ÎÒÃÇÖªµÀÓÐһЩ¶ÀÁ¢µÄ¡£hdf5ÎļþÒª´¦Àí³ÉÒ»¸ö¡°Êý¾Ý¼¯¡±£¬¶øÇÒÿ¸öÎļþ¶¼ÓÐÒ»Ð©Ææ¹ÖµÄÊý¾Ý½á¹¹¡£ÕâЩÌõ¼þ¿Ï¶¨ÐèÒªÒ»¸ö×Ô¶¨ÒåPyTorch DatasetÀàÀ´ÕýÈ·¼ÓÔØÒôƵÊý¾Ý£¬ÒÔ±ãÒÔºó½øÐÐѵÁ·¡£DatasetÀàÖ÷ÒªÐèҪʣϵÄ__init__ºÍ__getitem__º¯Êý(»¹ÓÐʣϵÄ__len__£¬µ«ÕâºÜ¼òµ¥)¡£ÒÔÏÂÊÇÎҼƻ®Òª×öµÄÊÂÇé:
__init__
±éÀúËùÓÐËĸöÎļþÖеÄÿ¸ö²¨ÐεÄÿ¸ö×éÃû£¬²¢½«ÆäËùÊôµÄÎļþºÍHDF5×é×·¼Óµ½ÊôÓÚ¸ÃÀàµÄÁбíÖС£
»ñÈ¡²¨ÐεıêÇ©(Îļþ/×éÃûµÄ×îºóһλ)²¢½«Æä¸½¼Óµ½ÊôÓÚ¸ÃÀàµÄÁíÒ»¸öÁбíÖС£ÀýÈ磬ÎļþÃûunit0301271222800000_0±íʾûÓÐÄñ½ÐÉù¡£
×¼±¸Ò»¸ö±ä»»º¯Êý£¬Ó¦Óõ½²¨ÐΣ¬½«Æäת»»Îª¹âÆ×ͼ(¾ßÌåµØËµ£¬mel-scaledµÄ¹âÆ×ͼ)£¬²¢¿¼Âǵ½ÆäËûÔöÇ¿¼¼Êõ¡£
__getitem__
ΪÔÚ³õʼ»¯Ö®Ê±´´½¨µÄÁбíÌṩË÷Òý
Ò»µ©Í¨¹ýÁбí½ÓÊÕµ½²¨ÐεÄλÖ㬴ò¿ª¸Ã²¨ÐεÄHDF5Îļþ¡£ËùÓеÄHDF5 I/O¶¼½«Ê¹ÓÃpython¿âh5pyÀ´´¦Àí
°ÑËü±ä³ÉPyTorchÕÅÁ¿²¢Ó¦ÓÃÈκα任£¬°üÀ¨Æ×ͼ±ä»»¡£
½«ÏîÄ¿·µ»Ø¸øµ÷ÓÃÕß
ÏÂÃæ£¬DatasetÀàµÄ´úÂë:
class BirdVox70kDS(Dataset):
def __init__(self, root_dir, fnames, transforms=None):
# store transforms func
self.transforms = transforms
# initialize storage arrays
self.wave_loc = []
self.labels = []
# for each hdf5 file...
for fname in fnames:
# open the file
fhdf5 = os.path.join(root_dir, fname)
with h5py.File(fhdf5, 'r') as f:
# navigate to `waveforms` group
waveforms = f['waveforms']
# for each piece of data...
for waveform in waveforms.keys():
# append waveform filename for later access
self.wave_loc.append([fhdf5, waveform])
# (label == last digit of filename)
self.labels.append(waveform[-1])
# turn them into np.arrays
self.wave_loc = np.array(self.wave_loc)
self.labels = np.array(self.labels)
# melspec transform (similar to `librosa.feature.melspectrogram()`)
self.melspec = T.MelSpectrogram(sample_rate=24000,
n_fft=2048,
hop_length=512)
def __len__(self):
# size of dataset
return len(self.labels)
def __getitem__(self, idx):
# fetch waveform from hdf5 file & label
fhdf5, waveform = self.wave_loc[idx]
wave = f['waveforms'][waveform]
# convert to np array for faster i/o performance
wave = np.array(wave)
# apply other specified transforms
if self.transforms:
wave = self.transforms()(wave)
# convert into tensor & apply melspec
wave = self.melspec(torch.Tensor(wave))
# unsqueeze adds dimension needed for pytorch's `Conv2d`
wave = wave.unsqueeze(0)
# parse label (still a string)
label = self.labels[idx]
return wave, int(label)
ÎÒÃǶ¨ÒåÊý¾Ý¼¯ÎļþµÄĿ¼ºÍÎļþÃû±¾Éí¡£ÎÒ¾ö¶¨Ê¹ÓÃ4¸öÎļþÖеÄ3¸ö×÷Ϊ²âÊÔÊý¾Ý£¬×îºóÒ»¸ö×÷ΪÑéÖ¤/²âÊÔ¼¯À´¶ÈÁ¿Ä£Ð͵ÄÐÔÄÜ£¬ÎªºóÕßÁôÏÂ×îСµÄÎļþ¡£ÓÉÓÚÿ¸öÎļþµÄËùÓмǼÉ豸¶¼ÉèÖõıȽϽü(ÔÚÒÁÈø¿¨µÄͬһ¸ö³ÇÊÐ)£¬ÎÒÈÏÎªÈÆ¹ýËæ»ú·Ö¸î²»»áÒýÈë´óÁ¿µÄÆ«²î¡£
root_dir = '/notebooks/storage/'
fnames = ['BirdVox-70k_unit03.hdf5',
'BirdVox-70k_unit07.hdf5',
'BirdVox-70k_unit10.hdf5']
train_ds = BirdVox70kDS(root_dir, fnames)
val_ds = BirdVox70kDS(root_dir, ['BirdVox-70k_unit01.hdf5'])
ÔÚÎÒÃǵÄÊý¾Ý¼¯Ö®ºó£¬ÏÂÃæ¾ÍÊÇʹÓÃdataloadersÁË:
batch_size = 128
train_dl = DataLoader(train_ds, batch_size, shuffle=True, pin_memory=True)
val_dl = DataLoader(val_ds, batch_size * 2, pin_memory=True)
# having `num_workers > 1` will crash dataloader when working w/ h5 files
¶¨Òådataloaders£¬Ëü½«·ÖÅú·µ»ØÊý¾Ý¡£ÔÚʹÓÃPyTorchºÍHDF5Îļþʱ£¬ÎÒ³¢ÊÔ¹ýÉèÖöà¸ö¡°num_workers¡±£¬µ«·¢ÏÖ´æÔÚÒ»¸öbugÄ£ÐÍ
ÎÒΪÎÒµÄÄ£ÐÍÉèÖÃÁ˱ØÒªµÄ¸¨Öúº¯Êý£¬ÒÔ±ãÒÔºó½øÐÐѵÁ·:
class ModelBase(nn.Module):
# defines mechanism when training each batch in dl
def train_step(self, batch):
xb, labels = batch
outs = self(xb)
loss = F.cross_entropy(outs, labels)
return loss
# similar to `train_step`, but includes acc calculation & detach
def val_step(self, batch):
xb, labels = batch
outs = self(xb)
acc = accuracy(outs, labels)
return {'loss': loss.detach(), 'acc': acc.detach()}
# average out losses & accuracies from validation epoch
def val_epoch_end(self, outputs):
batch_loss = [x['loss'] for x in outputs]
batch_acc = [x['acc'] for x in outputs]
avg_loss = torch.stack(batch_loss).mean()
avg_acc = torch.stack(batch_acc).mean()
return {'avg_loss': avg_loss, 'avg_acc': avg_acc}
# print all data once done
def epoch_end(self, epoch, avgs, test=False):
s = 'test' if test else 'val'
print(f'Epoch #{epoch + 1}, {s}_loss:{avgs["avg_loss"]}, {s}_acc:{avgs["avg_acc"]}')
¶¨Òå¶à¸öº¯Êý£¬ÒÔºó¿ÉÒÔʹÓÃÕâЩº¯ÊýѵÁ·¼Ì³ÐÕâ¸öÀàµÄPyTorchÄ£ÐÍ¡£
def accuracy(outs, labels):
_, preds = torch.max(outs, dim=1)
return torch.tensor(torch.sum(preds == labels).item() / len(preds))
Õâ¸öº¯ÊýÔÚÉÏÊöÀàµÄval_stepº¯ÊýÖб»ÓÃÀ´È·¶¨ÑéÖ¤dataloaderÉÏÄ£Ð͵Ä?È·ÐÔ¡£
²¢¶¨ÒåÓÃÓÚÄâºÏ/ѵÁ·Ä£ÐͺÍÔÚÑéÖ¤Êý¾Ý¼¯ÉϲâÊÔÄ£Ð͵ÄÖ÷Òª¹¦ÄÜ
@torch.no_grad()
def evaluate(model, val_dl):
# eval mode
model.eval()
outputs = [model.val_step(batch) for batch in val_dl]
return model.val_epoch_end(outputs)
def fit(epochs, lr, model, train_dl, val_dl, opt_func=torch.optim.Adam):
torch.cuda.empty_cache()
history = []
# define optimizer
optimizer = opt_func(model.parameters(), lr)
# for each epoch...
for epoch in range(epochs):
# training mode
model.train()
# (training) for each batch in train_dl...
for batch in tqdm(train_dl):
# pass thru model
loss = model.train_step(batch)
# perform gradient descent
loss.backward()
optimizer.step()
optimizer.zero_grad()
# validation
res = evaluate(model, val_dl)
# print everything useful
model.epoch_end(epoch, res, test=False)
# append to history
history.append(res)
return history
×îºó£¬ÕâÊÇÎÒÃǵȴýÒѾõļòµ¥CNNÄ£ÐÍ:
class Classifier(ModelBase):
def __init__(self):
super().__init__() # 1 x 128 x 24
self.conv1 = nn.Conv2d(1, 4, kernel_size=3, padding=1) # 4 x 128 x 24
self.conv2 = nn.Conv2d(4, 8, kernel_size=3, padding=1) # 8 x 128 x 24
self.bm1 = nn.MaxPool2d(2) # 8 x 64 x 12
self.conv3 = nn.Conv2d(8, 8, kernel_size=3, padding=1) # 8 x 64 x 12
self.bm2 = nn.MaxPool2d(2) # 8 x 32 x 6
self.fc1 = nn.Linear(8*32*6, 64)
self.fc2 = nn.Linear(64, 2)
def forward(self, xb):
out = F.relu(self.conv1(xb))
out = F.relu(self.conv2(out))
out = self.bm1(out)
out = F.relu(self.conv3(out))
out = self.bm2(out)
out = torch.flatten(out, 1)
out = F.relu(self.fc1(out))
out = self.fc2(out)
return out
ÎÒʹÓÃÁ˶à¸ö¾í»ý²ã£¬ÕýÈçÎÒÃÇ֮ǰµÄÀíÂÛÍÆ¶ÏËù½¨ÒéµÄÄÇÑù£¬ÎÒÃǵÄÄ£ÐÍʹÓÃÁËһЩ×î´ó³Ø»¯²ã£¬È»ºóʹÓÃÒ»¸ö·Ç³£¼òµ¥µÄÈ«Á¬½ÓÍøÂçÀ´½øÐÐʵ¼ÊµÄ·ÖÀà¡£ÁîÈ˾ªÑȵÄÊÇ£¬Õâ¸ö¼Ü¹¹ºóÀ´±íÏÖµÃÏ൱ºÃ£¬ÉõÖÁ³¬¹ýÁËÎÒ×Ô¼ºµÄÔ¤ÆÚ¡£ÀûÓÃGPU
¼¸ºõÿ¸öÈ˶¼ÐèÒªGPUÀ´ÑµÁ·±ÈÒ»°ãµÄǰÀ¡Éñ¾ÍøÂç¸ü¸´ÔӵĶ«Î÷¡£ÐÒÔ˵ÄÊÇ£¬PyTorchÈÃÎÒÃÇ¿ÉÒÔºÜÈÝÒ×µØÀûÓÃÏÖÓÐGPUµÄÄÜÁ¦¡£Ê×ÏÈ£¬ÎÒÃǽ«ÎÒÃǵÄcudaÉ豸¶¨ÒåΪ¹Ø¼ü´ÊÉ豸£¬ÒÔ±ã¸üÈÝÒ×·ÃÎÊ:
device = 'cuda' if torch.cuda.is_available() else 'cpu'
ÎÒÃÇ»¹È·±£Èç¹ûûÓÐGPU, CPU»á±»Ê¹Óá£
ÕâÀﻹÓÐÁíÒ»¸ö¼¼ÇÉ:
torch.backends.cudnn.benchmark = True
Õâ¿ÉÒÔ°ïÖúÌá¸ßÄãµÄѵÁ·ËÙ¶È(Èç¹ûÄãµÄÊäÈëÔÚ´óС/ÐÎ×´ÉÏûÓб仯)
ÏÔÈ»£¬Äã¿ÉÒÔ¡°¸æËß¡±PyTorchÔÚÒ»´ÎÓÖÒ»´ÎµÄѵÁ·ÖÐÓÅ»¯×Ô¼º£¬Ö»ÒªÑµÁ·ÊäÈëÔÚ´óСºÍÐÎ×´Éϱ£³Ö²»±ä¡£Ëü»áÖªµÀΪÄãµÄÌØ¶¨Ó²¼þ(GPU)ʹÓÃ×î¿ìµÄËã·¨¡£!
È»ºóÎÒÃǶ¨Òå°ïÖúº¯ÊýÀ´Òƶ¯dataloaders¡¢tensorsºÍÎÒÃǵÄÄ£Ð͵½ÎÒÃǵÄGPUÉ豸¡£
def to_device(data, device):
"""Move tensor(s) to chosen device"""
if isinstance(data, (list, tuple)):
return [to_device(x, device) for x in data]
return data.to(device, non_blocking=True)
class DeviceDataLoader():
"""Wrap a dataloader to move data to a device"""
def __init__(self, dl, device):
self.dl = dl
self.device = device
def __iter__(self):
"""Yield a batch of data after moving it to device"""
for b in self.dl:
yield to_device(b, self.device)
def __len__(self):
"""Number of batches"""
return len(self.dl)ѵÁ·
ʹÓÃÎÒÃǵÄÉ豸¸¨Öú¹¦ÄÜ£¬ÎÒÃǽ«Ò»ÇÐÒÆ¶¯µ½ÎÒÃǵÄGPUÈçÏÂ:
train_dl = DeviceDataLoader(train_dl, device)
val_dl = DeviceDataLoader(val_dl, device)
model = to_device(Classifier(), device)
ÎÒÃÇ»¹Ö¸¶¨ÁËÎÒÃǵÄѧϰËٶȺÍÎÒÃǵÄѵÁ·´ÎÊý£¬ÎÒ»¨Á˺ܳ¤Ê±¼äÀ´ÕÒµ½Ò»¸öºÃµÄÖµ¡£
lr = 1e-5
epochs = 8
ÔÚ½øÐÐÈκÎѵÁ·Ö®Ç°£¬ÎÒÃǻᷢÏÖÄ£Ð͵ıíÏÖ:
history = [evaluate(model, val_dl)]
[{'avg_loss': tensor(0.7133, device='cuda:0'), 'avg_acc': tensor(0.6042)}]
ºÜÏÔÈ»£¬ÎÒÃÇÔÚ¿ªÊ¼Ê±µÄ׼ȷÐÔÉÏÓеãÐÒÔË£¬µ«¾¹ý¶à´ÎÊÔÑ飬×îÖÕ½á¹û¼´Ê¹²»Ïàͬ£¬Ò²»á·Ç³£ÏàËÆ¡£
½ÓÏÂÀ´£¬ÎÒÃÇʹÓÃ֮ǰ¶¨ÒåµÄfitº¯ÊýÀ´ÑµÁ·ÎÒÃǵļòµ¥·ÖÀàÆ÷Ä£ÐÍʵÀý:
history += fit(epochs, lr, model, train_dl, val_dl)
HBox(children=(FloatProgress(value=0.0, max=352.0), HTML(value='')))
Epoch #1, val_loss:0.6354132294654846, val_acc:0.7176136374473572
Epoch #2, val_loss:0.6065077781677246, val_acc:0.7439352869987488
Epoch #3, val_loss:0.56722491979599, val_acc:0.77376788854599
Epoch #4, val_loss:0.5528884530067444, val_acc:0.7751822471618652
Epoch #5, val_loss:0.5130119323730469, val_acc:0.8004600405693054
Epoch #6, val_loss:0.4849482774734497, val_acc:0.8157732486724854
Epoch #7, val_loss:0.4655478596687317, val_acc:0.8293880224227905
Epoch #8, val_loss:0.4765000343322754, val_acc:0.8155447244644165
ÔÚ·¢ÏÖ¾«È·¶ÈÓÐÒ»µãϽµºó£¬ÎÒ¾ö¶¨ÔÙѵÁ·Ò»µãµã£¬ÈÃÄ£ÐÍÖØ¶¨Ïò»Øµ½ÕýÈ·µÄ·½Ïò:
history += fit(3, 1e-6, model, train_dl, val_dl)
Epoch #1, val_loss:0.4524107873439789, val_acc:0.8329823613166809
Epoch #2, val_loss:0.44666698575019836, val_acc:0.8373703360557556
Epoch #3, val_loss:0.4442901611328125, val_acc:0.8412765860557556
ºöÂÔ¡°HBox¡±¹¤¼þ£¬ÕâÊÇtqdmÌṩµÄ£¬Çë¶à¹Ø×¢×¼È·ÐÔ!
×ܽáһϣ¬ÒÔÏÂÊÇÎÒÃǹýÈ¥11¸öʱÆÚµÄѵÁ·Í³¼ÆÊý¾Ý:
plt.plot([x['avg_loss'] for x in history])
plt.title('Losses over epochs')
plt.xlabel('epochs')
plt.ylabel('loss')
plt.show()
plt.plot([x['avg_acc'] for x in history])
plt.title('Accuracy over epochs')
plt.ylabel('acc')
plt.show()
×ܵÄÀ´Ëµ£¬ÎÒÃǵÄÄ£ÐÍѵÁ·µÃÏ൱ºÃ£¬´ÓËüµÄÍâ¹ÛÀ´¿´£¬ÎÒÃÇ¿ÉÄÜÒѾΪÎÒÃǵÄÄ£Ð͵ÄËðʧÕÒµ½ÁËÒ»¸öÏà¶Ô×îСµÄÖµ¡£
µÈµÈ£¬Ò»¸ö¸ü¸´ÔÓµÄÄ£ÐÍ»òÕßʹÓò»Í¬µÄת»»ÔõôÑù?
ÏàÐÅÎÒ£¬ÔÚÎÒµÄsimple Classifier()µÚÒ»´Î³¢ÊԳɹ¦Ö®ºó²»¾Ã£¬ÎÒÒ²³¢ÊÔ¹ýÕâÁ½ÖÖ·½·¨¡£ÎÒ¾ö¶¨²»°üÀ¨ÕâÁ½¸öϸ½Ú£¬ÒòΪÎÒ·¢ÏÖËûÃǵĽá¹ûʵ¼ÊÉϱÈÎÒÃÇÒѾȡµÃµÄ½á¹û¸üÔã¸â£¬ÕâºÜÆæ¹Ö¡£
¶ÔÓÚ¶îÍâµÄÆ×ͼת»»£¬ÎÒ³¢ÊÔÁËËæ»úÊ±ÒÆºÍÔëÉù×¢Èë¡£³¤»°¶Ì˵£¬ËüËÆºõ¸ù±¾Ã»ÓÐÌá¸ßÑéÖ¤µÄ׼ȷÐÔ¡£´Ëºó,ÎÒÈÏΪÊÇÕâÑù,ÒòΪÊý¾Ý¼¯¹æ·¶Ã÷È·±íʾ,ËùÓÐà±à±½«Î»ÓÚÖмäµÄ¼Òô,Òò´ËËæ»ú±ä»¯µÄ¹âÆ×ͼµÄÄ¿µÄÔÊÐí¸üºÃµÄÄ£ÐÍ·º»¯Êµ¼ÊÉÏ¿ÉÄÜÒѾ×÷ΪË𺦵ıíÏÖ¡£È»¶ø£¬ÎÒ»¹Ã»Óг¢ÊÔ¹ýËæ»úÔëÉù×¢Èë¡£
ÎÒ»¹³¢ÊÔѵÁ·Ò»¸öResNet50Ä£ÐÍ£¬Ï£Íû½øÒ»²½Ìá¸ßÑéÖ¤µÄ׼ȷÐÔ¡£ÕâÊÇ×îÁîÈËÄÑÒÔÖÃÐŵIJ¿·Ö:ÎÒµÄÄ£ÐÍ´ÓÀ´Ã»Óг¬¹ý50?׼ȷÂÊ!Ö±µ½½ñÌìÎÒдÕâÆªÎÄÕµÄʱºò£¬ÎÒ»¹²»È·¶¨ÎÒ×ö´íÁËʲô£¬ËùÒÔÈç¹ûÆäËûÈËÄÜ¿´¿´±Ê¼Ç±¾²¢°ïÖúÎÒ£¬ÎҺܸßÐËÊÕµ½Èκν¨Òé!½áÂÛ
×ܶøÑÔÖ®£¬ÕâÊÇÒ»¸öÕæÕýÓÐȤµÄŬÁ¦£¬»¨Ò»Ð©Ê±¼ä½øÐÐÑо¿¡£Ê×ÏÈ£¬ÎÒµÃÖØÐÂÉóÊÓÎÒÈ¥ÄêÏÄÌìµ÷²é¹ýµÄ¶«Î÷£¬ÎÞ¿É·ñÈÏ£¬ÕâÓÐÒ»ÖÖ»³¾ÉµÄ¸Ð¾õ¡£¸üÖØÒªµÄÊÇ£¬ÎÒÃÇѧϰÁËÈçºÎʵÏÖÒ»¸öºÜ¿ÉÄÜÓÃÓÚÕæÊµ³¡¾°µÄPyTorchÊý¾Ý¼¯À࣬ÔÚÕæÊµ³¡¾°ÖУ¬Êý¾Ý²»Ò»¶¨ÏñÄúÔ¤ÆÚµÄÄÇÑùÉèÖá£×îºó£¬×îÖÕµÄÑéÖ¤·ÖÊýΪ84?¶ÔÓÚÎÒ¼´ÐË´´½¨µÄÈç´Ë¼òµ¥µÄÍøÂç¼Ü¹¹À´Ëµ£¬ÕâÊÇÏ൱Õû½àµÄ! |
