ÇúÆ×ɨÃèÈí¼þCapella v8.0.11
´òÆ×Èí¼þ
Scan sheet music with capella-scan. Dispatch re-typing of sheet music to a nuisance of the past Let capella-scan transform your sheet music quickly into a ringing score that is ready for editing and printing!
What sounds like magic has become reality
capella-scan has put an end to the laborious task of typing out notes! At last, there is now a way of transposing printed notes and creating part extraction from a printed score without having to type out sheet music note-for-note.
How it works
capella-scan activates your scanner directly.
- You can use all scanners with Twain interface.
- The note and text recognition function is activated at a click. capella-scan has been developed to recognize notes including bar lines, accidentals, clefs etc. and to transform sheet music into capella files. The entire process takes only a few seconds.
- Text is recognized and handed over correctly to capella. Small adjustments can be done directly in capella-scan.
By opening the scanned file in capella notation software (available separately), you can print the file to your specifications. You will find that all the notation program's score editing functions are available for editing your new file. You can, of course, also produce part extraction or change the notes yourself - there are no editing restrictions whatsoever.
What can capella-scan do:
Lines at variable heights?
capella-scan is also capable of recognizing lines at varying heights in the score.
Your sheet music contains text?
capella-scan distinguishes between text objects (titles, articulation symbols, lyrics) and chord or voice names. In capella, you will find everything in its correct place! This saves a lot of your time.
Was the scan somewhat dirty?
No reason to worry. capella-scan is capable of tolerating slightly slanted lines.
Would you like to see the results of the recognition process right away - preferably superimposed onto the original itself?
capella-scan plots the objects (notes etc.) that it has recognized directly into the scanned notes - and in color! So there's no need to spend extra time comparing and contrasting between two windows as is often the case for other note scanning programs.
Would you like to avoid using the indirect route via Midi format?
capella-scan has been optimized for capella: Many of the score layout's properties such as vertical intervals, accolade brackets, the size of note lines etc. are passed on to capella by capella-scan. This means that you will not have to edit the layout afterwards.
Would you like to use capella-scan in conjunction with your existing music program?
Thanks to its MusicXML and Midi export function, capella-scan provides you with contact to the outside world. Indeed, you can use capella-scan in conjunction with other software products.
Comfortable voice management
Music recognition programs have to work very hard when several voices appear in a single line. In actual fact, this is the point where many of the other programs on the market reach their limitations. Yet capella-scan has been developed to accomplish its task even when faced with these difficult situations. Drawing on its excellent voice management system, capella-scan analyses and establishes the right connections and assigns all notes to their correct vertical and horizontal positions.
Text recognition in 100 languages
capella-scan uses the FineReader engine from ABBYY to recognize text. To this end, then, you will automatically benefit from the world's best OCR technology recognizing even gothic print. A large number of reviews have confirmed that this is the best text recognition program there is. capella-scan comes with over 100 dictionaries, which can be installed if and when you need them. capella-scan's text recognition system uses these dictionaries to check the recognized text for its plausibility.
Eighth rest or smudge?
capella-scan can recognize pitch and pitch length, rests, accidentals, keys, key signature and time signature. It also recognizes brackets and curly braces, distances between staves, slurs, ties, repeat boxes, articulation signs, staff size, cue notes and much more. Note recognition is a very demanding process that requires software to accomplish something that in principle is only possible with human experience. When is an undefined mark on the music sheet a note, an eighth rest or simply a smudge?
Óοͣ¬Èç¹ûÄúÒª²é¿´±¾ÌûÒþ²ØÄÚÈÝÇë»Ø¸´
ËÍÔÞ ・1
ÆÀÂÛÁÐ±í£¨22£©
Ó¢ÎÄÌ«²î£¬¿´²»¶®£¬😢
2020-4-7 23:18:38 1 »Ø¸´
ºÃÈí¼þ¿ÉÒÔºº»¯Âð£¿ÀÏʦ
2019-9-29 22:42:42 »Ø¸´
capella(ÀÖÆ×ÖÆ×÷Èí¼þ)
capellaÊÇÒ»¿îרҵÓÅÐãµÄµÄÀ֯״´×÷Èí¼þ£¬capellaΪÄúÌṩÁùÖÖ²»Í¬µÄÀÖÆ××ÖÌ壬´ÓÎÄÒÕ¸´ÐËʱÆÚµÄÒôÀÖµ½¾ôÊ¿ÀÖ¡£ËüÄܹ»°ïÖúÓû§ÇáËɵÄÖÆ×÷À֯ף¬²Ù×÷¼òµ¥¡¢¹¦ÄÜÇ¿´ó¡£
Èí¼þÌØÉ«
¡¡¡¡¿¨ÅåÀ­ÎÞ´¦²»ÔÚ
¡¡¡¡ÔÚ±´¶à·Ò£¬°ÍºÕºÍÀ׸ñ¶ûµÄ¹ú¼Ò£¬¿¨ÅåÀ­ÒѾ­³ÉΪ¸÷Ðи÷ÒµÒôÀÖ¼ÒÖÐÀÖÆ×±à¼­µÄÊÂʵÉϵıê×¼¡£
¡¡¡¡¶ÀÌØµÄ¸ÅÄî
¡¡¡¡ËäÈ»³õѧÕß½«Äܹ»Á¢¼´¼Ç¼ËûÃǵĴ´Ò⣬µ«×¨ÒµÈËÊ¿½«¼ÌÐøÏíÊÜÆä¾Þ´óµÄ¹¦ÄܺͿÉÄÜÐÔ¡£
¡¡¡¡×¨ÒµµÄ´òӡЧ¹û
¡¡¡¡ËûÃÇÀ´×Ô´«Í³µÄ¼ÇÆ×¹¤½³¡£
¡¡¡¡×¨ÒµÈËÊ¿ºÍÒµÓà°®ºÃÕߵķûºÅ½â¾ö·½°¸
¡¡¡¡ÊäÈë±Ê¼ÇµÄÎåÖÖ¼òµ¥·½·¨¡£
¡¡¡¡±íʾ·¨×ÖÌåºÍÑùʽ
¡¡¡¡capellaΪÄúÌṩÁùÖÖ²»Í¬µÄÀÖÆ××ÖÌ壬´ÓÎÄÒÕ¸´ÐËʱÆÚµÄÒôÀÖµ½¾ôÊ¿ÀÖ¡£Äú»¹¿ÉÒÔÔÚ²»Í¬µÄÑùʽÖб£´æ×Ô¼ºµÄÐÂ×ÖÌå»ò±äÌåÒÔ¼°´ÓÏÖÓÐ×ÖÌåÖлñÈ¡µÄ¡°ÔÓ½»¡±¡£Ñùʽģ°å¿ÉÒÔµ¥¶À·ÖÅ䏸ÄúµÄ·ÖÊý¡£¼øÓÚcapellaÈÃÄã³ÊÏÖûÓо¥ºÍ/»òûÓÐÍ·µÄÒô·û£¬ÄÇЩϲ»¶ÊÔÑéµÄÈ˼¸ºõ²»»á·¢ÏÖ¶¨Òåµ¥¸ö·ûºÅµÄ¿ÉÄÜÐÔ¡£(ÔÚcapella¿ªÊ¼ÄãÖ»ÄÜʹÓñê×¼·ç¸ñµÄÄ£°å¡£)
¡¡¡¡ÌýºÍ»Ø·Å
¡¡¡¡capellaÖ§³Ö¶ÀÌØµÄcapella-tune¼¼Êõ£¬ÈÃÄúÍêÈ«¿ØÖÆcapellaµÄÉ«µ÷µ÷É«°å¡£¸ù¾ÝÒ¡°Ú»ò»ª¶û×ȽÚ×࣬²üÒô£¬¶¯Ì¬½¥±ä£¬Ö§³Ö¿¨ÅåÀ­Î¬Ò²ÄÉÀÖÍÅ£¬»ØÉùЧ¹ûºÍ»Ø·ÅµÈ×°Êζ¼ÔڻطŹý³ÌÖеõ½·´Ó³¡£
¡¡¡¡½«Í¼ÐÎÌí¼Óµ½ÀÖÆ×ÖÐ
¡¡¡¡ÍÐÅÌʹÓÃÊó±ê´ÓÔ¤¶¨ÒåµÄÍÐÅÌÖÐÑ¡ÔñͼÐζÔÏó¡£×¨¼Ò¿ÉÒÔʹÓÃcapella×Ö·û¼¯ÖеķûºÅÀ´¶¨Òå×Ô¼ºµÄÍÐÅÌ¡£
¡¡¡¡»¶Ó­À´µ½Í¼Ðοâ!
¡¡¡¡¿ÉÒÔΪÿ¸ö·ÖÊý´´½¨Í¼ÐοⲢ½«Æä¸½¼Óµ½Ã¿¸ö·ÖÊý¡£Í¼¿â´æ´¢Äú¾­³£Ê¹ÓõÄͼÐζÔÏó¡£capellaÅäÓм¸¸öÓÐȤµÄ»­ÀÈ£¬ÆäÖаüº¬ÌØÊâ·ûºÅ£¬¼ªËûÒôÆ·µÈµÈ¡£
¡¡¡¡¶à¹¦ÄÜͼÐζÔÏó
¡¡¡¡ËùÓÐͼÐζÔÏ󶼿ÉÒÔËõ·Å£¬À­ÉìºÍѹËõ£¬²¢¿ÉÒÔ·ÅÔÚÒô·ûµÄÇ°Ãæ»òºóÃæ¡£ÕâÑù£¬¸²¸ÇÕû¸öÒ³ÃæµÄˮӡ¿ÉÒÔ·ÅÔÚÀÖÆ×ÏÂÃæ¡£
2020-2-10 15:58:34 »Ø¸´
ллÀÏʦµÄÎÞ˽·ÖÏí£¡
2020-3-23 11:49:16 »Ø¸´
¿´¿´Ò»£¬Ðв»ÐÐÄØ
2020-3-29 15:45:43 »Ø¸´
2020-3-30 16:12:21 »Ø¸´
¿´¿´Ò»£¬Ðв»ÐÐÄØ
2020-4-3 03:28:47 »Ø¸´
Õâ¸öÊÇÕæµÄNB
2020-4-4 17:42:30 »Ø¸´
ÕâÈí¼þÓÐMAC°æÂð£¿Ê¶±ð¹¦ÄÜÈçºÎ
2020-5-3 21:32:00 »Ø¸´
ÒÔºó°Ç´ø¾Í¼òµ¥¶àÁË
2020-5-4 15:56:58 »Ø¸´
һƬÍôÑó´óº£¿´²»¼ûŶ¡£¡£¡£
2020-6-20 00:17:22 »Ø¸´
¶Ô²»Æð¸Õ¿´µ½È·ÊµºÃ¶«Î÷¡£¡£
2020-6-20 00:18:39 »Ø¸´
²»ÖªÄÜ·ñ¡°Ê¶±ð  ¼òÆ×¡±£¿
2020-6-27 18:37:06 »Ø¸´
Èç¹ûÄܹ»¡°Ê¶±ð  ¼òÆ×¡±£¬ÄÇ¿ÉÌ«·½±ãÀ²£¡
2020-6-27 18:38:18 »Ø¸´
Õâ¸öºÜ²»´í£¡
2020-6-28 00:29:47 »Ø¸´
¿´²»¶®¿´²»¶®¿´²»¶®¿´²»¶®
2020-11-3 15:23:49 »Ø¸´
ÃÎÃÂÒÔÇóµÄÈí¼þÀàÐÍÖ®Ò»!
2020-11-4 18:00:50 »Ø¸´
Ã÷Ìì´ò¿ªµçÄÔÒ»¶¨¼°Ê±ÏÂÔØ!
2020-11-4 18:04:57 »Ø¸´
»¹ÒªÓÐÒ»¸öÓ²¼þɨÃèÒÇ  OCRʶ±ð²ÅÄÜ ×¼È·¶È¸ß.²»È»ÊÖ»úÅijöÀ´µÄ¿ÉÄÜ»á±äÐÎ.Ó°Ïìʶ±ð.
2020-11-5 20:40:10 »Ø¸´
