µç×Ó¹ÜÉùÒôÄ£ÄâÆ÷ Voxengo Warmifier 2.4 Win
wangfei02
2020-7-4 21:28:41
Warmifier ÊÇÒ»¸öÌØ±ðµÄ²å¼þ£¬Ëü¿ÉÒÔ¶Ô½øÈëµÄÒôƵÐźŽøÐд¦Àí²¢ÊµÏÖÀàËÆÄ£Äâµç×ӹܵÄÉùÒô¡£Í¨¹ý Warmifier£¬Äã¿ÉÒÔÈÃÉùÒô´øÓÐÎÂůµÄµç×ӹܸоõ£¬¶øÇÒ¿ÉÒÔ¶Ô¡°É«²Ê¡±½øÐпØÖÆ¡£
Warmifier ¼ÈÊÊÓÃÓÚ×îÖյĻìÒôÒ²ÊÊÓÃÓÚµ¥¶ÀµÄÀÖÆ÷Òô¹ì¡£Äã¿ÉÒÔ¶Ô¼¸¸ö²ÎÊý½øÐÐÉèÖ㬿ÉÒԸıäЧ¹ûµÄÇ¿¶ÈÒÔ¼°É«²Ê¡£È»ºó»¹Óм¸¸öµç×Ó¹ÜÀàÐ͹©ÄãÑ¡Ôñ¡£Ã¿¸öµç×Ó¹ÜÀàÐͶ¼ÌṩÁ˲»Í¬µÄÕûÌåÉ«²Ê¡£
ͨ¹ýÕâ¸ö²å¼þʵÏÖµÄЧ¹û¿Ï¶¨ÊÇ΢ÃîµÄ£¬Õë¶Ô²»Í¬µÄÉùÒô»áÓв»Í¬µÄ²îÒìºÍ±ä»¯¡£Í¨³£Ëü»áÈÃÄãµÄÒô¹ì±äµÃ¸ü¼Ó¡°Ã÷ÁÁ¡±¡¢¡°ÓÐÏÖ³¡¸Ð¡±¡¢¡°ÎÂů¡± »òÊÇ¡°ÓÐÄý¾ÛÁ¦¡±¡£
Warmifier v2.0 Öеı仯£º
¶àƽ̨֧³Ö¡£
Ô¤ÖÆ¹ÜÀíÆ÷¡£
Óû§½çÃæÖØÐµ÷Õû¡£
²å¼þʵÀýÃüÃû
Warmifier is a special audio effect AAX, AudioUnit and VST plugin for professional sound and music production applications which processes audio signal in a way similar to analog tube/valve equipment. By using Warmifier you can achieve valve warming and ¡°console¡± coloration effects.
Warmifier is applicable both to the complete mixes and to the individual instrument tracks. You have several parameters at your disposal that allow you to control the strength and the color of the effect. Also, you have several tube/valve types to choose from. Each valve type offers a different overall coloration. While the effect of this plugin is definitely subtle, the difference it makes is similar to the difference in sound between various analog mixing consoles. In most cases it boils down to adding a subtle ¡°sparkle¡±, ¡°presence¡±, ¡°warming¡± or ¡°solidifying¡± effect to a sound track it was applied to.
Features:
7 tube/valve types
2 processing modes
Stereo processing
Up to 8x oversampling
64-bit floating point processing
Preset manager
Undo/redo history
A/B comparisons
Contextual hint messages
All sample rates support
41 ms compensated processing latency
User interface color schemes
Resizable user interface
Retina and HighDPI support
Compatibility:
This audio plugin can be loaded into any audio host application that conforms to the AudioUnit or VST plugin specification. Plugins with AAX version available can be loaded in ProTools 12+.
This plugin is compatible with Windows (32- and 64-bit Windows XP, Vista, 7, 8, 10 and later versions) computers (2.5 GHz dual-core or faster processor with at least 4 GB of system RAM, SSE4.2 instructions support required, e.g. any Intel Core i-, AMD Bulldozer- or Zen-based processor). A separate binary distribution file is available for each target computer platform and audio plugin specification.
Compatible software: Cubase, Logic Pro, ProTools, Ableton Live, Reaper, Presonus Studio One, FL Studio, Cakewalk, Nuendo, WaveLab, GarageBand, Vegas, SoundForge, Audition, Samplitude, Digital Performer, Mixcraft, Bitwig Studio, Edius, others.
File size: 6.4 MB
Whats New:
Updates: official site does not provide any info about changes in this version.
ÏÂÔØµØÖ·£ºhttps://plugintorrent.com/voxeng ... aax-au-win-x86-x64/
