½ÚÅÄÖÆ×÷Èí¼þ ¨C Serato Studio 1.4.5 x64 Win
82683630
2020-5-21 19:51:49
Èí¼þ
( }( T" L' g" j% }8 ^" S2 a: S% a
; m0 f  |/ m# R- {$ gÖÕ¼«½ÚÅÄÖÆÔìÉÌ¡£ÃæÏòDJºÍÖÆ×÷È˵ÄÖ±¹Û½ÚÅÄÖÆ×÷Èí¼þ¡£Ê¹ÓÃSerato Studio»¨·Ñ¸üÉÙµÄʱ¼äÀ´½â¾öÕϰ­£¬²¢»¨·Ñ¸ü¶àµÄʱ¼äÀ´ÖÆ×÷ÒôÀÖ¡£
9 N9 |$ N0 T$ j9 p+ W& V3 s, ^) E7 s& @
+ Y5 s: T- U( ]6 `¿ìËÙ£¬¼òµ¥µÄ¹¤×÷Á÷³Ì¡£
* @  J* d1 ]0 Z. O: j" z5 g) A  E+ u1 B¿ìËÙ½ÚÊ¡ÄúµÄÏë·¨£¬²¢Í¨¹ýʡʱµÄ¹¦ÄÜ£¨°üÀ¨Ô¤ÖƵĹÄģʽ£¬BPMͬ²½ºÍÒ»¼üʽ°´¼üÇл»£©±£³ÖÔÚ´´ÒâÁ÷³ÌÖС£
; N2 u2 W# y8 y; C' i0 Y: O, N  w8 j, c$ z; P; i: T1 E
DJÓѺõÄÖÆ×÷
$ `7 X9 ^7 P( d/ Y/ s$ K& NÓÃÄúµÄDJÓ²¼þÌø¶¯²¢·ÃÎÊÕû¸öSerato DJ¿â¡£Äú»¹½«»ñµÃÊìϤµÄDJÔªËØ£¬ÀýÈç²ÊÉ«²¨ÐΣ¬»ìºÏͨµÀºÍ¸ßÖÊÁ¿FX¡£4 G- z4 a0 k/ w* V1 @& X3 \$ K
- g6 |# L9 `+ u5 ?" i# aÄÚÖÃÉùÒô¿ªÊ¼
+ d. H  E/ d. @0 J( v' C9 W$ }Á¢¼´¿ªÊ¼Ê¹ÓÃÄÚÖõĹÄ×飬ÀÖÆ÷£¬»ØÂ·ºÍÖªÃûÒÕÊõ¼ÒºÍÉùÒôÉè¼ÆÊ¦µÄÑù±¾ÖÆ×÷ÒôÀÖ¡£! U9 N2 n# s3 ?' |3 j. o# N3 F
  u2 ?" {5 i+ O* }' l
¼òµ¥µ«¹¦ÄÜÇ¿´ó
. U7 o0 `! K2 Z, F0 P) c3 qʹÓÃVSTºÍAU²å¼þ£¬×Ô¶¯»¯ºÍµ¼³ö¾¥À´ÍêÈ«×Ô¶¨ÒåÄúÏëÒªµÄÉùÒô¡£
" c) `4 t2 p0 Q" Z5 x) v9 a3 e/ g  e/ G) u5 J
×Ô¶¯ºÍÏÒģʽ-Á¢¼´ÔÚÏîÄ¿µÄ¹Ø¼ü²¿·ÖÉú³ÉºÍÏÒ-ÎÞÐèÒôÀÖÀíÂÛ£¬Ò²Ã»ÓÐÎÊÌâ¡£´ò¿ª¡°¸Ð¾õ¡±ÐýÅ¥ÒÔÄ£Äâʵʱ¼üÅÌÑÝ×àÆ÷¡£
+ f% t! }8 C2 W$ l0 dSong ViewµÄ¸Ä½ø-°üÀ¨¸´ÖÆÒô¹ìµÄ¹¦ÄÜ£¬Song ViewÖеÄС° Back to Start¡±°´Å¥ÒÔ¼°Song View²àÀ¸ÖеÄÐÂˮƽµ÷Õû´óС¡£+ R# H  M1 z6 W) C3 z6 T+ ]5 w
Á¿»¯Ìáʾµã-Á¿»¯Ä£Ê½ÏÖÔÚ¿ÉÒÔ½«ÄúµÄÌáʾµã²¶×½µ½×î½Ó½üµÄ°ëÅÄ-¾ÍÏñSerato DJÒ»Ñù¡£
9 W. _$ R9 {2 a6 z1 jSerato DJ¿â¸üÐÂ-¶ÔÓÚÄÇÀïµÄËùÓÐÖÆ×÷ÈËDJ£¬ÄúµÄDJ±êÇ©À¸ÏÖÔÚ½«ÓëËüÃÇÔÚSerato DJÖеÄÏÔʾ·½Ê½±£³Öͬ²½¡£& F9 M! B5 W" j  w; Q* q# D9 P4 y
2 z9 q. V; t8 d* F( `* W$ s" t% G
²Ù×÷ϵͳ£º
" D& V  r% F! cWindows 10
. x  A( s; ^1 u, K2 H×¢Ò⣺²Ù×÷ϵͳ֧³Ö¼Ù¶¨ÄúʹÓõÄÊÇ×îеÄPoint°æ±¾¡£½ö64루²»Ö§³Ö32λ²Ù×÷ϵͳ£©¡£) H( L+ l; X: Z
: i; S/ r( p- w! o$ _
8 M6 K% e% S8 @+ A. r+ ]* \, O8 J* c
1 P2 u0 A0 H3 S0 YThe ultimate beat maker. Intuitive beat making software for DJs and producers. Spend less time hitting roadblocks and more time making music with Serato Studio.* V+ k; `' E8 d
, O! M1 i0 T+ S0 c+ J1 z
Fast, simple workflow.& j& D% ]3 R0 h( S
Get your ideas down quick and stay in the creative flow with time-saving features, including pre-made drum patterns, BPM-sync and one-click key shifting.
6 u0 `/ ^7 |) ~  _" W0 _0 ^
2 {- L( }2 |. {7 _6 r8 WDJ-friendly production
0 t% t! ^5 l4 c$ DMake beats with your DJ hardware and access your entire Serato DJ library. You¡¯ll also get familiar DJ elements like colored waveforms, a mixing channel, and high-quality FX.1 L3 x9 O; ]+ |
' B9 ]4 E5 [- m: gBuilt-in sounds to get started
/ W/ k! Y0 k4 k9 m* _# U  m$ sStart making music right away with built-in drum-kits, instruments, loops and samples from renowned artists and sound designers.' i% G/ y: j- @) w+ ~8 H- t
; m: @: y! R$ \( c! f) P! w
Simple but powerful
. |8 i' Z8 }# m; g, \( _# B5 FUse VST and AU plug-ins, automation, and export stems to customize your sound exactly how you want it.6 C; k/ }: F: N+ t3 H
/ `/ q. E1 P: [0 ?% b( l. u# M3 kAuto Chord Mode ¨C Instantly generate chords in the key of your project ¨C no music theory, no problem. Turn on the Feel knob to simulate a live keyboard player.6 M: `6 m5 U5 D5 }% N% t
Song View Improvements ¨C Including the ability to duplicate your Audio Tracks, a new ¡®Back to Start¡¯ button in the Song View, and new horizontal resizing in the Song View sidebar.( a* l( c8 j# ?9 Y: O& D' `8 v& I: T
Quantized Cue Points ¨C Quantize Mode will now snap your Cue Points to the closest half-beat ¨C just like Serato DJ.
- U0 y; y( |8 u# ?4 ?, X) PSerato DJ Library Update ¨C For all the producer-DJs out there, your DJ tab columns will now sync up with how they appear in Serato DJ.6 g' A6 W* l8 v/ m3 B0 Y
154bfb655d622261.png 0 s0 c; [+ w4 g
Operating System:
2 u+ `8 r( n8 Q& lWindows 10. ]2 e6 K5 `7 X/ h" h
Note: Operating system support assumes you are using the latest point release. 64-bit only (32-bit operating systems are not supported).. |( D' K8 ^  R0 C9 m5 F: `
% C, Y7 f6 O( O0 _# y6 x6 |9 m
File Size: 0.99 GB
  b% K* u9 \, ?; @1 d: ^7 Whttps://serato.com/studio/downloads
