EVENANT ¨C Mixing Workshop ¨C From Stem to Final Master ¹ÜÏÒÀÖ»ìÒô½Ì³Ì
¹ÜÏÒ»ìÒô¹¤³Ìʦ¹¤×÷Á÷³Ì¼ò½é£¬´Ó´Ê¸Éµ½×îÖÕĸ´ø¡£
»ìÒôȷʵÊÇÒ»¸ö·Ç³£¼è¾ÞµÄÖ÷Ì⣬֪µÀÈçºÎÆ´´ÕÕû¸öÒô¹ì»ìÒôµÄÄÑÌâ»áÈÃÈ˸е½²»ÖªËù´ë¡ª¡ª¼´Ê¹ÄúÖªµÀºÜ¶à»ù±¾µÄ»ìÒôÔÀí¡£
Õâ¾ÍÊÇΪʲôÎÒÃÇÖÆ×÷ÁËÒ»¸öÂ¼ÖÆµÄ»ìÒô¹¤×÷·»£¬ÈÃÄúÉîÈëÁ˽âרҵ»ìÒô¹¤³ÌʦµÄÕæÊµ¹¤×÷Á÷³ÌºÍ·½·¨£¬Õ¹Ê¾ËûÈçºÎ´¦ÀíÇúÄ¿µÄ»ìÒôºÍĸ´ø½×¶Î¡ª¡ª´Ó´ò¿ªÖ÷¸Éµ½×îÖÕĸ´ø.
ͨ¹ý¹¤×÷·»£¬Toby Mason ½«´Ó Evenant ÁªºÏ´´Ê¼ÈË Arn ÄÇÀï»ñµÃÒ»Ê×ÇúÄ¿£¬²¢Õ¹Ê¾»ìÒôºÍÕÆÎÕÇúÄ¿ÒÔ½øÐÐ×îÖÕ½»¸¶µÄÕû¸ö¹ý³Ì¡£
Äú»¹½«Á˽â»ù±¾µÄÉùѧÔÀí¡¢Ëû¶Ô³ÝÂÖµÄÏë·¨¡¢»ìÒôʱµÄÒ»°ã˼ά·½Ê½ÒÔ¼°×î³£¼û»ìÒô²å¼þµÄϸ·Ö¡£
ÔÚ±¾´ÎÑÐÌÖ»á½áÊøÊ±£¬Äú½«Á˽âÉùѧµÄ»ù´¡ÖªÊ¶¡¢Ö÷ÒªµÄ»ìÒô¹¤¾ßÒÔ¼° Toby ÈçºÎ´¦ÀíËûÖÆ×÷µÄÇúÄ¿¡£
Äú½«¹Û¿´Õû¸ö¹ÜÏÒÀֵĻìºÏºÍÕÆÎÕ£¬²¢ÉîÈëÁ˽â»ìºÏÇúÄ¿Óë´óÁ¿´ò»÷ÀÖ¡¢ÈÈßèÇú¡¢ÈËÉùºÍ¼ªËûÉù²¿µÄ»ìºÏ£¬²¢Ñ§Ï°ÈçºÎ´¦ÀíÕâÐ©ÔªËØ¡£
Õâ¸ö¹¤×÷·»²»ÊÇÒ»¸ö´øÓÐÑϸñϵͳµÄ»ù±¾»ìÒô³ÌÐò£¬¶øÊÇÒ»¸öÕæÊµµÄÉú»î£¬¿´¿´ Toby ÔÚËû×÷ΪÂåÉ¼í¶»ìÒô¹¤³ÌʦµÄÈÕ³£Éú»îÖÐËùÀûÓõÄ×Ô¼ºµÄ¹Ûµã¡¢ÔÔòºÍ¹¤×÷Á÷³Ì¡£´ÓËûµÄ×ÜÌå˼ά·½Ê½ºÍËûʹÓõIJå¼þ£¬Ò»Ö±µ½ËûÈçºÎ´¦Àí»ìºÏÖеĸ÷¸öÔªËØ¡£
An Introduction To The Workflow of an Orchestral Mixing Engineer, From Stems to Final Master.
Mixing can indeed be a very daunting subject, and it can feel overwhelming to know how to piece together the puzzle of mixing an entire track ¨C even if you know a lot of basic mixing principles.
That¡¯s why we made a recorded mixing workshop that gives you an insight into the real life workflow and methods of a professional mixing engineer, showing how he approaches the mix and mastering stage of a track ¨C all the way from opening the stems to the final master.
Through the workshop, Toby Mason will take a track from Evenant co-founder Arn and show the entire process of mixing and mastering the track for the final delivery.
You will also get an introduction into fundamental acoustic principles, his thoughts on gear, general mindsets when mixing, as well as a breakdown of the most common mixing plugins.
At the end of this workshop, you will possess an understanding for the fundamentals of acoustics, the main mixing tools, and how Toby approaches the tracks he works on.
You will watch a whole orchestral tack get mixed and mastered, and also get an insight into the mixing of a hybrid track with massive percussion, hits, vocals and guitar parts and learn how to approach those elements.
This workshop is not a fundamental mixing program with a rigid system, but rather a real life look into Toby¡¯s own perspectives, principles and workflows that he utilizes in his daily life as a mixing engineer in Los Angeles. From his overarching mindset, and the plugins he uses, all the way to how he approaches the individual elements in a mix.
https://audioz.download/tutorials/196432-download_evenant-mixing-workshop-from-stem-to-final-master.html |
