  • wangfei02  2020-7-4 21:43
    Tube/valve distortion emulation plug-in
    Voxengo Tube Amp
    Tube Amp is an audio effect plug-in that applies asymmetric tube triode overdrive usually found in single-tube microphone pre-amp boxes. The sound this plug-in produces varies from a mild "warm" overdrive to a fuzzy distortion. Beside that, Tube Amp includes a -6 dB/oct low-pass filter that is built-in into plug-in's valve modeling equation, and can be used to imitate a lower-quality tube triode.
    Tube Amp also features all standard advanced Voxengo plug-in features like full multi-channel operation and built-in oversampling.
    Features
    * Asymmetric tube triode overdrive
    * Multi-channel processing
    * Internal channel routing
    * Channel grouping
    * Mid/side processing
    * Up to 8x oversampling
    * 64-bit floating point processing
    * Preset manager
    * Undo/redo history
    * A/B comparisons
    * Contextual hint messages
    下载:http://www.dontcrack.com/freewar ... /software/Tube-Amp/
  • wangfei02  2020-7-4 21:28
    电子管声音模拟器 Voxengo Warmifier 2.4 Win
    Warmifier 是一个特别的插件,它可以对进入的音频信号进行处理并实现类似模拟电子管的声音。通过 Warmifier,你可以让声音带有温暖的电子管感觉,而且可以对“色彩”进行控制。
    Warmifier 既适用于最终的混音也适用于单独的乐器音轨。你可以对几个参数进行设置,可以改变效果的强度以及色彩。然后还有几个电子管类型供你选择。每个电子管类型都提供了不同的整体色彩。
    通过这个插件实现的效果肯定是微妙的,针对不同的声音会有不同的差异和变化。通常它会让你的音轨变得更加“明亮”、“有现场感”、“温暖” 或是“有凝聚力”。
    Warmifier v2.0 中的变化:
    多平台支持。
    预制管理器。
    用户界面重新调整。
    插件实例命名
    Warmifier is a special audio effect AAX, AudioUnit and VST plugin for professional sound and music production applications which processes audio signal in a way similar to analog tube/valve equipment. By using Warmifier you can achieve valve warming and “console” coloration effects.
    Warmifier is applicable both to the complete mixes and to the individual instrument tracks. You ...查看全文
  • wangfei02  2020-7-4 21:08
    Beatskillz Slam Pup WIN/MAC 模拟狗叫声的效果器
    试听链接:https://v.qq.com/x/page/w3056goytv7.html?start=8
    插件格式:
    MAC OSX – VST3 / AU– 64位
    WINDOWS – VST3 – 64位
    PC / MAC:Windows 10 / OSX 10.13或更高版本
    (AAX –不支持RTAS)
    系统要求:
    Intel i3,AMD Ryzen或等效的
    2 GB RAM / 300 MB HD屏幕分辨率:
    1024×768 VST2,VST 3,AU或AAX 64位主机
    安装:
    OSX:提取SlamPup.zip文件,然后双击SlamPup.pkg文件。右键单击该程序包,然后单击“打开”。按照说明安装插件。
    Windows:运行SlamPup.exe并按照说明安装插件
    Beatskillz发布新款插件Slam Pup,这是一款压缩器兼饱和器。
    坐拥大量模拟和数字处理器库的Beatskillz,这次模拟出了美国压缩器Thrusty和英国多极管单元饱和器Gritty的结合体,Slam Pup。插件只有两个控件,一个Bark,增加饱和度;一个Bite,加大压缩量。名字和造型一样形象呢。
    插件特点:
    模拟温暖的多极管单元,声音更肥厚。
    融合Thrusty压缩器的灵魂,压缩后声音仍然强而有力。
    非常适用于鼓、合成器、贝斯,或在母线上使用。
    调整干湿比,可调制出不一样Bark和Bite细节的效果。
    免费。
    PC / MAC:Windows 10 / ...查看全文
  • wangfei02  2020-7-4 20:25
    YAMAHA UR816C 16×16 USB3.0音频接口
      音质一直是所有音频设备中首要考虑到的问题,而UR816C能完全胜任。其丰富多样的输入/出接口,可以轻松胜任多轨录音的需求,超赞的麦克风前置放大器,以及包括字时钟、数字输入/出接口及“Mute”静音/“Dim”衰减开关等,所有在录音都迫切需要的功能。
      给予您专业级的音频I/O解决方案
      音质一直是所有音频设备中首要考虑到的问题,而UR816C能完全胜任。自带的Class-A D-PRE麦克风前置放大器和32-bit/192kHz音频处理精度,让您在任何地方都可以获得专业级的录音质量。多样话的输入接口可以轻松应对鼓组的录制。基于内置的DSP效果器的吉他放大器,以及高阻抗输入接口,可以让电吉他能被清晰干净的录制下来的同时也能进行零延迟的实时监听。而MIDI接口可以让更多的外部MIDI设备加入录制的行列。数字光纤接口,可以让您通过先进的抖动衰减技术、字时钟同步技术及数模转化技术,确保多台音频设备之间获得出色的同步协同效果。以及“Dim”衰减和“Mute”静音专业录音室级别的功能 而这所有的这一切都可在任何宿主软件中使用。
      轻松捕捉乐队录音的方方面面
      没有什么比大家能一起演奏更能体现一个乐队的精神了。丰富 ...查看全文
