Irish Acts Studio SAM 03 First Contact Expansion for Irish Acts InfinityÀ©Õ¹
winter662
2020-7-14 12:21:35
×ªÔØ
Irish Acts Studio SAM 03 First Contact Expansion for Irish Acts Infinity v2 InfinityÀ©Õ¹
¡°µÚÒ»´Î½Ó´¥¡±ÊÇ×îеÄÉùÒôÀ©Õ¹ÎªÁ÷ÐеÄÎÞÏÞVST/AU¡£
Õâ¸öеÄÀ©Õ¹´øÄã½øÒ»²½½øÈëÁíÒ»¸öÊÀ½çµÄÁìÓò£¬»·¾³ºÍÐÂʱ´úµÄÉùÒô¡£
²úƷ˵Ã÷:
Òª°²×°´ËÀ©Õ¹£¬ÄúÖ»Ðè¸´ÖÆ¡°SAM 03 ¨C First Contact¡±¡£mse ¡°µ½Äú¼ÆËã»úÉϵÄÕýÈ·Îļþ¼Ð£¬ÄúµÄÎÞÏÞv2.0 VSTλÓÚÄÇÀï¡£
WindowsÓû§
ÕÒµ½Äã°²×°ÎÞÏÞÎļþ¼ÐµÄµØ·½£¬²¢¸´ÖÆ¡°SAM 03 -µÚÒ»¸öÁªÏµÈË¡£½«mseÎļþת»»ÎªÎÞÇî´ó¡£¹¤¾ß¡±Îļþ¼Ð¡£
MacÓû§
ÕÒµ½Äú°²×°ÎÞÏÞµÄλÖ᣸´ÖÆ¡°SAM 03 -µÚÒ»´ÎÁªÏµ¡±¡£mse¡°Îļþµ½¡°×ÊÔ´¡±Îļþ¼Ð¡£
·ÇÃË/Âß¼­Óû§
ÕÒµ½Äú°²×°infini .componentµÄλÖ㬲¢¸´ÖÆ¡°SAM 03 ¨C First Contact¡±¡£mse¡°Îļþµ½¡°×ÊÔ´¡±Îļþ¼Ð¡£
¸´ÖÆÍêÎļþºó£¬¾Í¿ÉÒÔÔËÐÐInfinity v2.0ÁË¡£Ëü»á×Ô¶¯¼ì²âµ½ÐµÄ×ÊÁÏÆ¬¡£
ÎÞÏÞv2.0 AU-VST²å¼þΪWindowsºÍMacOS°üÀ¨
Ö÷Ò³
irishacts.com/?download=infinity-sam-03-first-contact
¡°First Contact¡± is the latest sound expansion for the popular Infinity VST/AU.
This new expansion takes you even further into the realm of otherworldly, ambient and new age sounds.
Instructions:
To install this expansion you simply need to copy the ¡°SAM 03 ¨C First Contact.mse¡± to the correct folder on your computer where you have your Infinity v2.0 VST located.
Windows Users
Locate where you installed your Infinity Folder and copy the ¡°SAM 03 ¨C First Contact.mse¡± file into the ¡°infinity.instruments¡± folder.
Mac Users
Locate where you installed your infinity.vst and copy the ¡°SAM 03 ¨C First Contact.mse¡± file into the ¡°Resources¡± folder.
AU/Logic Users
Locate where you installed your infinity.component and copy the ¡°SAM 03 ¨C First Contact.mse¡± file into the ¡°Resources¡± folder.
Once the file has been copied over, your now ready to run the Infinity v2.0. It will automatically detect the new expansion.
Infinity v2.0 AU-VST Plugin for Windows & MacOS included
home page
Skywalker | 12-07-2020 | 1.98 GB
