CS5269Éè¼Æ×ÊÁÏ|CS5269Éè¼Æ¹æ¸ñÊé|TYPECתHDMI4K60HZ+VGA´øPD3.0ÍØÕ¹Îë·½°¸
ÒôÊÓÆµ
CS5269²ÎÊýÌØÐÔÌØÐÔ
×ÜÔò
 USB Type-C ¹æ·¶ 1.2
¼æÈÝVESA DisplayPort TM(DP) v1.4
¼æÈÝHDMI¹æ·¶v2.0b£¬Êý¾ÝËÙÂʸߴïÿͨµÀ6-Gbps¡£
¼æÈÝUSB PowerDelivery(PD) v 3.0 t
Ö§³ÖËùÓÐUSB Type-C ChannelConfiguration (CC)ͨµÀÅäÖÃ
ÄÚÖþ§Õñ£¬ÎÞÐèÍⲿ¾§Õñ
ÄÚÖÃMCUºÍSPI flash
ǶÈëʽV-sync/H-sync
ǶÈëʽEDID£¨Èç¹ûÖÕ¶ËÉ豸ûÓУ¬CS5269AN½«ÏìÓ¦EDID£©
Ö§³ÖHDCP 1.4ºÍHDCP2.3£¬´øon-chip keysÒÔÖ§³ÖHDCPÖÐ¼ÌÆ÷¡£
Ö§³ÖRGB 4:4:4 8/10λbpcºÍYCbCr 4:4:4¡¢4:2:2¡¢4:2:0 8/10λbpc
192KHz x8ͨµÀµÄ×î´óÒôƵ²ÉÑùÂÊ
LPCMºÍѹËõÒôƵ±àÂë¸ñʽ
ÓÃÓÚоƬ¿ØÖƵĸ¨ÖúͨµÀ¡¢I2CÖ÷»ú½Ó¿Ú
USB Type-C DisplayPort£¨DP£©AltģʽÊäÈ루½ÓÊÕÆ÷£©
USB Type-C¹æ·¶1.2ºÍÏòºó¼æÈÝType-C¹æ·¶1.0
VESA DisplayPort TM v1.4¼æÈÝ¡£Ö§³Ö4-lane
ÄÚÖÃCC¿ØÖÆÆ÷£¬ÓÃÓÚ²åÍ·ºÍ·½Ïò¼ì²â
ÓÃÓÚ³äµçÆ÷ºÍÕý³£Í¨ÐŵÄË«CC¶Ë¿Ú
¸ß´ïHBR2£¨5.4-Gbps£©ÊäÈë¡£ÄÚÖøßÐÔÄÜ×ÔÊÊÓ¦¾ùºâÆ÷¡£Ö§³Ö1-MHz AUX
USB Type-CͨµÀÅäÖã¨CC£©¹¦ÄÜ
USB Power Delivery Spec 3.0 ¼æÈݼ¯³ÉUSB Power Delivery (PD-BMC) PHY.Support for Message Protocol. Ö§³ÖPolicy Engine. Ö§³Öbasic Device Policy Manager
Ö§³ÖÈȲå°Î¼ì²â£¨HPD£©
HDMIÊý×ÖÊä³ö
¼æÈÝHDMI 2.0b
ÿ¸öͨµÀµÄ×î´óÊý¾ÝËÙÂʸߴï6-Gbps
Ö§³Ö¸ß´ï3840 x2160@60Hz »òÕß4096x2160@60Hz
ÒôƵÁ÷´¦Àí
LPCMºÍѹËõÒôƵ±àÂë¸ñʽ
192k Hz x8ͨµÀµÄ×î´óÒôƵ²ÉÑùÂÊÖ§³Ö¸ß¶¯Ì¬·¶Î§£¨HDR£©ÔªÊý¾Ý´¦Àí
VGAÊä³ö½Ó¿Ú
ʱÖÓÆµÂʸߴï210MHzµÄÈýÖØ8λDAC£¨Êýģת»»Æ÷£©
Ö§³Ö¸ß´ï1920x1200@60Hz,1920x1440@60Hz £¨½µµÍÏûÒþ£©£¬2048x1152@60Hz £¨½µµÍÏûÒþ£©£¬ÒÔ¼°2048x1536@60Hz £¨½µµÍÏûÒþ£©
ǶÈëʽV-sync/H-sync»º³å
·ûºÏVESA VSIS v1r2
ÆäËü
Ö§³ÖI2CÖ÷´Ó¸ß´ï400 kHz¡£
HBM 4KVÓÃÓÚÁ¬½ÓÆ÷Òý½Å
8*8mm 68ÕëQFN68·â×°£¬´øe-Pad
Power ¼¼Êõ
    5V/1.0Vϵͳµçѹ£¬¼¯³É3.3V LDOºÍ1.8V LDO¡£
CS5269ÊÇÒ»¿î¸ßÐÔÄÜType-C/DP1.4ÖÁHDMI2.0bºÍVGAת»»Æ÷£¬Éè¼ÆÓÃÓÚUSB Type-CÔ´»òDP1.4Ô´Á¬½Óµ½HDMI2.0b½ÓÊÕÆ÷¡£CS5269¼¯³ÉÁËDP1.4¼æÈݽÓÊÕ»ú¡¢¼æÈÝHDMI2.0bµÄ·¢Éä»úºÍVGAÊä³ö½Ó¿Ú¡£ÁíÍ⣬Á½¸öCC¿ØÖÆÆ÷°üÀ¨CCͨÐÅ£¬ÒÔʵÏÖDPAltģʽºÍPD´«Ê书ÄÜ£¬Ò»¸öÓÃÓÚÉÏÓÎType-C¶Ë¿ÚºÍÁíÒ»¸öÓÃÓÚÏÂÓζ˿ڡ£
DP½Ó¿Ú°üÀ¨4ÌõÖ÷ͨµÀ¡¢¸¨ÖúͨµÀºÍHPDÐźš£×î¸ßÖ§³Ö5.4Gbps(HBR2£©µÄÊý¾ÝËÙÂÊ¡£DP½ÓÊÕ»ú¼æÈÝHDCP1.4ºÍHDCP2.3ÄÚÈݱ£»¤·½°¸¾ßÓÐǶÈëʽÃÜÔ¿£¬ÓÃÓÚÊý×ÖÒôÊÓÆµÄÚÈݵݲȫ´«Êä¡£
HDMI½Ó¿Ú°üÀ¨4¸öTMDSʱÖÓ/Êý¾Ý¶Ô¡¢DDCºÍHPDÐźš£HDMI·¢ÉäÄܹ»Ö§³Ö¸ß´ï6GpbsµÄÊý¾ÝËÙÂÊ£¬×ãÒÔ´¦Àí¸ß´ïFHD 1080p 120HzµÄÊÓÆµ·Ö±æÂʺÍUHD 4k 60Hz¸ñʽ¡£HDMI·¢Éä°üº¬Ö§³ÖHDCP1.4ºÍHDCP2.3¡£ÓÉÓÚ°üº¬HDCP£¬CS5269ÔÊÐí°²È«´«ÊäÊܱ£»¤µÄÄÚÈÝ£¬Ç¶ÈëʽÃÜÔ¿¿ÉÌṩ×î¸ß¼¶±ðµÄHDCPÃÜÔ¿°²È«ÐÔ¡£
  CS5269ÊÇÒ»Öָ߶ȼ¯³ÉµÄµ¥Ð¾Æ¬£¬ÊÊÓÃÓÚ¶à¸öϸ·ÖÊг¡ºÍÏÔʾӦÓã¬ÈçÊÊÅäÆ÷¡¢À©Õ¹ÎëµÈ¡£
CS5269Ó¦ÓÃ;¾¶£º
CS5269×îÐÂ°æ¹æ¸ñÊéÈçÏÂÃæ¸½¼þÖУº
CS5269AN_Datasheet_V1.0.pdf (451.55 KB, ÏÂÔØ´ÎÊý: 0)
