Native Instruments Massive X 1.3.3 WiN ºÏ³ÉÆ÷
Massive X ÊÇ Native Instruments µÄÐÂÆì½¢ºÏ³ÉÆ÷£¬ÓÉÓëÆäǰÉíÏàͬµÄÍŶӴòÔì¡£Ëü»ùÓÚ×îÏȽøµÄ¼Ü¹¹£¬ÎªÒÕÊõ¼ÒºÍÉùÒôÉè¼ÆÊ¦µÈÌṩԭʼµÄÉùÒôºÍ¾Þ´óµÄ´´×÷Áé»îÐÔ¡ª¡ªÔÊÐíËûÃÇÒÔËûÃÇϲ»¶µÄÈκη½Ê½´´×÷¡¢µ÷ÖÆºÍÊÔÑéÀ´×Ô´óÁ¿À´Ô´µÄÉùÒô¡£
Õñµ´Æ÷
ÔÚ MASSIVE X µÄºËÐÄ£¬Äú»á·¢ÏÖȫеÄÕñµ´Æ÷²¿·Ö ¨C Äܹ»²úÉú±ÈijЩÕû¸öºÏ³ÉÆ÷¸ü¶àµÄ±ä»¯£¬¾ÍÔÚÔ´Í·¡£´Ó³¬¹ý 170 ÖÖ²¨±íºÍ 10 ÖÖ²»Í¬µÄ¶ÁȡģʽÖнøÐÐÑ¡Ôñ¡ª¡ª´Ó¼¤½øµÄ Gorilla ϵÁе½²¨±íÍäÇúģʽ¡¢Hardsync¡¢¹²Õñ·åµÈµÈ¡ª¡ªÃ¿Ò»ÖÖ¶¼ÓÐ×Ô¼º¶ÀÌØµÄ×ÓģʽºÍ¶îÍâµÄ¿ØÖÆ¡£²¦ÈëÁ½¸öÏàλµ÷ÖÆÕñµ´Æ÷£¬ÎªÖ÷Õñµ´Æ÷×¢Èë¶îÍâµÄÔ˶¯¡£
ÖØÐ¹¹Ïë·ÓÉ
½«ÈκÎÊä³öÁ¬½Óµ½ÈκÎÊäÈ룬¿´¿´»á·¢Éúʲô¡£Ö±¹ÛµÄ·ÓÉÉèÖÃÈÃÄú»ù±¾ÉÏ¿ÉÒÔÖØÐÂÁ¬½Ó MASSIVE X µÄ¸÷¸ö²¿·Ö£¬ÕâÒâζ×ÅÄú¿ÉÒÔÒÔÈκÎÄúϲ»¶µÄ·½Ê½ÅÔͨ¡¢·´À¡ºÍ·¢ËÍÒôƵ¡£»¹¿ÉÒÔ½«µ÷ÖÆÆ÷·ÓÉΪÒôƵԴÒÔ¼¤·¢Êá×´Â˲¨Æ÷µÈÔª¼þ¡£
±íÑÝÕߣºÎªµ÷ÖÆ¶øÉú
ÔÚ Performer ²¿·Ö»æÖƾ«È·µÄµ÷ÖÆÄ£Ê½£¬²¢½«ËüÃÇ·ÖÅ䏸¸´Ôӵġ¢²»¶Ï±ä»¯µÄ²¹¶¡µÄ²ÎÊý£¬»ò¿ØÖÆÉùÒôµÄ±ä»¯¡£È»ºó£¬Äú¿ÉÒÔʹÓà Remote Octave ¿Ø¼þÔÚ¼üÅÌÉÏ´¥·¢ËüÃÇ£¬ÕâÒâζ×ÅÄú¿ÉÒÔÔÚµ¥¸ö Patch ÖлñµÃÕæÕý¿ÉÍæµÄµ÷ÖÆºÍ·á¸»µÄ±íÏÖÁ¦¡£
ʲôÊÇеģº
ÒÑÐÞ¸´ÒôƵÊä³öͨµÀµÄ²»ÕýÈ·³õʼ»¯
¸ñʽ£ºWin64£» AAX*, VSTi
Massive X is Native Instruments¡¯ new flagship synth, built by the same team as its predecessor. Based on a state of the art architecture, it delivers pristine sound, and huge creative flexibility for artists and sound designers alike ¨C allowing them to create, modulate, and experiment with sound from a huge range of sources, in any way they like.
THE OSCILLATORS
At the heart of MASSIVE X you¡¯ll find the completely new oscillator section ¨C capable of producing more variation than some entire synths, right at the source. Choose from over 170 wavetables and 10 different modes of reading them ¨C from the aggressive Gorilla family, to a wavetable-bending mode, Hardsync, Formant, and many more ¨C each with their own unique sub-modes and additional controls. Dial in two phase-modulation oscillators to inject extra movement into the main oscillators.
ROUTING REIMAGINED
Connect any output to any input, and see what happens. The intuitive routing setup lets you essentially rewire parts of MASSIVE X, meaning you can bypass, feedback, and send audio any way you like. It¡¯s also possible to route modulators as audio sources to excite elements such as the comb filter.
PERFORMERS: MADE TO MODULATE
Draw precise patterns of modulation in the Performer section, and assign them to parameters for complex, evolving patches, or for controlled changes to your sound. You can then use the Remote Octave control to trigger them on your keyboard, meaning you get truly playable modulation and huge expressive variety within a single patch.
Whats New:
FIXED Incorrect initialization of audio output channels
Formats: Win64; AAX*, VSTi
Homepage
https://www.native-instruments.com/en/products/komplete/synths/massive-x/
