Dear Reality dearVR MONITOR v1.7.0 macOSX Ä£Äâ»ìÒô²å¼þ
tenmid
2021-6-5 17:50:47
×¼±¸ºÃ¸ÄÉÆÄúÔÚ»ìÒôºÍĸ´øÖÐËù×öµÄÿһ¸öÑ¡ÔñÁËÂð£¿Dear Reality µÄРDearVR MONITOR ²å¼þ¿ÉÈÃÄúʹÓÃ×Ô¼ºÏ²»¶µÄ¶ú»úÔÚÀíÏëµÄ²Î¿¼Æ·ÖÊÌýÒôÊÒÖÐñöÌýÒôÀÖ¡£
ʹÓÃdearVR MONITOR£¬ÄúÏÖÔÚ¿ÉÒÔËæÊ±ËæµØ»ìÒô£¬¶øÎÞÐè°º¹óµÄÉùѧÓÅ»¯¿ØÖÆÊÒ¡£ÎÞÂÛÄúÊÇʹÓÃÁ¢ÌåÉù¡¢5.1 »ò 7.1 µÈ»·ÈÆÉù¸ñʽ£¬»¹ÊÇ 5.1.4 ºÍ 9.1.6 µÈ¸´ÔӵĶűÈÈ«¾°Éù¸ñʽ£¬Ëü¶¼ÄÜÈÃÄúÐéÄâµØ½«×Ô¼º´«Ë͵½ÍêÃÀµÄñöÌý¿Õ¼ä¡£
ÎÞÂÛÄúÊÇÔÚ·ÉÏ¡¢ÔÚ¼ÒÀï¡¢ÔÚİÉúµÄ¼ÒôÊÒ£¬»¹ÊÇÔÚàÐÔӵĻ·¾³ÖУ¬dearVR MONITOR ¶¼ÄÜΪÄúÌá¹©ÕæÕý²Î¿¼Æ·ÖʵÄÌýÒôÊÒµÄËùÓкô¦£¬ÈÃÄú¿ÉÒÔ¿ìËÙ¿É¿¿µØÆÀ¹À»ìÒôµÄÖÊÁ¿Ñ¡Ôñ¡ª¡ªÒ»Çж¼À´×ÔÄú×îϲ»¶µÄ¶ú»úµÄÊæÊʶȡ£
DearVR MONITOR ¼ÈÁé»îÓÖÒ×ÓÚʹÓá£Äú¿ÉÒÔ¿ìËÙµ÷ÕûÆäÐéÄâÌýÒôÊÒÒÔÂú×ãÄúµÄ¸öÈËÐèÇó¡£Ö»Ðèµ¥»÷¼¸Ï£¬Äú¾Í¿ÉÒÔ¸ü¸Ä·¿¼äÄ£ÐÍ£¬ÕâÑùÄú¾Í¿ÉÒÔ¾ø¶ÔÈ·¶¨ÄúµÄÎÔÊÒ»ìÒôÔÚ´ÓСÐÍÆû³µµ½µçÓ°ÔºµÄËùÓл·¾³ÖÐÌýÆðÀ´¶¼ºÜ°ô£¡ÔÚ 11 ÖÖ²»Í¬µÄÉùѧ»·¾³ÖнøÐÐÑ¡Ôñ£¬°üÀ¨¾ãÀÖ²¿¡¢¿ÍÌü¡¢Æû³µ¡¢Îę̀¡¢µçÓ°ÔºµÈ¡£
ÎÞÂÛÄúÊÇÏëÌá¸ß¶ú»ú»ìÒôµÄÖÊÁ¿£¬»¹ÊÇÔÚûÓаº¹óµÄ¶àÉùµÀÑïÉùÆ÷ϵͳµÄÇé¿öϼàÌý¸´ÔӵĻ·ÈÆÉù¸ñʽ£¬dearVR MONITOR ¶¼¿ÉÒÔ°ïÖúÄú¸Ä±äñöÌýÒôÀֵķ½Ê½¡£
²»ÐèÒª PA Ðí¿ÉÖ¤»ò KeyGen¡£
https://youtu.be/0o4rPYnzAeQ
OVERVIEW
Ready to improve every choice you make in your mixes and masters? The new dearVR MONITOR plugin from Dear Reality allows you to hear your music in an ideal reference-quality listening room, using your own favorite headphones.
With dearVR MONITOR, you can now mix anywhere, anytime, without the need for an expensive acoustically-optimized control room. It allows you to virtually transport yourself to the perfect listening space, whether you are working in stereo, in a surround sound format like 5.1 or 7.1, or even in complex Dolby Atmos formats like 5.1.4 and 9.1.6.
Whether you¡¯re on the road, at home, in an unfamiliar studio, or a noisy environment, dearVR MONITOR gives you all the benefits of a real reference-quality listening room, so that you can quickly and reliably evaluate the quality of your mix choices¡ªall from the comfort of your own favorite headphones.
dearVR MONITOR is also as flexible as it is easy-to-use. You can quickly adapt its virtual listening room to suit your personal needs. Just a few simple clicks allow you to change the room model so that you can be absolutely certain your bedroom mixes will sound great in everything from a small car to a movie theater! Choose between 11 different acoustic environments including clubs, living rooms, cars, stages, cinemas, and more.
Whether you¡¯re looking to improve the quality of your headphone mixes, or monitor complex surround sound formats without an expensive multi-channel speaker system, dearVR MONITOR can help change the way you hear your music for good.
Doesn¡¯t require a PA license or KeyGen.
