  • octave  2020-5-7 21:35
    FL Studio Sylenth1 and Serum Presets
    W. A. Production What About Dubstep Muscle WAV MiDi FL Studio Sylenth1 and Serum Presets
    1.5 GB
    We are calling out to all you headbangers. Give your Dubstep a little something extra. Check out What about: Dubstep Muscle from W. A. Production. Get ready to experience a supersonic powerhouse of sound. We are giving you harder hits, bone-chilling progressions, melodic build-ups, heavy-hitting drops, and crisp alterations that are sure to catch anyone that thinks they know what will come next by surprise.
    If you are not familiar with Construction Kits they are a great tool for professionals on the go, beginners learning about song structure and audio production, or those looking to stay current on multiple genres.
    Our top-notch producers have designed the demo track you will hear in each kit. Inside the kit, you will find every sample, preset, MIDI trigger, and plugin used to create the track. Not only is it broken down into one hits. Each track has been broken down layer by layer in its en ...查看全文
  • octave  2020-5-7 21:28
    Nuendo 10.2.10 WIN版
    Nuendo 10.2.10 WIN版
    安装时必须删除Cubase或者旧版Nuendo
    !!!!切记在开始安装之前先禁用Windows Defender防病毒软件!
    Steinberg Nuendo 10.2.10(带有版本号)
    请注意,这些是仅x64位安装程序,我没有win 7来对其进行测试
    两者都经过了翻新,并已更新为DC版本的所有最新版本,而且还具有用于标准版和Dc版的桌面图标,以方便访问。
    包含Steinberg Library Manger,还带有一个易于访问的桌面图标
    一些社区朋友在使用Antitrial B11时遇到了麻烦
    这两个安装程序都包含以前的Antitrial b10版本
    Padshop Pro是单独的产品,安装程序中未包含
    如果您已安装B11且没有任何问题,请保持Antitrial不变!!!!
    只需从菜单安装步骤03
    笔记:
    来自Mono的信息-包括
    如何安装-随附
    防弹B10-随附
    尊敬-完成
    Vstbassamp-完成
    Vstamp机架-完整
    多延迟完成
    VST XMLS-完成
    文件结构-完整
    斯坦伯格图书馆经理-已安装
    There is no need to install Cubase Elements at all, if you have Cubase Elements remove it as its not needed.
    If you have been using Steinberg trial Instruments with Library’s there is no need to remove them
    !!!! Remember to Disable your windows Defender Antivi ...查看全文
  • octave  2020-5-7 21:26
    Easy Audio Mixer 2.6.0 MacOS
    Easy Audio Mixer Mac版是Mac平台上的一款简单易用的音频编辑工具。Easy Audio Mixer Mac版可以帮我们剪切音频,混合音频,从视频文件中分割音频,还可以将多个音频合并为一个。
    软件特色
    Easy Audio Mixer Mac版非常易于使用,只需要进行几次拖放操作,你就可以快速轻松地完成音频剪辑的工作。
    支持几乎所有流行的音频格式,包括但不限于mp3,m4a,wav,wma等。支持几乎所有可以分割音频的流行视频格式,如mp4,wmv,rmvb等。
    支持实时预览结果。支持音频切割,合并,分割和混音。支持音量调节,淡入/淡出效果。支持以mp3 / m4a / wav格式输出。
    File size: 16 MB
    Easy audio mixer is a simple audio editor tool and is easy to use. You can use it to cut audio, mix audio, split audio from video file, and also merge multi audios into one.
    Key feature:
    Support almost all popular audio format, including but not limited to mp3, m4a, wav, wma etc
    Support almost all popular video format from which you can split audio, such as mp4, wmv, rmvb etc
    Easy to use. You can quickly and easily finish the task by only a fe ...查看全文
  • octave  2020-5-7 21:25
    多轨音频/MIDI音序器 – Cockos REAPER 6.07 WIN
    REAPER是一个多轨音频/MIDI音序器,但由于其便宜的价格,出色的性能,完整的功能,娇小的身材,立刻被广大平民音乐人所推崇。REAPTER是Rapid Environment for Audio Prototyping and Efficient Recording的缩写,也就是音频原型与高性能录音的快速环境。
    据说REAPER的核心开发人员是从前Winamp公司跳槽出来的,可见水平还是很有保证的。
    REAPER是一款工作站级别的专业音乐制作软件,包含多轨录音、音频混缩、MIDI编辑与母带处理等多项功能。软件采用64位音频引擎,支持目前流行的各类DX、VST音频插件与软音源,并自带多个品质出色的音频效果器。
    正常运行REAPER,对计算机软硬件的要求很低。但是为了最大限度的发挥其功能,并提高工作效率,我们推荐采用如下配置:多核处理器,Windows 2000/XP/Vista,1G内存,至少1G的空闲磁盘空间,1280×1024显示分辨率,24位真彩色,支持ASIO音频驱动的专业音频卡或音频 接口。
    Cockos REAPER v6.x WiN | 18.28 Mb
    REAPER is a complete digital audio production application for Windows and OS X, offering a full multitrack audio and MIDI recording, editing, processing, mixing an ...查看全文
  • octave  2020-5-7 21:24
    Steinberg Cubase Elements v10.5.12 WIN
    Cubase是由德国Steinberg公司所开发的全功能数字音乐/音频工作站软件,其主要定位是Advanced Music Production System,即“高级的音乐制作系统”,是广大音乐制作者以及个人音乐工作室最青睐的工作站软件之一。对MIDI音序功能,音频编辑处理功能,多轨录音缩混功能,视频配乐以及环绕声处理功能均属世界一流,帮助你一站式完成从作曲,到编配,到录音,到缩混和母带处理的全部过程。因此,它获得全球无数专业用户的喜爱,多次赢得业内国际大奖,被誉为全世界最优秀的音乐工作站软件。特别是Steinberg公司推出的VST虚拟工作室技术,彻底解决了多年以来约束电脑音乐制作的种种弊病,而在全球范围内制定了电脑音乐行业的新规格,大大的开拓了电脑音乐制作以及音频处理的美好前景。
    File Size : 139 MB
    Cubase Elements is your personal music studio, incorporating professional workflows as used by countless professional artists around the globe. Using the same technology platform as its larger siblings in the Cubase family, Cubase Elements offers tools for intuitive song-writing, instruments to develop your mus ...查看全文
  • octave  2020-5-7 21:21
    调整音响到底要用什么 软件做标准
    调整音响到底要用什么 软件做标准?
    调整音响绝对是一门学问。许多音响迷听了一辈子的音响,却永远觉得音响不够好听,到最后宣布放弃。这就是没有把音响系统调整好的结果。音响系统到底要怎么调整?器材搭配是一门学问、空间处理也是一门学问,但我认为最重要的,是喇叭摆放位置的调整。如果你有一个可以自由施展的空间、如果你有真的「用音响听好音乐」的崇高动机。你没有理由不自己动手调整出一个正确的喇叭摆放位置。
    「摆位」与「定位」没有关系
    因为调整的是喇叭的「位置」,很多人就很自然的认为调整喇叭位置是为了要听「定位」。事实上,对也不对。而且我可以很有把握的告诉你:如果你是用音像定位当做调整喇叭位置的参考标准,你永远也找不到正确的摆放位置!为什么?因为听定位,注重的是音效,而音效的真相在哪里?别说你不知道、我不知道,就连录音的制作人、录音师、演出者都不会知道!拿没人知道真相的东西当做调整的标准,这是多么虚无飘渺的一件事情?
    喇叭的摆位,是为了找到一个让声音各个频段声音能量均衡分布的点。为什么要让各个频段声音能量均衡?因为唯有这样,我们才能听到乐器不被扭曲的正确声音表现;唯有这样,我们才能听到音乐要表达的东西。我在以 ...查看全文
GMT+8, 2025-10-10 17:09 , Processed in 0.018466 second(s), 7 queries , Redis On.
