5 w& h$ L9 u1 T3 O1 r yEasy Audio Mixer 2.6.0 MacOS
& F9 O% n+ V# A5 Q2 u3 o5 t% ^ : [/ {( m& N; V, X
Easy Audio Mixer Mac°æÊÇMacƽ̨ÉϵÄÒ»¿î¼òµ¥Ò×ÓõÄÒôƵ±à¼¹¤¾ß¡£Easy Audio Mixer Mac°æ¿ÉÒÔ°ïÎÒÃǼôÇÐÒôƵ£¬»ìºÏÒôƵ£¬´ÓÊÓÆµÎļþÖзָîÒôƵ£¬»¹¿ÉÒÔ½«¶à¸öÒôƵºÏ²¢ÎªÒ»¸ö¡£- N- l7 m E) Z
, ] u; k* X1 ^7 kÈí¼þÌØÉ«! A. M$ b, J8 i' y. X! m
0 Y( O, q! D+ }& eEasy Audio Mixer Mac°æ·Ç³£Ò×ÓÚʹÓã¬Ö»ÐèÒª½øÐм¸´ÎÍϷŲÙ×÷£¬Äã¾Í¿ÉÒÔ¿ìËÙÇáËɵØÍê³ÉÒôƵ¼ô¼µÄ¹¤×÷¡£) W4 C7 A7 M* L6 w
$ u0 L. c! e* U8 \8 ?& E, W
Ö§³Ö¼¸ºõËùÓÐÁ÷ÐеÄÒôƵ¸ñʽ£¬°üÀ¨µ«²»ÏÞÓÚmp3£¬m4a£¬wav£¬wmaµÈ¡£Ö§³Ö¼¸ºõËùÓпÉÒÔ·Ö¸îÒôƵµÄÁ÷ÐÐÊÓÆµ¸ñʽ£¬Èçmp4£¬wmv£¬rmvbµÈ¡£
0 x: o6 y- b1 s4 w
, x) j; g' B6 A' O6 d( D5 [! MÖ§³ÖʵʱԤÀÀ½á¹û¡£Ö§³ÖÒôƵÇиºÏ²¢£¬·Ö¸îºÍ»ìÒô¡£Ö§³ÖÒôÁ¿µ÷½Ú£¬µÈë/µ³öЧ¹û¡£Ö§³ÖÒÔmp3 / m4a / wav¸ñʽÊä³ö¡£* T' P7 L, T, g g0 h/ |+ y9 |. ]
" M; L) k5 {4 V. Z1 \) a5 K
File size: 16 MB
" e" F7 I9 \7 ^Easy audio mixer is a simple audio editor tool and is easy to use. You can use it to cut audio, mix audio, split audio from video file, and also merge multi audios into one.1 e h3 C# A# Z, c; `
8 m/ j; k. d. z% [: nKey feature:: ]5 k6 W' f$ T8 l2 o( |
Support almost all popular audio format, including but not limited to mp3, m4a, wav, wma etc
# W4 g# P! @+ K5 b% TSupport almost all popular video format from which you can split audio, such as mp4, wmv, rmvb etc
1 q: B* k" O5 B2 C: |; @% MEasy to use. You can quickly and easily finish the task by only a few drag and drop operations. And you can preview the result in the real time
3 @ d7 D% g4 m4 ^ }, `4 d; q, C! ySupport audio cutting, merging, splitting and mixing
! Z6 b/ s$ w+ m2 W: gSupport audio volume adjusting, and fade in/fade out effect
% i; u7 }8 {4 L6 t7 M% `% O- \6 sSupport to output in mp3/m4a/wav format/ o, q6 y! O* V! [& _
Powerful, efficient and easy to use' O' \) S/ ?1 X, ^, i
/ C* L- l8 d. R9 {3 X
Supported Operation Systems:" v* w# N s: \, ?
macOS 10.10 or later 64-bit
4 ~$ O8 D% @; m: Y6 p1 P7 s
0 T+ E3 @6 f6 F# P; P3 w1 z7 fHomepage
~! j3 s$ c$ @1 \1 X! h" }% Z) } ahttp://www.macupdate.com/v1/app/mac/60960/easy-audio-mixer |
