, or do a quick edit on the fly when inspiration strikes (or the opening band runs long).
The standard for end-to-end production, only Studio One 5 seamlessly moves with you from initial inspiration to full production, final mix to mastered album, digital release to stage production¡­ and lets you truly create without boundaries.
