SHURE EZG12SE ¶ì¾±µçÈÝ»áÒ黰Ͳ(30CM)
liaoyin
2010-2-8 13:43:10
ÆäËü²úÆ·
SHURE EZG12SE ¶ì¾±µçÈÝ»áÒ黰Ͳ(30CM)ÊÛ¼Û£º£¤1350Ôª
Êæ¶ûEasyflex EZG/12SEÊÇÒ»¸ö΢ÐÍÂó¿Ë·ç¶ì¾±Ê½µçÈÝʽÂó¿Ë·ç £¬ Ö÷ÒªÓÃÓÚÓïÒôºÍÉùÀÖÆ¤¿¨Éè¼Æ¡£ Ëü¿ÉÒÔ°²×°ÔÚ½²Ì¨£¬½²Ì³£¬»ò»áÒé×ÀÉÏ¡£°üÀ¨Ò»¸öǰÖ÷ŴóÆ÷¡£
The Easyflex line of miniature gooseneck condenser microphones are the perfect choice to capture speech and vocals in environments where quality, value and budget are primary considerations. ¶ì¾±µÄ΢Ð͵çÈÝÂó¿Ë·çEasyflex·Ïß £¬ ÊÇÍêÃÀµÄÑ¡Ôñ²¶»ñ½²»°ºÍ»·¾³ÉùÔÚÆ·ÖÊ£¬¼ÛÖµºÍÔ¤ËãµÄÖ÷Òª¿¼ÂÇÒòËØ¡£ The gooseneck condenser microphones feature a cardioid polar pattern, and are available in four different models, dependent on height and mounting application. µçÈÝʽÂó¿Ë·çµÄ¶ì¾±ÐŦÄܵÄÒ»¼«¸ñ¾Ö£¬¶øÇÒÔÚËÄÖÖ²»Í¬µÄÐͺţ¬Ôڸ߶ÈÒÀÀµºÍ°²×°Ó¦ÓóÌÐòÌṩ¡£
Shure Wired Microphone EZG/12SE Features Êæ¶ûÓÐÏßÂó¿Ë·çEZG/12SEÌØµã
Single gooseneck section near microphone base foreasy orientation of the microphone. ¸½½üµÄÂó¿Ë·çÉú²ú»ùµØÂó¿Ë·çµÄ¶ì¾±foreasy·½Ïòµ¥½Ú¡£
Tubular preamp body sized to fit many standardaccessories. ¹ÜǰÖûú¹¹µ÷ÕûÒÔÊÊÓ¦Ðí¶àstandardaccessories¡£
Slide on windscreen. »ÃµÆÆ¬µÄµ²·ç²£Á§¡£
5/8¨C27 threaded nut with ca ble exit provides avariety of mounting possibilities. 5/8-27ÂÝĸÓëCA¾ùºâÆ÷³ö¿ÚÌṩÁËÔ½À´Ô½¶àµÄ¿ÉÄÜÐÔavariety¡£
External preamp reduces visible size of the microphone.ÍⲿǰÖýµµÍÂó¿Ë·ç¿É¼ûµÄ´óС¡£
Shure Wired Microphone EZG/12SE Specifications Êæ¶ûÓÐÏßÂó¿Ë·çEZG/12SE¹æ¸ñ
Frequency Response: 50 to 17,000 Hz ƵÂÊÏìÓ¦£º50ÖÁ17,000 Hz
Polar Pattern: Cardioid Ö¸ÏòÐÔ£ºÐÄ
Output Impedance (at 1 kHz): Rated at 150 ? Êä³ö×迹£¨1ǧºÕ£©£º¶î¶¨150£¿ (180 ?actual) £¨180£¿Êµ¼Ê£©
Open Circuit Sensitivity (at 1 kHz, ref. 1 V/Pascal):¨C45.7 dB (5.19 mV) ¿ªÂ·ÁéÃô¶È£¨ÔÚ1 kHz£¬²Î¿¼¡£1·ü/ÅÁ˹¿¨¶û£©£º-45.7·Ö±´£¨5.19»ú¶¯³µÁ¾£©
Maximum SPL (1 kHz at 1% THD, 1 k? load): 129 dB ×î´óÉùѹ¼¶£¨1 kHzÓÚ1£¥×Üг²¨Ê§Õ棬1ǧ£¿¸ºÔØ£©£ºÒ»°Ù¶þÊ®¾Å·Ö±´
Equivalent Output Noise (A-weighted): 29 dB SPL µÈЧÊä³öÔëÉù£¨A¼ÓȨ£©£º29 dBÉùѹ¼¶
Signal to Noise Ratio (referenced to 94 dB SPL): 65 dB ÐÅÔë±È£¨²Î¿¼94 dBÉùѹ¼¶£©£º65·Ö±´
Dynamic Range (at 1 k? Load): 100 dB ¶¯Ì¬·¶Î§£¨1ǧ£¿¸ºÔØ£©£º100·Ö±´
Common Mode Rejection: 45 dB minimum ¹²Ä£ÒÖÖÆ£º45 dB×îС
Preamplifier Output Clipping Level (1 kHz at 1% THD,1 k? load): ¨C12.0 dBV (0.25 V) ǰÖ÷ŴóÆ÷Êä³öÏÞ·ùµçƽ£¨1 kHzµÄ1£¥×Üг²¨Ê§Õ棬1ǧ£¿¸ºÔØ£©£º-12.0 dBV£¨0.25Î壩
Polarity: Positive sound pressure on diaphragmproduces positive voltage on pin 2 relative to pin 3 of output connector. ¼«ÐÔ£ºÕýÉùѹÔÚÕë½ÅÉÏdiaphragmproducesÕýµçѹ2Ïà¶ÔÓÚÕë½ÅµÄÊä³ö½ÓÍ·3¡£
Power Requirements: 11 to 52 Vdc phantom, 2.0 mA µçÔ´ÒªÇó£º11ÖÁ52 Vdc»ÃÏó£¬2.0 mA
Environmental Requirements »·¾³ÒªÇó
Operating Temperature Range: ¨C18¡ã C to 57¡ã C (0¡ã F to 135¡ã F) ¹¤×÷ζȷ¶Î§£º-18 ¡ã CÖÁ57¡æ£¨0 ¡ã Fµ½135¨H£©
Relative Humidity: 0 to 95% Ïà¶Ôʪ¶È£º0ÖÁ95£¥
Dimensions ³ß´ç
Gooseneck: 12" (305 mm) ¶ì£º12¡°£¨305ºÁÃ×£©
Head Diameter: 0.46" (11.68 mm)Í·Ö±¾¶£º0.46¡°£¨11.68ºÁÃ×£©
ÆÀÂÛÁÐ±í£¨1£©
ÐÀÉÍÖ§³Ö£¡
2010-2-10 09:01:41 »Ø¸´
