ÒôÆµÂ¼ÖÆÒÔ¼°²¥·Å
Ò»°ãµÄÒôƵӦÓÃÖУ¬ÍùÍùÐèÒªÖ§³ÖÒôƵµÄʰȡÊäÈëÒÔ¼°ÒôƵµÄ²¥·ÅÊä³ö¡£LPC5411x¾ßÓÐI2SÒôƵ½Ó¿ÚÒÔ¼°Ë«Í¨µÀPDMÊý×ÖÂó¿Ë·ç½Ó¿Ú£¬ÆäÖÐÊý×ÖÂó¿Ë·ç½Ó¿ÚÖ§³ÖоƬÉî¶È˯ÃßʱµÄÓïÒô¼¤»î£¬·Ç³£ÊʺÏÓÚÒôƵ£¬ÓÈÆäÊǵ͹¦ºÄÒôƵµÄÓ¦Óá£
1. I2S
LPC5411xÄÚÖÃÁË8¸öFlexcomm½Ó¿ÚÓÃÓÚÖ§³Ö´®ÐÐÍâÉ裬ÆäÖÐFlexcomm 6ºÍFlexcomm 7¿ÉÒÔÅäÖóÉI2S½Ó¿Ú¡£Ã¿¸öI2S½Ó¿ÚÖ»ÄÜÖ§³ÖÒôƵµÄ°ëË«¹¤´«Ê䣬¼´I2SÊý¾Ý¿ÚÖ»ÄÜÅäÖóÉÊäÈë»òÕßÊä³ö¡£ÍòÀûµÄLCP5411x¿ª·¢°å°åÔØÁËÒ»¿ÅWM8904ÒôƵ±à½âÂëÆ÷£¬Ö§³ÖLine inÊäÈëÒÔ¼°¶ú»úÊä³ö£¬Í¨¹ýFlexcomm 7Á¬½ÓÒôƵÊä³öÁ÷£¬Flexcomm 6Á¬½ÓÒôƵÊäÈëÁ÷£¬´Ó¶ø¹¹³ÉI2SµÄȫ˫¹¤´«Êä¡£
I2SµÄ³õʼ»¯¹ý³ÌÈçÏ£º
a. ÔÚpin_mux.cÖгõʼ»¯I2SµÄ¹¦ÄÜÒý½Å¡£
// I2S FC6
uint32_t i2s_config = {
IOCON_FUNC1 |
IOCON_MODE_INACT|
IOCON_DIGITAL_EN|
IOCON_INPFILT_OFF
IOCON_PinMuxSet(IOCON, 0, 5,i2s_config); // PIO0_5 DATAO
IOCON_PinMuxSet(IOCON, 0, 6,i2s_config); // PIO0_6 WSO
IOCON_PinMuxSet(IOCON, 0, 7,i2s_config); // PIO0_7 BCKO
// FC7
i2s_config = IOCON_FUNC4 | IOCON_MODE_INACT |
IOCON_DIGITAL_EN | IOCON_INPFILT_OFF;
IOCON_PinMuxSet(IOCON, 1, 12,i2s_config); // PIO1_12 BCKI
IOCON_PinMuxSet(IOCON, 1, 13,i2s_config); // PIO1_13 DATAI
IOCON_PinMuxSet(IOCON, 1, 14,i2s_config); // PIO1_14 WSI
IOCON_PinMuxSet(IOCON, 1, 17,i2s_config); // PIO1_17 MCKL
b. ÉèÖÃI2SÍâÉèʱÖÓ£¬Ê¹ÓÃPLLʱÖÓ£¬24.576MHz¡£
const pll_setup_t pllSetup = {
.syspllctrl =SYSCON_SYSPLLCTRL_BANDSEL_MASK | SYSCON_SYSPLLCTRL_SELP(0x1FU) |SYSCON_SYSPLLCTRL_SELI(0x8U),
.syspllndec =SYSCON_SYSPLLNDEC_NDEC(0x2DU),
.syspllpdec =SYSCON_SYSPLLPDEC_PDEC(0x42U),
.syspllssctrl= {SYSCON_SYSPLLSSCTRL0_MDEC(0x34D3U) | SYSCON_SYSPLLSSCTRL0_SEL_EXT_MASK,0x00000000U},
.pllRate =24576000U,
.flags =PLL_SETUPFLAG_WAITLOCK};
/* InitializePLL clock */
CLOCK_AttachClk(kFRO12M_to_SYS_PLL);
CLOCK_SetPLLFreq(&pllSetup);
/* I2S clocks*/
CLOCK_AttachClk(kSYS_PLL_to_FLEXCOMM6);
CLOCK_AttachClk(kSYS_PLL_to_FLEXCOMM7);
c. ÉèÖÃI2SµÄÖ÷ʱÖÓMCLKÊä³ö£¬1·ÖƵ£¬MCLKÊä³ö24.576MHzʱÖÓ¡£
/* Attach PLLclock to MCLK for I2S, no divider */
CLOCK_AttachClk(kSYS_PLL_to_MCLK);
SYSCON->MCLKDIV= SYSCON_MCLKDIV_DIV(0U);
SYSCON->MCLKIO= 1U;
d. ÉèÖÃI2S1ΪÖ÷»úģʽ£¬ÏàÓ¦µÄÊý¾Ý¸ñʽ£¬²¢³õʼ»¯¡£I2S1µÄ¼Ä´æÆ÷»ùÖ·¶ÔÓ¦Flexcomm 7µÄ¼Ä´æÆ÷»ùÖ·£¬ÔÚÖ÷»úģʽ£¬ÓÉÖ÷»ú²úÉúλʱÖÓ¡¢Ö¡Ê±ÖÓÕâЩͬ²½Ê±ÖÓ£¬Í¨¹ýI2STxConfig.divider·ÖƵ¾ö¶¨I2SµÄλʱÖÓ£¬ÔÚ48·ÖƵʱ£¬Î»Ê±ÖÓΪ24.576MHz / 48 =512KHz£¬16볤£¬Ë«Í¨µÀ¶ÔÓ¦µÄ²ÉÑùÂÊΪ24.576MHz / 48 / 16 / 2 = 16K¡£
* masterSlave = kI2S_MasterSlaveNormalMaster;
* mode = kI2S_ModeI2sClassic;
* rightLow = false;
* leftJust = false;
* pdmData = false;
* sckPol = false;
* wsPol = false;
* divider = 1;
* oneChannel = false;
* dataLength = 16;
* frameLength = 32;
* position = 0;
* fifoLevel = 4;
I2S_TxGetDefaultConfig(&I2STxConfig);
I2STxConfig.divider = 48; //24576000/16/2/48=16k
I2S_TxInit(I2S1, &I2STxConfig);
e. ÉèÖÃI2S0Ϊ´Ó»úģʽ£¬ÏàÓ¦µÄÊý¾Ý¸ñʽ£¬²¢³õʼ»¯¡£I2S0µÄ¼Ä´æÆ÷»ùÖ·¶ÔÓ¦Flexcomm 6µÄ¼Ä´æÆ÷»ùÖ·£¬ÔÚ´Ó»úģʽ£¬´Ó»úµÄλʱÖÓ¡¢Ö¡Ê±ÖÓͬ²½µ½Ö÷»úµÄλʱÖÓ¡¢Ö¡Ê±ÖÓ¡£
* masterSlave = kI2S_MasterSlaveNormalSlave;
* rightLow = false;
* leftJust = false;
* pdmData = false;
* sckPol = false;
* wsPol = false;
* divider = 1;
* dataLength = 16;
* frameLength = 32;
* position = 0;
* watermark = 4;
* txEmptyZero = false;
* pack48 = true;
I2S_RxGetDefaultConfig(&I2SRxConfig);
I2S_RxInit(I2S0, &I2SRxConfig);
f. ÉèÖÃI2SµÄDMAͨµÀ´«Ê䣬DMA´«Êä¿ÉÒÔ¼õÉÙCPU¶ÔÒôƵÁ÷µÄ²ÎÓë´¦Àí£¬´Ó¶ø½µµÍCPUµÄ¸ºÔØ¡£Í¨³£ÒôƵÊý¾ÝµÄ´¦ÀíÒÔ֡Ϊµ¥Î»£¬·½±ãÒôƵ±à½âÂ룬´ò°ü´«ÊäµÈ´¦Àí£¬µ±DMAÍê³ÉÒ»Ö¡»º´æ´«Êäʱ£¬Í¨¹ýÖжÏ֪ͨCPU´¦ÀíÏÂÒ»Ö¡»º´æµÄDMA´«Êä¡£
DMA_EnableChannel(DMA0, I2S_TX_CHANNEL);
DMA_EnableChannel(DMA0, I2S_RX_CHANNEL);
DMA_SetChannelPriority(DMA0,I2S_TX_CHANNEL, kDMA_ChannelPriority3);
DMA_SetChannelPriority(DMA0,I2S_RX_CHANNEL, kDMA_ChannelPriority2);
DMA_CreateHandle(&I2STxDmaHandle,DMA0, I2S_TX_CHANNEL);
DMA_CreateHandle(&I2SRxDmaHandle,DMA0, I2S_RX_CHANNEL);
I2S_TxTransferCreateHandleDMA(I2S1,&I2STxHandle, &I2STxDmaHandle, I2STxCallback, (void*)&I2STxTransfer);
I2S_RxTransferCreateHandleDMA(I2S0,&I2SRxHandle, &I2SRxDmaHandle, I2SRxCallback, (void*)&I2SRxTransfer);
g. I2S×¼±¸¾ÍÐ÷ºó£¬¿ÉÒÔͨ¹ýI2S_TxStart()º¯ÊýÆô¶¯Êä³öÖ¡»º´æµ½ÒôƵÊä³öÁ÷µÄDMA´«Ê䣬ͨ¹ýI2S_RxStart()º¯ÊýÆô¶¯ÒôƵÊäÈëÁ÷µ½ÊäÈëÖ¡»º´æµÄDMA´«Êä¡£
void I2S_TxStart(void)
I2SState.TxReadIndex = 0;
I2STxTransfer.data = (volatile uint8_t*)I2SState.TxBuffer[0];
I2STxTransfer.dataSize =sizeof(I2SState.TxBuffer[0]);
I2S_TxTransferSendDMA(I2S1,&I2STxHandle, I2STxTransfer);
I2SState.TxWriteIndex = 1;
void I2S_RxStart(void)
I2SState.RxWriteIndex = 0;
I2SRxTransfer.data = (volatile uint8_t*)I2SState.RxBuffer[0];
I2SRxTransfer.dataSize = sizeof(I2SState.RxBuffer[0]);
I2S_RxTransferReceiveDMA(I2S0,&I2SRxHandle, I2SRxTransfer);
I2SState.RxWriteIndex = 1;
I2SRxTransfer.data = (volatile uint8_t*)I2SState.RxBuffer[1];
2. ÒôƵ±à½âÂëÆ÷
¿ª·¢°å°åÔØÁËWM8904ÒôƵ±à½âÂëÆ÷£¬Í¨¹ýI2CÉèÖÃWM8904ÄÚ²¿¼Ä´æÆ÷£¬ÉèÖÃΪ´Ó»úģʽ£¬ÏàÓ¦µÄÊý¾Ý¸ñʽ¡£
a. ÔÚpin_mux.cÖгõʼ»¯I2CµÄ¹¦ÄÜÒý½Å¡£
const uint32_t i2c_config = (
IOCON_FUNC5 |
IOCON_DIGITAL_EN|
IOCON_INPFILT_OFF|
IOCON_OPENDRAIN_EN
IOCON_PinMuxSet(IOCON,1, 1, i2c_config); // PIO1_1 SCL
IOCON_PinMuxSet(IOCON,1, 2, i2c_config); // PIO1_2 SDA
b. ÉèÖÃI2CÍâÉèʱÖÓ£¬Ê¹ÓÃFROʱÖÓ12MHz¡£
/* I2C clock */
CLOCK_AttachClk(kFRO12M_to_FLEXCOMM4);
/* reset FLEXCOMM for I2C */
RESET_PeripheralReset(kFC4_RST_SHIFT_RSTn);
c. ÉèÖÃI2CΪÖ÷»úģʽ£¬ÏàÓ¦µÄ²¨ÌØÂÊ£¬²¢³õʼ»¯¡£
* enableMaster = true;
* baudRate_Hz = 100000U;
* enableTimeout = false;
I2C_MasterGetDefaultConfig(&i2cConfig);
i2cConfig.baudRate_Bps =WM8904_I2C_BITRATE;
I2C_MasterInit(I2C4, &i2cConfig,12000000);
d. ³õʼ»¯WM8904ÒôƵ±à½âÂëÆ÷¡£
WM8904_GetDefaultConfig(&codecConfig);
codecHandle.i2c = I2C4;
if (WM8904_Init(&codecHandle,&codecConfig) != kStatus_Success) {
PRINTF("WM8904_Initfailed!\r\n");
return;
/* Adjust it to your needs, 0x0006 for-51 dB, 0x0039 for 0 dB etc. */
WM8904_SetVolume(&codecHandle,0x0030, 0x0030);
3. DMIC
DMIC (digital microphoneinterface)Ö§³ÖPDMÊä³öµÄÊý×ÖÂó¿Ë·ç½Ó¿Ú¡£¿ª·¢°å°åÔØÁËSPH0641LM4HÊý×ÖÂó¿Ë·ç£¬´ÓÊý×ÖÂó¿Ë·ç»ñÈ¡µÄPDMÊý¾Ý¿ÉÒÔͨ¹ýһϵÁеÄÂ˲¨Æ÷»¹Ô³öÏàÓ¦µÄ²¨ÐΣ¬ÔÙ²ÉÑù»ñµÃ¶ÔÓ¦µÄPCMÊý¾Ý¡£PCM²ÉÑùÂÊÓÉDMICʱÖÓÒÔ¼°¹ý²ÉÑùÂÊ(OSR)¾ö¶¨£¬²ÉÑùÂʹ«Ê½ÈçÏ£º
ÀýÈ磬DMICµÄʱÖÓ800KHz£¬¹ý²ÉÑùÂÊOSRΪ25£¬ÔÚ2 FSģʽ£¬¶ÔÓ¦µÄPCM²ÉÑùÂÊΪ16K¡£
a. ÔÚpin_mux.cÖгõʼ»¯DMICµÄ¹¦ÄÜÒý½Å¡£
const uint32_t dmic_config = (
IOCON_FUNC1|
IOCON_MODE_INACT|
IOCON_DIGITAL_EN|
IOCON_INPFILT_OFF
IOCON_PinMuxSet(IOCON,1, 15, dmic_config); // PIO1_15 PDM0_CLK
IOCON_PinMuxSet(IOCON,1, 16, dmic_config); // PIO1_16 PDM0_DATA
b. ÉèÖÃDMICÍâÉèʱÖÓFROʱÖÓ12MHz£¬ÏàÓ¦µÄ½Ó¿ÚʱÖÓ800KHz¡£
/* DMIC uses 12MHz FRO clock */
CLOCK_AttachClk(kFRO12M_to_DMIC);
/*12MHz divided by 15 = 800KHz PDM clock*/
CLOCK_SetClkDiv(kCLOCK_DivDmicClk, 15,false);
c. ÉèÖÃDMIC¹ý²ÉÑùÂÊ£¬ÏàÓ¦µÄÔöÒæ£¬16λÊý¾Ý£¬²¢³õʼ»¯¡£
dmic_channel_cfg.divhfclk =kDMIC_PdmDiv1;
dmic_channel_cfg.osr = 25U;
dmic_channel_cfg.gainshft = 3U;
dmic_channel_cfg.preac2coef =kDMIC_CompValueZero;
dmic_channel_cfg.preac4coef =kDMIC_CompValueZero;
dmic_channel_cfg.dc_cut_level =kDMIC_DcCut155;
dmic_channel_cfg.post_dc_gain_reduce =1U;
dmic_channel_cfg.saturate16bit = 1U;
dmic_channel_cfg.sample_rate =kDMIC_PhyFullSpeed;
DMIC_Init(DMIC0);
DMIC_ConfigIO(DMIC0, kDMIC_PdmDual);
DMIC_Use2fs(DMIC0, true);
DMIC_SetOperationMode(DMIC0,kDMIC_OperationModeDma);
DMIC_ConfigChannel(DMIC0,kDMIC_Channel0, kDMIC_Left, &dmic_channel_cfg);
DMIC_FifoChannel(DMIC0, kDMIC_Channel0,FIFO_DEPTH, true, true);
d. ÉèÖÃDMICµÄDMA´«ÊäͨµÀ¡£
DMA_EnableChannel(DMA0, DMAREQ_DMIC0);
DMA_CreateHandle(&DmicDmaHandle,DMA0, DMAREQ_DMIC0);
DMIC_TransferCreateHandleDMA(DMIC0,&DmicHandle, DMIC_Callback, &DmicTransfer, &DmicDmaHandle);
DMA_SetChannelPriority(DMA0,DMAREQ_DMIC0, kDMA_ChannelPriority2);
e. DMIC×¼±¸ºÃºó£¬¿ÉÒÔͨ¹ýDmic_Start()º¯ÊýÆô¶¯DMICÒôƵÊäÈëÁ÷µ½Ö¡ÊäÈ뻺´æµÄDMA´«Êä¡£
void Dmic_Start(void)
DmicTransfer.data = (uint16_t*)DmicState.Buffer;
DmicTransfer.dataSize = sizeof(DmicState.Buffer[0]);
DMIC_TransferReceiveDMA(DMIC0,&DmicHandle, &DmicTransfer, kDMIC_Channel0);
DMIC_EnableChannnel(DMIC0,DMIC_CHANEN_EN_CH0(1));
4. Ó¦ÓÃÀý³Ì
mainº¯ÊýÀý³ÌʵÏÖ°ÑÒôƵ±à½âÂëÆ÷ÊäÈëÁ÷DMA´«Êäµ½ÒôƵÊäÈ뻺´æ£¬ÒôƵÊäÈ뻺´æ²»¾¹ýÈκδ¦Àí£¬Ö±½ÓÊä³öµ½ÒôƵÊä³ö»º´æ£¬DMAÔÙ°ÑÊä³ö»º´æ´«Êäµ½ÒôƵ±à½âÂëÆ÷Êä³öÁ÷ÖУ¬ÊµÏÖÒôƵ±à½âÂëÆ÷Line inµÄ»Ø·Å¡£Ò²¿ÉÒÔ°ÑÊý×ÖÂó¿Ë·ÖµÄÊäÈëÁ÷DMA´«Êäµ½Âó¿Ë·çÊäÈ뻺´æ£¬²¢¿½±´µ½ÒôƵÊä³ö»º´æ£¬DMA´«Êäµ½ÒôƵ±à½âÂëÆ÷Êä³öÁ÷ÖУ¬ÊµÏÖÊý×ÖÂó¿Ë·çµÄʰȡ»Ø·Å¡£
int main(void)
int i;
int Select;
/* Board pin, clock, debug console init*/
CLOCK_EnableClock(kCLOCK_InputMux);
CLOCK_EnableClock(kCLOCK_Gpio0);
CLOCK_EnableClock(kCLOCK_Gpio1);
/* USART0 clock */
CLOCK_AttachClk(BOARD_DEBUG_UART_CLK_ATTACH);
BOARD_InitPins();
BOARD_BootClockFROHF96M();
BOARD_InitDebugConsole();
Gpio_Init();
DMA_Init(DMA0);
I2S_Init();
Codec_Init();
Dmic_Init();
I2S_TxStart();
Select = 1;
if (Select) {
// codec linein
I2S_RxStart();
while(1) {
if(I2SState.RxEvent) {
for(i=0; i<AUDIO_FRAME_SIZE; i++) {
I2SState.TxBuffer[I2SState.TxWriteIndex]= I2SState.RxBuffer[I2SState.RxReadIndex];
if(I2SState.RxReadIndex >= AUDIO_NUM_BUFFERS-1) {
I2SState.RxReadIndex= 0;
}else {
I2SState.RxReadIndex++;
if(I2SState.TxWriteIndex >= AUDIO_NUM_BUFFERS-1) {
I2SState.TxWriteIndex= 0;
}else {
I2SState.TxWriteIndex++;
I2SState.RxEvent= 0;
} else {
//digital mic
Dmic_Start();
while(1) {
if(DmicState.Event) {
I2SState.TxBuffer[I2SState.TxWriteIndex]= DmicState.Buffer[DmicState.ReadIndex];
if(DmicState.ReadIndex >= AUDIO_NUM_BUFFERS-1) {
DmicState.ReadIndex= 0;
}else {
DmicState.ReadIndex++;
}else {
DmicState.Event= 0;
