Create, produce and perform. Create ideas, make changes without stopping, and capture everything as you work.
If you¡¯ve used music software before, you¡¯re already familiar with one half of Ableton Live. Live¡¯s Arrangement View is a familiar working space: time moves from left to right, while tracks are stacked vertically.
But Live also features the revolutionary Session View: a unique sketchpad for improvising, playing and performing with musical ideas, without the constraints of the timeline. Freely and independently start and stop any number of audio or MIDI loops - everything stays in sync. Almost everything in Live works in real-time - add, reorder or remove devices, play with Live¡¯s flexible track routing and more - all without interrupting your creative flow.
The instruments and sounds you need to make music. Live comes with a collection of instruments, sounds, kits and loops for creating any kind of music.
5 Synths and 3 Samplers
Live¡¯s raw devices are the foundation of sound design in Live, including FM and physical modelling synthesis as well as sampling.
390 Drum kits
Classic analogue drum machines, one-shot samples and multi-sampled acoustic drum kits.
25 Packs
Over 3000 Sounds including vintage synthesisers, acoustic instruments and cutting-edge combinations of sampling, effects and synthesis.
4000 Loops
Audio and MIDI patterns, ready to use in your own productions, covering everything from 60s Soul and Hip Hop to electronica.
Live 9 Suite comes with the full collection of instruments and sounds.
Effects, processing and tweaking. For getting your sound right (or wrong in just the way you like it) Live has a full range of effects from corrective to creative.
34 Audio Effects
Live comes with a wide selection of audio processors, from the classic to the unique
7 MIDI Effects
Devices to rearrange, constrain or randomize MIDI notes for creating endless variations
Live 9 Suite comes with the full collection of audio and MIDI effects.
Work with instruments and effects the way you want to. Live provides easy and flexible ways for combining and integrating all kinds of devices.
External hardware
Use your external hardware synthesizers or effects units as if they were plug-ins, via Live¡¯s unique External Instrument and External Audio Effect devices.
Make your own racks
Racks let you combine multiple instruments and effects into a single device. Each of the eight Macro knobs can be mapped to any number of parameters in a Rack, allowing for customized controls.
VST and Audio Units
Use VST or Audio Units instruments and effects alongside Live¡¯s native devices.
More online
Ableton¡¯s Pack store allows you to browse and download instruments and patches.
Tools that understand audio, instead of just playing it. Live can convert harmony, melody and beats from recordings to MIDI. Live can take the notes from audio files and transform them directly into notes in a MIDI track. This lets you extract harmony, melody or drums from an existing recording or one of your own. Even create new melodies and rhythms using solo instruments or your own voice. Sampling just got much bigger.
Software you can play. Live is even more powerful when it¡¯s hands-on. And it works with instruments and controllers of all kinds:
MIDI controllers
Live works with any MIDI controller and includes instant mapping for the most popular ones.
Multi-touch
Control Live with your iOS or Android device using powerful third-party software
Flexible MIDI and keyboard mappingMap
MIDI knobs, sliders, and buttons or even your computer keyboard to almost every control in Live.
Max for Live
Download or create your own Max devices to customize or extend your controller.
Push. An instrument for song creation that fits in your backpack with your laptop.
Push is designed to help you make songs from scratch. With the Push hardware you get all of the fundamental elements of music making - melody and harmony, beats, sounds, and song structure - at your fingertips. Because it¡¯s powered by Live you still get all the advantages of software when it comes to editing, mixing, mastering and exporting your finished track.
Whatever you want it to be. Get a wealth of new devices, and the ability to make your own, with Max for Live - now included in Suite.
Max for Live, based on Cycling 74's Max 6, is included with Live 9 Suite. Max for Live is an ever-growing collection of inspiring synths, effects and customizations to Live itself, as well as a toolkit for building your own. Live 9 Suite also comes with a collection of our favorite devices from Max for Live¡¯s lively community of artists and creators.
Live 9 comes in three editions: Intro, Standard and Suite. The editions share common features, but Standard and Suite have additional features, Instruments, Packs and Effects.
Description
Ableton Suite 9 is a powerful DAW and music sequencer for MAC and PC with innovative real-time features, and incredible editing capabilities plus a huge library of sounds and instuments.
Ableton Live is one of the stalwarts of music production software, and Suite 9 brings with it many new features and workflow enhancements. New features include Session View clip automation, a new comprehensive browser to find sounds faster, lots of new sounds with preset macro controls, and better effects including the new Glue compressor and EQ Eight. Significantly, a new pitch-to-MIDI engine also allows the extraction of MIDI data from harmonic, rhythmic and drum parts, while Max for Live programming environment is also now included with it's unique instruments, effects and tools.
Suite 9 offers a variety of ways to manipulate your music - conventional "multi-track tape-recorder" type recording, where tracks are recorded in a linear fashion and the song runs sequentially through the track, and another more "on-the-fly" method of playback where clips are triggered, automatically timed, and looped over a number of bars. This clip-triggering method is great for live performance as well as studio production, allowing during-gig tweaks to your music, or even recording loops on the fly. There are a number of dedicated hardware controllers designed to control Ableton Suite 9 in this way, including the Ableton Push, AKAI APC products and Novation Launchpad, making Ableton Live a great tactile musical production environment.
Included with Ableton Suite 9 is a huge selection of sounds, effects and virtual instruments. This can be expanded further with additional third party plugins and sounds, all of which can be manipulated via MIDI or by keyboard input with easy-to-assign controller mapping - simply set the global "learn" mode and make assignments instantly. Full automation and controller assignment over virtually every parameter in Live 9 give complete freedom to create interesting and polished results, now made even easier by the new clip automation feature.
Max for Live - now in Suite: The Suite edition of Live 9 comes with Max for Live and its many unique instruments, effects and tools. Max for Live itself includes 24 new devices such as a convolution reverb, new drum synthesizer instruments, MIDI echo as well as reworked versions of classics such as Step Sequencer and Buffer Shuffler 2.
With a great workflow, and incredibly flexible methods of working, Ableton Suite 9 remains one of the best DAW/Music Production solutions on the market.
ÏÂÔØµØÖ·£ºÓοͣ¬Èç¹ûÄúÒª²é¿´±¾ÌûÒþ²ØÄÚÈÝÇë »Ø¸´
